Like Tree3Likes
Old 12-30-2010, 02:16 PM   #10156
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
Originally Posted by tfracing View Post
TF Racing have launched their fully universal carbon fibre battery tray. Made in 3mm carbon fibre they help hold batteries in place during an impact where tape would sometimes break. Light and universal it fits most touring car chassis’ and has adjustable positioning for fine tuning your chassis balance. Mounted on 2 rubber o-rings to avoid tweak, it can accept LiPo batteries up to 138mm x 47mm. larger sizes to follow.
is this out already?
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 01-03-2011, 06:27 AM   #10157
Tor Erik's Avatar
R/C Tech Charter Subscriber
Hi
I did just install the Smokem LP chassi to my 416X
But I did loose lot of steering versus the stock chassis.
My set-up are like the Jilles uses alot, white / blue springs, shock oil 450, C/C blocks front and 1XA / E blokcs rear.
Anye tip to get moore steering in the car ??
I did remove the screw above the steering rack and did take out the front sway bar, that did help a little , but still I do not got enough steering.......
Xray XB4 and T4 Futaba 4PK
Tor Erik is offline   Reply With Quote
Old 01-03-2011, 09:06 AM   #10158
Trader Rating: 31 (100%+)
Try removing the aluminum steering brace altogether. This is the only way I can get my car to steer on a high bite asphalt track without raising the roll centers to the moon.
ittjv is offline   Reply With Quote
Old 01-03-2011, 12:43 PM   #10159
Tor Erik's Avatar
Thanks for fast reply !
I did remove the alu steering brace, that did help a little.
Maybe I should try softer springs in the front ? And raise the rollcenter ?
Old 01-03-2011, 02:20 PM   #10160
Trader Rating: 19 (100%+)
try this:
blue front springs, yellow rears
1mm shim under both rear suspension mounts
4mm shims on the top rear bulked
3mm shim on the rear hub carriers
3mm shim on top front bulked
small rear sway bar
medium front sway bar
-1.5* camber front, go to 2* for more steering as needed
-2* camber rear
5mm front ride height
5.5 rear ride height
1mm front droop over ride height
1.5 rear droop over ride height.
Hope this helps, this is the setup i run on mine and it seems to be really aggressive on high bite conditions.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 01-03-2011, 04:10 PM   #10161
CraigM's Avatar
Trader Rating: 34 (100%+)
what surface/tyres?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-03-2011, 05:30 PM   #10162
Tron's Avatar
Trader Rating: 16 (100%+)
Hi
Do you use the same rollcenters as Jilles? If you want aggressive turn in you need to play with front rollcenter...
Do you lose steering in mid-corner or turn in or turn exit? Do you feel it push? Is the rear end planted throughout the turn? Talk to me goose.
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 01-03-2011, 06:30 PM   #10163
Foxxrocket's Avatar
This is going to sound like a dumb newbie question, but it's important to me. I'm finding the antenna post to be a bit too narrow for most antennas to fit into. The stock antenna that came with the kit doesn't even to fit. Any solutions would be helpful.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 01-03-2011, 06:36 PM   #10164
mickrcarver's Avatar
Trader Rating: 98 (99%+)
same here,drilled mine out with my body reamer
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 01-03-2011, 06:36 PM   #10165
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Cut the bottom of the tube at an angle. It should slide right in then.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 01-03-2011, 06:37 PM   #10166
Just grab it as close as you can and stuff it in there!
It will go in. It's a nice tight fit. I've never had an antenna tube pop off.
Old 01-03-2011, 11:01 PM   #10167
Tor Erik's Avatar
Thanks again for reply !
Tron and CraigM :
I run same rollcenter as jilles setup.
My track is carpet, and I use Sorex 28 with blue JB inserts !
Old 01-04-2011, 04:55 PM   #10168
anyone have a 416 standard ball diff they want to trade for my new spec r gear diff? pm me
www.ovrccc.com
Old 01-10-2011, 11:25 PM   #10169
Raman's Avatar
Trader Rating: 56 (100%+)
HELP! what combo spur / pinion can i run to reach 3.5 fdr?
Thus far either the pinion is too big and comes into contact with top deck, or combo is too small and won't mesh without modifying the motor mount which I want to avoid..
Thanks in advance!
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 01-10-2011, 11:38 PM   #10170
pinoy69racer's Avatar
Trader Rating: 180 (99%+)
Thanks in advance!
82/48=3.51.....86/50=3.53
HENRY C
DESOTO RACING/SERPENT/VEYTREX DESIGN LAB/RC TARGET
pinoy69racer is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
