Old 10-06-2010, 07:27 PM   #9856
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by veecee View Post
Have a pack right in front of me mate - 53500!
Thanks Vinny!
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-07-2010, 10:44 PM   #9857
shikakae123's Avatar
If the aluminium dampers does not have any rebound,does that mean that it is spoilt?
shikakae123 is offline   Reply With Quote
Old 10-07-2010, 11:19 PM   #9858
It could mean that oil has leaked from the damper which usually happens over time.
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
Old 10-08-2010, 02:10 AM   #9859
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
How do you achieve zero rebound for the shocks?
When i fully compressed the shaft of the shocks, and place the rubber cap it will hit the end of the shaft of the shocks and causes the oil to spill.
hello miss, puwede pa bind?
nikkiesteban is offline   Reply With Quote
Old 10-08-2010, 02:45 AM   #9860
However,I got the dampers quite recently and only use it once.It is a third party item.
Old 10-08-2010, 04:04 AM   #9861
cheehtae's Avatar
Trader Rating: 15 (100%+)
it should spill because it will only retain the oil that is sufficient, just wipe it. To achieve ZERO rebound, JGH achieves this by drilling a tiny hole on the cap.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 10-08-2010, 08:20 AM   #9862
M-Technic's Avatar
If you aren't spilling oil no matter what rebound you build the shocks with you probably introduced air to the shock when you put the cap on.
To build with 0 rebound just put the shaft in all the way before you put the cap on.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 10-08-2010, 05:45 PM   #9863
crabboy's Avatar
Trader Rating: 58 (98%+)
What sway bars fit on the front and rear of the 416X, can some one give me part numbers or a link to buy.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 10-08-2010, 05:52 PM   #9864
stitchy's Avatar
Rhys
Fronts
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 10-08-2010, 07:16 PM   #9865
RL.2002's Avatar
Rhys
U can use the TA05 sway bar. Im sorry, im forget the part number.
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 10-09-2010, 12:13 AM   #9866
CraigM's Avatar
Rhys
I've never seen an asphalt setup from the team that used sway bars other than the kit ones
Old 10-09-2010, 08:23 AM   #9867
Which is better for touring? TRF 416X or Xray T3?
Old 10-09-2010, 08:39 AM   #9868
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
It really depends what you want and how much you want to spend.
If you want the TC that won the world TC title 4x, go with the TRF TC series
If you want the TC that everybody uses at your local track, go with that if it's the Xray.
Either one, it boils down to you and your money.
But if you want my personal opinion....check my SIG with the exception of the last 2 kits listed.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 10-09-2010, 09:06 AM   #9869
Which is cheaper?which need lesser hop up parts? Maintenance and durability?
Old 10-09-2010, 09:23 AM   #9870
JRRobiso's Avatar
Both TCs are durable, about the same price range and require maintenance.
I know there are some here that had experience with XRay and TRF kits and would provide more valuable and detailed input for you.
For me, I've only owned the TRF TC kits when I started the hobby and later tried the Kyosho brand for nitro TC sedan and 1/8 nitro GT cars since Tamiya did not have kits for those platforms mentioned.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
