Old 07-18-2010, 01:27 PM   #9331
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Originally Posted by Taman View Post
Sounds like I'll be buying one of these when they are in stock Do you still have to tape the battery in?
Yep. Still use tape. The carbon lipo retainers are there to stop the lipo from moving or ejecting out.
The TRF guys do not seem to use them and just use tape only.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 07-18-2010, 01:56 PM   #9332
Richards Racing's Avatar
Default One Way
Raced on Carpet on the weekend, most guys had a one way just wandering if anyone knows someone who makes a oneway for the 416WE.
Noel
RC Core - Castlehill Raceway
O/M - VBC Racing - M05 - Sanwa - Hobbywing
Junior - ARC - Killshot - Spektrum DX3R Pro - Hobbywing
Daughter - VBC Racing - Spektrum DX3S - Hobbywing
Richards Racing is offline   Reply With Quote
Old 07-18-2010, 03:29 PM   #9333
CraigM's Avatar
Trader Rating: 34 (100%+)
Tamiya makes a 1-way which it includes with the jap kits. I'll have a look to see if I have one at home, you're welcome to it if I do
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-18-2010, 03:48 PM   #9334
RC MARKET's Avatar
Tamiya TRF416 / TRF416WE / TRF416X-sat-marccake-3.jpg   Tamiya TRF416 / TRF416WE / TRF416X-sat-haracake-1.jpg   Tamiya TRF416 / TRF416WE / TRF416X-sat-haracake-2.jpg
RC MARKET is offline   Reply With Quote
Old 07-18-2010, 04:03 PM   #9335
JCarr's Avatar
Originally Posted by Johnny Wishbone View Post
Artworks discription is what I find as well. To put a shim under the suspension bridges front or back will loosen that end of the car, less grip.
How about calling them (from front to rear) front, mid front, mid rear, and rear, I think its pretty self explanitory.
Boy I hate this car, I have a worked over 416, not a WE or a X, I have shelved this car for about 4 months now, due to a disagreement, last week I took it out, put in a older speed control and a used up motor, proceded to turn more consistant laps and only a 10th off my best time with the car I have spent a lot more time on. They are both great cars, but my 416 is such a tease.
JCarr, what is it your trying to make the car do??
I'm trying to get a little more steering into the car. I put the shims under the rear mounts and got to make a couple runs on saturday. The car was improved, but I still could use a little more. That's guys for the help and insite on this. I noticed that I have been draggin the rear of the chassis a good bit so I think I may need to go to stiffer springs all around.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 07-18-2010, 06:23 PM   #9336
CraigM's Avatar
Post your full setup and we can help out
Old 07-18-2010, 06:50 PM   #9337
JCarr's Avatar
Surface: med grip asphalt
tires: jaco blue
ride height: 5 or 5.5 not sure which right now
camber: 2.5 f/2.0 r
springs: assc blue f/silver r
Shock oil: not sure got the car used and never opened them
toe: 0 f/ 2 r
sway bar: soft f/ none r
shock position: front bottom outer hole, top 4th hole from outside/ rear bottom outer hole, top outermost hole.
Gorilla Size Racing
Old 07-19-2010, 03:05 AM   #9338
Default One Way
Thanks for that Craig.
Noel Richards
Old 07-19-2010, 09:42 AM   #9339
Johnny Wishbone's Avatar
tires: jaco blue
camber: 2.5 f/2.0 r
toe: 0 f/ 2 r
You could try 5.5 - 6 for ride height and put a rear bar in.
Old 07-19-2010, 09:57 AM   #9340
JCarr's Avatar
Thanks, I know I wanted to try 5.5 if I wasn't there already. As i was tyoing my setting and noticed i didn't have the rear bar, I thought that would be something to try also. I had taken it off before because the rear was loose, but that turned out to be different problem all together. I just never did put it back on after that. Thanks for the ideas, I will give them a go and see what happens.
Gorilla Size Racing
Old 07-19-2010, 04:29 PM   #9341
CraigM's Avatar
2.5 deg front camber is also an uncommon setting, and you didn't post any of your roll centre settings either, but that's ok. Here is the setup I've been running on med grip asphalt with excellent results, it's very similar to the setup the TRF team were running at the worlds, give it a go
Tamiya TRF416 / TRF416WE / TRF416X-craigm-20100719-sma.jpg
Old 07-20-2010, 04:54 AM   #9342
Will the we front bulk heads fit with the lipo kit upper and lower decks. Thanks
charl mac is offline   Reply With Quote
Old 07-20-2010, 05:02 AM   #9343
dodo's Avatar
Send a message via Yahoo to dodo
yes, it will fit
lipo lower deck will fit 416, 416WE/X
the upper deck will only fit 416X (because the rear end of 416X is different from 416WE in terms of upper deck screw holes)
dodo is offline   Reply With Quote
Old 07-20-2010, 05:49 AM   #9344
JCarr's Avatar
Thanks, 2.5 front camber is what the jaco tires seem to like. If I ren less than that it wears teh outside edge of the tire through. I have no spacers under the front bridges and now have .5mm under the rear bridges. Thanks again for the help guys, I wont get out to the track again until 7/31, but I will give these suggestions a shot and see what works for me. Thanks again.
Gorilla Size Racing
Old 07-20-2010, 07:38 AM   #9345
Thumbs up
thanks dodo.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
