Old 11-11-2010, 04:00 PM   #10021
Anyone have a good asphalt set up for the x with exotek lipo chassis? It actually feels good but there is still quite a bit push. I've run Jille's basic out door set up with losi oil 40f/35r otherwise it's the same.
M3dreamin2008 is offline   Reply With Quote
Old 11-11-2010, 04:20 PM   #10022
CraigM's Avatar
Trader Rating: 34 (100%+)
I haven't run the exotek but I found the germany worlds setup better than the base asphalt setup with the X. The only thing I changed was the height of the camber links which I used 5mm/4mm same as the base setup because lower was a bit hard to drive.
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 11-11-2010, 04:27 PM   #10023
Is that set up posted? I'm sure it was but I can't find it
Old 11-11-2010, 08:38 PM   #10024
CraigM's Avatar
Jilles posted it in his thread, it's also on my site
www.tchub.info
Old 11-11-2010, 09:53 PM   #10025
geeunit1014's Avatar
Here is what I ran on the GB parking lot, I thought it was very good. Only things to note, you can go up on camber if you want to, I was running less to try to avoid the "ring of death", I have the 0.5mm hex spacer all around. And finally, go up on oil a little (500-600) if its hotter, helps with consistency. Otherwise this is a good balance, can over or understeer if you drive to aggressively, you have to be smooth
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 11-12-2010, 08:08 AM   #10026
guinnes.s's Avatar
im just about to convert my 416 to the short reversible suspensions arms and wondering on witch way i should fit them,many setups sheet dont shows that. thanx
guinnes.s is offline   Reply With Quote
Old 11-12-2010, 09:42 AM   #10027
Johnny Wishbone's Avatar
You can usually tell on the setup sheet by the location of the bottom shock holes. You have to flip them to get the either/or location.
Old 11-12-2010, 10:15 AM   #10028
guinnes.s's Avatar
so in this case http://www.petitrc.com/reglages/tami...buryNOWRd3.pdf
the front arms are the side were the holes are nearest to chassis ,and the rear on the holes farthest from chassis. mi right?
Old 11-12-2010, 10:56 AM   #10029
Looking at the front of the car head on, the front arms are positioned so that you have the three holes facing out and he is located on the outer hole. Looking at the back of the car as it faces you, the arms are positioned so that there are only 2 lower shock locater holes facing out and he is using the outer hole. Hope that helps.
Old 11-12-2010, 04:20 PM   #10030
Thanks Gee. I will be running at the C next weekend. Maybe i could use this but slightly stiffer?
Old 11-12-2010, 04:24 PM   #10031
www.tchub.info
Thanks for the link.
Old 11-13-2010, 04:40 AM   #10032
please someone can tell me if you not mind that springs work best in 416x.
HPI Springs
Tamiya 53440
Thank you very much
best regards, ciro
Ciro is offline   Reply With Quote
Old 11-13-2010, 01:20 PM   #10033
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
Does anyone know the size of the diff. bearings for the outdrives? I want to order aftermarket.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 11-13-2010, 10:05 PM   #10034
Ultraspeed84's Avatar
Trader Rating: 44 (100%+)
CAn someone post me up a good setup for the 416x on carpet? or email me to teamdwr@aol.com Im going to the cleveland nats thanks
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 11-13-2010, 10:40 PM   #10035
RL.2002's Avatar
you can use the jilles snowbird 2010 setup.
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
