Old 10-14-2010, 12:02 AM   #9916
TryHard's Avatar
Originally Posted by stuartb View Post
Does that mean you are racing Tamiya again?
Yar (although due to work, unlikely to hit the track anytime soon!)
Old 10-14-2010, 12:40 AM   #9917
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Arahawak View Post
Why will snap the belts? Would lessen the tension of the belts help?
would the bigger center alu pulley help in preventing belt snaps?
Sorry for so many questions.. trying to learn the car.
The gear diffs have no slip unlike a ball diff so they put more stress on the drivetrain. I normally run my belts quite tight for this reason, I run the same setting as syndrome.
The bigger pulley will help because there are more teeth and surface area transmitting the power, and the curve of the belt around the pulley isn't as severe as the smaller pulley.
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-14-2010, 02:52 AM   #9918
Arahawak's Avatar
Trader Rating: 32 (100%+)
Ok will take note to tighten the belt when i get a gear diff.
So I should be looking for 19T or 20T center pulley then right?
Hmmz, just realize also if we change the center pulley, won't the internal ratio change too?
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 10-14-2010, 04:56 AM   #9919
Senna Racing's Avatar
yes 1.94 and 1.85
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 10-14-2010, 05:07 PM   #9920
rcscoot2539's Avatar
I just picked up a 416x with the smokem lipo chassie, first weekend with the car a TQed both rounds and won the main. This car is sooooo much better than my Photon.
TC6 - B4.1 - LOSI SCTE - LRP - SPEKTRUM - SWEEP - AB CHARLES HOBBY SHOP - THE RACEWAY AT BEAVER
rcscoot2539 is offline   Reply With Quote
Old 10-14-2010, 05:15 PM   #9921
Anyone on this thread going to the Halloween Classic in Cleveland next weekend?
Old 10-14-2010, 06:28 PM   #9922
Akudou's Avatar
on one of the suspension mount setup given, the Front suspension mounts require D but as i am using seperate suspension mounton the front rear, should i just stick with the 1a/1xa or are there any other options? plus it says 0.5 shim? hmmmm
Akudou is offline   Reply With Quote
Old 10-14-2010, 10:11 PM   #9923
CraigM's Avatar
The standard setup is C/C front and XA/E on the rear. D/D on the front is a good to take away steering if you have too much, I most often use D/D on my original 416. We almost always run 0.5mm under the rear blocks, and often run 0.5mm under the front block that is flipped over the belt to provide some anti-dive, though this is becoming less common with the X and the lipo deck.
If you are running an A block at the front then you most likely have the original 416 with the long arms. Chucking them in the bin is the first thing you should do
Old 10-15-2010, 07:21 AM   #9924
Default 416
hey guys,
here is my 416 with some modification~
take a look~
teamsanwa is offline   Reply With Quote
Old 10-15-2010, 10:13 AM   #9925
Tron's Avatar
Trader Rating: 16 (100%+)
Cool Please Help!
I have a few questions if someone would help that would be greatly appreciated:
1. If I install the Tamiya 54121 Aluminum Servo horn will this take out the slop in my servo saver? Do I have to buy the new servo saver and the horn or will the horn alone fix the slop? I'm guessing the slop is caused by the soft plastic top piece being compromised by the servo saver springs in a good impact.
My servo saver is notchy and causes my car to wander left or right.
I know a lot of you use the Kimbrough servo saver too, but would prefer to pickup the Tamiya aluminum horn since it is locally sold.
2. Are the knuckles and c-hubs left/right specific?
3. My car has some torque steer. There is no tweak but I have yet to balance the chassis, could this cause the on/off throttle torque steer?
BTW, I am running Jilles asphalt setup on the car, 21.5 Novak, 50c Thunderpower battery, 15g weight on battery side rear, Havoc ESC and S9551 Futaba Servo with R604fs receiver.
Thanks a lot in advance.
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 10-15-2010, 11:14 AM   #9926
artwork's Avatar
Trader Rating: 59 (100%+)
1. Keep Servo savers in stock because they do go bad after a while. Just replace them they are cheap.
2. The C-hubs are for sure side specific. the steering block are not.
3. Make sure the belts and diffs are tight and make sure your car is balanced and not tweaked
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 10-18-2010, 12:16 PM   #9927
Raman's Avatar
Trader Rating: 54 (100%+)
Could someone kindly give me the link for the aftermarket gear diff for the 416.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 10-18-2010, 12:45 PM   #9928
artwork's Avatar
http://www.spec-r.com/specrr2/
Old 10-19-2010, 12:45 AM   #9929
For those of you that run the smokem fx chassi make sure that the chassi isnt bent like a banana when assembled. We had two chassis that ended up like this and had to file the topdeck quite a bit on both ends and enlarge the front holes in the topdeck to line them up with the bulkhead holes. The chassi seems to be around 0.5mm shorter than stock tamiya one.
Mr_Orange is offline   Reply With Quote
Old 10-19-2010, 12:45 PM   #9930
20967's Avatar
Hi everyone.
With the Smoken-Fx chassis I had the same problem. In my the hole were not off-center than the original but the belt most shortened. I slightly loosened the belt and everything went well.
With the new chassis and Spec-R diff in my first indoor race in this season I take the final "A" and I ended up 5th in the overall standings.
Good result if we think that for the first time I raced with the new chassis and the new diff.
20967 is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
