Old 07-20-2010, 09:19 AM   #9346
tommi's Avatar
Originally Posted by Richards Racing View Post
Raced on Carpet on the weekend, most guys had a one way just wandering if anyone knows someone who makes a oneway for the 416WE.
Noel
You'll need the following parts for a front one-way on the WE:
One-way housing: #3454520
One-way joint: #9444623
37T one-way pulley: #54023
tommi is offline   Reply With Quote
Old 07-21-2010, 10:13 AM   #9347
Trader Rating: 19 (100%+)
Originally Posted by CraigM View Post
2.5 deg front camber is also an uncommon setting, and you didn't post any of your roll centre settings either, but that's ok. Here is the setup I've been running on med grip asphalt with excellent results, it's very similar to the setup the TRF team were running at the worlds, give it a go
Thanks for posting up this setup. I'll give it a try this weekend.
How do you measure the droop setting front and rear?
zake540 is offline   Reply With Quote
Old 07-21-2010, 01:59 PM   #9348
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
Ok I am leaning to the 416X over the T3 and Photon for this fall/winter indoor carpet rubber.
I have never ran Tamiya. What parts do you recommend to have on hand? This is a shot in the dark but does anyone know where to find a carpet setup for 17.5 tight track?
I just hope the results will be even close to my Losi.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 07-21-2010, 02:50 PM   #9349
Richards Racing's Avatar
Default Thanks
Thankyou for your help parts are being ordered today.
Noel Richards
RC Core - Castlehill Raceway
O/M - VBC Racing - M05 - Sanwa - Hobbywing
Junior - ARC - Killshot - Spektrum DX3R Pro - Hobbywing
Daughter - VBC Racing - Spektrum DX3S - Hobbywing
Richards Racing is offline   Reply With Quote
Old 07-21-2010, 02:53 PM   #9350
Default Setup
If you check the main Tamiya website they have a basic setup for carpet by a factory driver in the TRF site.
Noel
Old 07-21-2010, 07:09 PM   #9351
cheehtae's Avatar
Trader Rating: 15 (100%+)
Get the car first then worry about the parts later,, Dirty Johnson.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 07-21-2010, 07:29 PM   #9352
CraigM's Avatar
Trader Rating: 34 (100%+)
Droop is measured with droop blocks under the outer hinge pins i.e. not under the set screw bump on the front arms
The setup works a treat for me, it's the best I've had my X. I've just installed a gear diff to try, looking forward to testing it out!
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-22-2010, 12:36 AM   #9353
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
What shop in america has spec r gear diffs for the 416 in stock? Looking to adapt something, but in the mean time I need a spec r. Might have to adapt a Photon gear diff.
Does Atomic/Spec R have a america distributer? Got to get them into our shop.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 07-22-2010, 01:20 AM   #9354
CL
CL's Avatar
Trader Rating: 32 (100%+)
Try this shop:
http://store.hkshobby.com/product_in...bcd3049b6ce645
Believe in yourself!
CL is offline   Reply With Quote
Old 07-22-2010, 07:23 AM   #9355
M-Technic's Avatar
Speedtech imports both Spec R and Atomic, but they are out of stock on both for the moment.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 07-22-2010, 08:47 AM   #9356
Originally Posted by CL View Post
Thank You, that might have to be the place I order.
That was the first place I checked.
Old 07-22-2010, 07:38 PM   #9357
RAL
RAL's Avatar
Trader Rating: 59 (100%+)
C-hubs, Rear Hubs, Front arms and dogbones. And get titanium turnbuckles. The stock alum ones are very soft.
RAL is offline   Reply With Quote
Old 07-22-2010, 10:34 PM   #9358
CraigM's Avatar
C blocks I've never broken an arm the whole time I've been running 416s. The C-hubs are also a lot chunkier now than they used to be and they're a lot harder to break.
I find the best parts to carry are actually for the drivetrain. Keep heaps of driveshaft blades on hand and replace them regularly, as soon as one wears a bit it will break and ruin your outdrive$ in a lap or two. Spool cups are also a must to keep spares of - it's best to run the 46mm driveshafts to prolong them a bit more
Old 07-22-2010, 10:42 PM   #9359
dodo's Avatar
Send a message via Yahoo to dodo
+1
spool cups are regular replacements for me every 2 or 3 race weekends.
arms are tough
i've broken 1 c-hub thus far on a very small, tight carpet race with 11.5R and turbo
never bent any suspension blocks. hingepin, yes.
dodo is offline   Reply With Quote
Old 07-22-2010, 11:23 PM   #9360
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
I just got these in the mail today. I hope to test them out Saturday. I got tired of replacing spool cups...
http://www.speedtechrc.com/store/ebp...il.asp?id=9868
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
