Old 08-09-2010, 05:24 PM   #9481
CraigM's Avatar
Trader Rating: 34 (100%+)
mmm got my tamiya lipo deck yesterday - thanks RC Market, that was super quick! I have it mostly installed now, can't wait to give it a run on Sunday, it's a lot narrower than I thought it would be
Originally Posted by Tor Erik View Post
CraigM
Does the 511 diffs fit in the 416 ??
I think they will with a bit of shimming, the 511 looks slightly narrower but my verniers ran out of battery so I cant tell for sure
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 08-09-2010, 05:27 PM   #9482
syndr0me's Avatar
Trader Rating: 32 (100%+)
The new top deck is a bit narrower as well. You don't have to cut your servo ears off, and the pinion is much easier to get at from the top.
This new chassis from Tamiya is excellent. Gonna test it on the rug tomorrow.
syndr0me is offline   Reply With Quote
Old 08-09-2010, 05:33 PM   #9483
LOSI123's Avatar
Trader Rating: 63 (100%+)
If i fit the New li-po upgrade chassis set from tamiya to my 416WE , i know i cant fit the top deck and must use my WE top deck which is ok with me, but does anyone know if doing that will effect my posibilities of different li-po's fitting??
LOSI123 is offline   Reply With Quote
Old 08-09-2010, 07:00 PM   #9484
artwork's Avatar
Trader Rating: 59 (100%+)
I figured I would post my setup that I used at Norcal this weekend from the ROAR Nats...Not sure if anyone wants it but I found my car pretty good and really easy to drive.
I have my setup posted on my website...http://projectgreenracing.com/PGR/Re...X%20Norcal.pdf
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 08-09-2010, 07:07 PM   #9485
CraigM's Avatar
No, the lipos should all fit the same. Looking at the top deck the front is narrowed more than the back so it should yield a bit more steering than the standard X top deck
are you really using hole 3 on the front arms?
Old 08-09-2010, 07:14 PM   #9486
artwork's Avatar
Yes
Old 08-09-2010, 07:25 PM   #9487
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Looked at your sheet. To me, at Norcal, Solaris felt like they fell off after one run and just became victims of the current heat of the track. And to others, they felt like they lasted forever. Inconsistent. Some people swear that 1 degree of camber is how to run solaris, since they have such a skinny insert anything more inner grooves of death. But when the tires only last just over a couple runs, inner grooves of death don't matter.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 08-10-2010, 01:40 AM   #9488
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
check out the Trf conversion kit here
Give the best while u can !
kschu is offline   Reply With Quote
Old 08-10-2010, 04:17 PM   #9489
CraigM's Avatar
Elliott Harper was nice enough to send through his setup from the euros last weekend, what a legend
File Type: pdf Elliott Harper - 2010 Euros Aniche.pdf (313.4 KB, 336 views)
Old 08-10-2010, 08:44 PM   #9490
Magnet Top's Avatar
Art shared his setup with me at the NorCal ROAR Nats and it worked well ( thanks again ). Only difference was I was using a speed 6 and left the front wheelbase spacers at 2 and 2 only due to not having the chance to try it with 1 and 3.
Kudos to your great A main result. it was a stacked 17.5 Expert field.
Magnet Top is offline   Reply With Quote
Old 08-10-2010, 10:13 PM   #9491
syndr0me's Avatar
I tested the LiPo chassis tonight on carpet. I was struggling through some other problems that held me back a bit, but my initial impression is that the car is a lot more nimble, and makes quick direction changes more easily without upsetting the car. I felt like I could drive it harder in fast sections without risking stepping out.
The new top deck is surprisingly narrow. It felt like the car generated more mechanical grip, and was very planted in the rear. For me, on high traction carpet, it's not really the feel I'm after. But other guys will undoubtedly make it fast, so I suppose it's just a matter of preference. I'm gonna put the WE bits back on the LiPo chassis, they definitely fit fine.
Old 08-11-2010, 02:40 AM   #9492
kentech's Avatar
TRF ISTC Worlds setup and some other Worlds stuff @ http://kentech.blogs.se/
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 08-11-2010, 04:21 AM   #9493
Trader Rating: 45 (100%+)
Anyone know when the LiPO conversion will be available for US consumption? Want to order from my LHS. Plus, I need to come out of TC retirement for a day to prove a point.
Apex is offline   Reply With Quote
Old 08-11-2010, 06:51 AM   #9494
syndr0me's Avatar
You know what's interesting? The LiPo conversion kit says it's "made in the USA." But it's not available here.
Old 08-11-2010, 07:27 AM   #9495
M-Technic's Avatar
Trader Rating: 15 (100%+)
It sounds like the chassis combo might have more flex if it's making more mechanical traction. Maybe it'll work better in high bite with the standard top deck?
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
