Old 11-27-2010, 08:04 AM   #10081
Tron's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Mugen10 View Post
I think he was asking droop and not ride height. I always start off with 2mm of droop above ride height. Right now I am running 1.5mm of droop above ride height which is 5mm in front and 5.5mm in rear.
No need to
I run droop of 6/5.5 and ride height 4.5/5. Using the droop gauge that's how the numbers are measured.
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 11-27-2010, 04:40 PM   #10082
RAL
RAL's Avatar
Trader Rating: 59 (100%+)
Originally Posted by Tron View Post
No need to
Yup
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 11-27-2010, 08:01 PM   #10083
superspeed's Avatar
tamiya got ti screw kit, not in blue, too bad ae's kit is not metric, ouch.
superspeed is offline   Reply With Quote
Old 11-28-2010, 03:33 PM   #10084
M3dreamin2008 is offline   Reply With Quote
Old 11-28-2010, 04:37 PM   #10085
CraigM's Avatar
Trader Rating: 34 (100%+)
rc champ sell the blue alu screws
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 11-28-2010, 10:30 PM   #10086
Toh WL's Avatar
talk about screws... the blue look cool alongside with blue alu bulkheads...
Toh WL is offline   Reply With Quote
Old 11-28-2010, 10:32 PM   #10087
Toh WL's Avatar
i had prob with screw wear on the bottom of the rear chassis...by the suspension mount. is there a 3rd party skid plate for the 416 series?
Old 11-28-2010, 11:16 PM   #10088
LOSI123's Avatar
Trader Rating: 63 (100%+)
Can some one tell me if this tamiya spring set
http://www3.towerhobbies.com/cgi-bin...?&I=LXWB01&P=7
is the short set or the same as the milky blue set as i have a spring chart that has tamiya springs listed in pounds for the short, milky blue, and just standard (three types of tamiya springs)
LOSI123 is offline   Reply With Quote
Old 11-29-2010, 06:45 AM   #10089
M-Technic's Avatar
Trader Rating: 15 (100%+)
The colored springs vary slightly in spring rate compared to the milky blue springs.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 11-29-2010, 07:12 AM   #10090
scribbler's Avatar
Tamiya used to offer a screw kit that was all aluminum on the top, and the bottom screws were titanium. Unfortunatly, discontinued.
Square offers the same product though. If your interested in the blue aluminum Tamiya screws there also sold seperately in limited sizes. Check out Rc Mushroom, and see if they have anything you like.
scribbler is offline   Reply With Quote
Old 11-29-2010, 05:32 PM   #10091
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
Have a question,
Based on the 416x manual. When the front rear suspension 1C is flipped upside down and the 3mm spacer is under the block. Is that a "low" roll center and whatever else is the amount shimmed up? such as .5mm or 1mm? Also does it equal the front block as "low"?
I hope that is as clear as mud.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 11-29-2010, 05:36 PM   #10092
CraigM's Avatar
Have a question,
Use the split blocks they are less confusing
You're correct though, 3mm is the same as running the front flat on the deck, so when you see a setup sheet with a value that means in addition to the 3mm.
Old 11-29-2010, 06:04 PM   #10093
Mugen10's Avatar
Thanks Craig for the info.
Why does know one run the diffs. high? It has very good results with other cars. I was going to try but the front stock spool rubs the top Al. camber mounts.
Xray T4
Old 11-29-2010, 07:22 PM   #10094
KHoff7's Avatar
I believe that is why no one does.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 11-29-2010, 08:04 PM   #10095
scribbler's Avatar
How can you tell the difference in the split blocks? They don't have the same markings as the typical suspension mounts.
Thanks in advance.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
