Old 08-14-2010, 11:08 PM   #9511
Smile
hello,
now i used TRF416 (first edition) since 2 year ago.
if i would like to upgrade to 416X it's posible ?
I guess lower deck, upper deck, bluckhead, motor mount ETC. must be change.
please advice me about part list.
Regards,
TA.man is offline   Reply With Quote
Old 08-15-2010, 12:10 AM   #9512
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by M3Armand View Post
For the guys that already bought and received their kits... how about posting some pics!@?!
My X in its latest trim.
Tamiya TRF416 / TRF416WE / TRF416X-416.jpg
syndr0me is offline   Reply With Quote
Old 08-15-2010, 12:50 AM   #9513
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Mugen10 View Post
So the Smokem chassis is stiffer then the 2.25mm Tamiya chassis? What about the Tamiya lipo chassis? The Smokem chassis is 2.2mm thick.
Smokem has 2 different chassis. The 416LP is 2.3mm with no cutouts and is stiffer than standard Tamiya 2.25mm. The 416FX is 2.2mm with cutouts and has more flex.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 08-15-2010, 07:48 AM   #9514
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
Thanks for the info. I will buy the stiffer chassis.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 08-15-2010, 10:10 AM   #9515
IgorR's Avatar
Default Compare option chassis
Hello,
Did somebody already compared for the 416 on carpet the two smokem chassis (LP and FX) and the one from Tamiya (TA-42182)?
Could you tell how it felt and the one you prefer?
Yokomo YR-X12
Shepherd Velox EC
IgorR is offline   Reply With Quote
Old 08-15-2010, 10:47 AM   #9516
RC MARKET's Avatar
Tamiya 42182 had more flex than before TRF416X !
if too many holes in chassis life short .
RC MARKET is offline   Reply With Quote
Old 08-15-2010, 10:53 AM   #9517
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
So, somebody needs to come out with a simple, stiff lipo chassis, or i'm just gonna make my own at the shop. Smokem looks to be the best option?
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 08-15-2010, 08:49 PM   #9518
Anyone try Exotek chasis?
How it performs and compare with Smokem and TRF Lipo chasis?
Tdriver is offline   Reply With Quote
Old 08-15-2010, 08:56 PM   #9519
HI_808's Avatar
I am soon going to put my Smokem 416LP chassis to use as we are likely to adapt the 1350 gram weight limit.
For those that have used the Smokem chassis or any other chassis with flipped belts and the servo mounted closer to the center line of the car, are there any clearance issues with the tie rod which connects the servo to the steering assembly? It looks like it might rub the upper deck.
Thanks!
HI_808 is offline   Reply With Quote
Old 08-15-2010, 09:31 PM   #9520
Originally Posted by CraigM View Post
Kyosho, I believe that's what the team used at the worlds
When I built the diff, I used 2 of the shims on each side to prevent the shims collapsing into the orings. Even though they are only 0.1mm it meant I needed to use 2 gaskets to get a nice mesh. After one meet it feels even better now, but I might give it a go with a single gasket now that the teeth are bedded in just in case the mesh is a little too loose now
Really happy though, I didn't expect it to be that good in lower grip, cant wait to try it on a dry track and check the lap times!
I try Mugen 3000wt oil but it seem too light. Any problem on the gear diff?
Old 08-15-2010, 11:31 PM   #9521
Trader Rating: 31 (100%+)
Thanks!
Yes, it will rub a bit. You'll have to remove .5mm of the spacers on the steering rack. Other than that, everything else is a perfect fit.
ittjv is offline   Reply With Quote
Old 08-15-2010, 11:31 PM   #9522
CraigM's Avatar
I'm still running 1000 and its working great. I have noticed some slop which I believed was in the teeth but when I removed the 2nd gasket the mesh was too tight again, so I think the slop is between the gears and pins. I'll be glad when tamiya bring out their gear diff, hopefully it'll have metal gears like the TOP one
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 08-16-2010, 09:15 PM   #9523
Thanks.
Old 08-17-2010, 04:52 AM   #9524
Does anyone know any online stores that have the Lipo chassis in stock. Perfect timing, I finally get the $$ together for the chassis and everyone sells out.
Bumpy is offline   Reply With Quote
Old 08-17-2010, 05:10 AM   #9525
RC MARKET's Avatar
Sakura Gear Diff. Lower Price & Fit 416 with bearing , silicone & shim set
http://rcmarket.com.hk/product_info....her7s3b02jtit4
Tamiya TRF416 / TRF416WE / TRF416X-3r-sak-65.jpg
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
