Old 10-09-2010, 07:56 PM   #9871
shikakae123's Avatar
Can tamiya parts be used with T3?
shikakae123 is offline   Reply With Quote
Old 10-09-2010, 09:53 PM   #9872
LOSI123's Avatar
Trader Rating: 63 (100%+)
Can anyone tell me if the Tamiya li-po chassis's carbon L type battery brackets can be adjusted not only side to side, but forward and back also? I was interested so as to adjust perfectly for differnt li-po's length so as to stop battery moving forward and back under hard braking and throtle.
I have not purchased it yet
LOSI123 is offline   Reply With Quote
Old 10-10-2010, 03:44 AM   #9873
Toh WL's Avatar
Originally Posted by shikakae123 View Post
Which is cheaper?which need lesser hop up parts? Maintenance and durability?
the xray is slightly a bit expensive. talking how tough is the car? the xray tc fits the catagory. but u know a more harder n rigid car have it's con too.. besides tamiya tc are more frequent in podium as u may see... on reliability, durability & maintainance.. the tamiya trf cars competitive as xray tc.
so my choice is tamiya 416 series, as parts availability & support are far better than xray.. that depends which region u are in. so the tamiya tc wins..
Toh WL is offline   Reply With Quote
Old 10-10-2010, 05:08 AM   #9874
Taman's Avatar
Trader Rating: 64 (100%+)
Hi,
there appears to be two settings you can have it on eg: too battery lengths but dont quote me on that, I just have the chassis sitting in front of me
Taman is offline   Reply With Quote
Old 10-10-2010, 04:51 PM   #9875
Default Very low grip asphalt base setup
Can anyone suggest a good starting point setup for very low grip outdoor asphalt on medium sized track. I just purchased the new Tamiya lipo upgrade and no matter what I do I have a real loose rear end. On the track with the kit setup slightly altered the car just has no grip in the rear on or off power. The rear end is just sledging around all over the place. Have checked all the settings and its got me baffled. Ive only own the car for a few months and have had little track time due to poor weather. Any help would be much appreciated.
Bumpy is offline   Reply With Quote
Old 10-10-2010, 05:19 PM   #9876
CraigM's Avatar
Trader Rating: 34 (100%+)
Try wider front track, softer springs and shock oil , lower rear roll centre and some rear pro squat.
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-10-2010, 05:35 PM   #9877
cheehtae's Avatar
Trader Rating: 15 (100%+)
What kind of tires are you using?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 10-11-2010, 12:11 AM   #9878
Im using Sorex tires with Speedmind wheels.
Old 10-11-2010, 01:21 AM   #9879
Xchange's Avatar
Trader Rating: 10 (92%+)
Hello,
This week, i ran my new freshly builted 416X with a Smokem 416FX chassis.
The car is perfectly balanced and weigth is equal left/right forward and backward.
All the stuff is new, tire glued and EPA is correctly setted.
And from the first time i put the car on the track, the 416 lose the rear left and right but left is much violent than the right but basicaly, no traction on the rear.
No tweak on the chassis and no pin bented.
The main problem is, the car dosent react to my setup change.
What i think is the smokem chassis is have too much flex.
Anybody have a similar issue ?
thanks
Xchange is offline   Reply With Quote
Old 10-11-2010, 02:30 AM   #9880
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Originally Posted by Xchange View Post
Hello,
thanks
Please don't take this wrong way.... but have you also checked:
1. shocks (air in them, leaking, not equal rebound)
2. rear toe blocks are aligned properly
3. is droop set correctly
Also, are you running a gear diff? and what is the track grip like? are the tires properly glued to rim?
I have been running the Smokem FX chassis on low-med grip outdoor asphalt tracks with great success. Laptimes are definitely faster compared with Tamiya lipo chassis.
HTH.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 10-11-2010, 03:09 AM   #9881
CraigM's Avatar
I just bolted the smokem fx deck on, interested to see how it goes. It has a bit more flex than the standard deck, particularly at the front. Hope the weather stays nice
Old 10-11-2010, 04:37 AM   #9882
Xchange's Avatar
HTH.
Thanks for your answer,
Well, shocks has been builded, no leak, no bubble and air in them.
Rear toe block are been aligned
And finally, droop are 6 front and 5 rear with 5mm front and 5,5mm rear ride height.
I inverted the tire and no difference.
Flipped the upper deck, no difference
Track had lower to medium grip.
On the begining of the qual, when the tire add is fresh, the rear stay a bit more on the track.
I tried to put the tire additive only on the rear first and 10m before the race, put in the front.
No change...
My springs are dark blue on front and yellow on rear. Oil i started with 45wt to all and put 55wt on rear to give a bit more rear traction on high speed turn.
I m need idea!!
But the big mistery is the car turn more on left than right !!
Old 10-11-2010, 04:51 AM   #9883
Senna Racing's Avatar
Put your tamyia steering brace back on the car with the screw in he top deck
And make sure you have equal throw left to right in your steering
You may have to much grip in the front end
Also try silver springs alround or go softer in the tamiya this worked for me on the weekend
Although I'm still have a touch to much I will try a one piece d block tomorrow
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 10-11-2010, 04:55 AM   #9884
veecee's Avatar
Xchange, are you running a gear diff? That can make quite a difference, especially if it is not nice and smooth or with the right oil. Also some people have found the gear diff difficult to drive on low traction surfaces.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 10-11-2010, 06:12 AM   #9885
artwork's Avatar
Trader Rating: 56 (100%+)
No change...
I m need idea!!
Sometimes in my pit the car looks balanced...but at speed on the track it does not feel balanced. To fix this I usually adjust some weight on the lighter side. This assumes something bigger is not going on in the car. It sounds like you have checked most of the things that could be part of the problem. Make sure all of the shock lengths are the same...this could be causing your issue.
As for the problem about the car being loose...it sounds to me like your front tires are getting to hot. To fix this I would try a couple of things:
If you are on carpet I would run HB Silver or Tamiya white springs up from with 45wt oil. I would run HB or Tamiya blue in the rear with 40wt oil. 1.5mm over ride height droop both front and rear.
If you are running on pavement I would run HB silver with 40wt oil. In the rear I would run HB silver or blue with 40wt oil. 2.0mm over ride height droop both front and rear.
Although Yellow blue seems like a good combo...I have yet to find a track that this feels good on. I have spent a lot of time testing springs and I have found that the Hot Bodies springs feel the best on the car regardless of the surface, but some people swear by the Tamiya springs on carpet because that is what the team drivers run. Simply, I run what feels best on the car and I can tell you that HB springs are way more consistent.
The Key is to control balance in the car...I have not run the smokem chassis, but it sounds like with your suspension setup the car may be simply too soft.
good luck!
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
