Old 09-16-2010, 06:49 AM   #9721
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by barts71m View Post
Was this on foam tires????
Jaco Blue rubber tires. It's almost identical to the setup he also ran at, I think TCM a few weeks later.
syndr0me is offline   Reply With Quote
Old 09-16-2010, 08:14 AM   #9722
jonest's Avatar
Originally Posted by Taman View Post
Hi,
is the 3Racing gear diff better for the 416X or the Spec-R?
thanks
3racing is definitely better!
jonest is offline   Reply With Quote
Old 09-16-2010, 02:48 PM   #9723
Taman's Avatar
Trader Rating: 64 (100%+)
Thanks for the reply
Taman is offline   Reply With Quote
Old 09-16-2010, 03:40 PM   #9724
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Tron View Post
I have a few questions:
How much better is the Lipo chassis that Tamiya makes for this?
Some have mentioned flipping the pulleys, is that possible with the stock chassis? Is the purpose of flipping the pulleys to accommodate the wider lipo battery and improve balance? Is it necessary for someone like me who is getting back into on-road after a 20 year hiatus?
My plan is to run RCGT at West Coast. 911 body, Ballistic 21.5 with a Novak Havoc Pro speed control...will the Havoc fit alright?
Do I have to run a shorty steering servo? Any recommendations?
There is plenty of room in the 416 even with a full size servo
Flipping the belts just allows you to centre the weight of the electronics more, which makes the car change direction a fraction better. You can flip the belts on the normal chassis but you need to enlarge the holes under the diff/spool. People have found up to 3 tenths difference with the lipo chassis, personally I've only found it a tenth or so better on most tracks. My smokem FX deck just arrived, I'm keen to see how that compares too
Hi,
thanks
They are pretty similar but I prefer the Spec R
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 09-16-2010, 06:37 PM   #9725
Still cant keep my oil in the Spec-R even with the new style X o rings... What are you guys running for oil in ether of the two gear diffs?
Thanks!
Kody is offline   Reply With Quote
Old 09-16-2010, 08:21 PM   #9726
transplantlife's Avatar
Trader Rating: 43 (98%+)
hey guys wanted to ask what upgrade bearings are you using was looking at the abec35 or acer??
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 09-16-2010, 10:30 PM   #9727
$1 Avid is what I run. There great and one of the best bearings for the money IMO. Check them out, http://www.avidrc.com/
Old 09-17-2010, 12:01 AM   #9728
StevenOlsen's Avatar
Thanks!
im running 1,00 kyosho oil in my 3-racing geardiff, tested it wedensday, the car has a lot more traction compare to a normal diff. om also running a geardiff in the front with 300,000 kyosho oil, it gives a little more steering campared to a spool.
im running the steel bearings abec5 with blue rubber seal, the berings are good and im not doing any thing other then put them in my car, no cleaning out the bering before running them. and when the berings not run smooth any more i just throw them out
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 09-17-2010, 12:16 AM   #9729
Originally Posted by kschu View Post
both fit well into 416x.
3racing gdiff have slop and can be fix with adding 2pcs axle type shim 0.2mm x 2pcs while spec-r gdiff is leaking but can b fix by replacing with latest o-ring..
so the choices is yours...
SPec-r Gdiff
3racing Gdiff
3racing, spec-r and NT-1 gear diff(need modify) i was used.
the best gear diff is xray NT-1 gear diff(rear), durable and good quality!!!
teamsanwa is offline   Reply With Quote
Old 09-17-2010, 12:18 AM   #9730
what??
i think you need to try xray nt-1 gear diff before you say"3racing is definitely better!"
Old 09-17-2010, 12:54 AM   #9731
Damon's Avatar
Originally Posted by teamsanwa View Post
what??
does nt-1 gear diff fit on 416X?
Awesomatix A800
Awesomatix A800X
Damon is offline   Reply With Quote
Old 09-17-2010, 04:18 AM   #9732
CraigM's Avatar
yes, you need to mod the pulley to fit though
Old 09-17-2010, 05:14 AM   #9733
jonest's Avatar
what??
Of course the nt1 would be best as it's metal gear but need modifications. How do you modify it btw? If it's not much work required, I'd like to try one.
Old 09-17-2010, 05:46 AM   #9734
barts71m's Avatar
Cheers. Was going to try with some foams but will go back to Jilles base foam setup...or will this be a good setup for carpet on foams.
barts71m is offline   Reply With Quote
Old 09-17-2010, 08:43 AM   #9735
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
maybe u can try ROche Ceramic bearing..
Give the best while u can !
kschu is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
