Old 12-13-2010, 03:15 PM   #10126
Originally Posted by hana166 View Post
I recently acquired a 416X lipo car, its very different to anything I have had before. Which plate would you recommend for carpet med/high traction?
If you have high traction I find the trf lipo chassis works better with the original top deck that came with the car, It's slightly wider and stiffer. Make sure you sand the top decks down front and back as they are a tight fit and can cause a tweek from the get go.
Hope this helps.
Paul
blue247carz is offline   Reply With Quote
Old 12-14-2010, 12:43 AM   #10127
hana166's Avatar
Hope this helps.
Paul
Thanks for your advice. I got the original top and bottom deck with it so that's good !
hana166 is offline   Reply With Quote
Old 12-14-2010, 02:31 AM   #10128
Hope this helps.
Paul
Do you have any good carpet setups using the x lipo chassis? i am finding mine hard work on carpet.
Smartypants is offline   Reply With Quote
Old 12-14-2010, 03:21 AM   #10129
RL.2002's Avatar
you can use the jilles snowbird 2010 setup
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 12-17-2010, 04:27 AM   #10130
hana166's Avatar
I'm looking for shims to go under the split block to raise roll centre. I found them online a few days ago but can't remember where. Can anyone help?
Old 12-17-2010, 04:34 AM   #10131
scribbler's Avatar
I didn't think there was specific shims for the split block. I thought you just used normal shims or washers under them. If someone could post a link to this product that would be great.
scribbler is offline   Reply With Quote
Old 12-18-2010, 07:11 PM   #10132
SchuMi2's Avatar
Trader Rating: 34 (100%+)
Can anyone provide me with these measurements...
Cheers
Tamiya TRF416 / TRF416WE / TRF416X-416steer.jpg
SchuMi2 is offline   Reply With Quote
Old 12-18-2010, 09:50 PM   #10133
chrisk's Avatar
Trader Rating: 32 (100%+)
i have:
A 17.2mm
B 28.8mm
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 12-18-2010, 10:06 PM   #10134
SchuMi2's Avatar
Originally Posted by chrisk View Post
i have:
A 17.2mm
B 28.8mm
Cheers
Old 12-19-2010, 07:20 AM   #10135
TryHard's Avatar
Jeez, I'd forgotten just how good Tamiya's are to drive... Finally got round to running my 416X again these past few weekends, ran modified last week and 17.5 boosted on two very different tracks... but only had to make a couple of small adjustments to get it spot on for both...
Now just need to stop myself ordering a 417 as a christmas present!
Good to be back
Ed
Old 12-19-2010, 08:14 AM   #10136
Tron's Avatar
Trader Rating: 16 (100%+)
Good to be back
Ed
Where'd you go?
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 12-19-2010, 09:35 AM   #10137
Stein Tumert's Avatar
Originally Posted by Tron View Post
Where'd you go?
Believe TryHard tried out another blue color....
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 12-19-2010, 09:35 AM   #10138
Good to be back
Ed
Just get the order in, mine is on the way :-)
Stein Tumert
Old 12-19-2010, 03:46 PM   #10139
Good to be back
Ed
Do it!!
kdempsey is offline   Reply With Quote
Old 12-19-2010, 08:58 PM   #10140
TryHard's Avatar
Ahh, not quite... Ran a JRX-S R all last season, but now gone back to blue. Had some issues with the Losi that I just don't think could have been resolved without a fairly big update (which I just don't have the or time to put into), and the car has now been discontinued, so not much point to carry on.
Anyway, brought a second hand X with LiPo chassis not long after finishing the national series, but with a very busy period of work, re-locating to china, and my confidence and enthusiasm having taken a big battering as well, I've only just manged to run it
Nothing like jumping in the deep end though, first time I so much as touched a controler in 3months, never run a LiPo chassis, never run 3.5t with boost, never run a gear diff...and guess what, didn't take long to get back into the swing of it and have a big grin on my face
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
