Like Tree3Likes
Old 07-15-2010, 06:42 PM   #9301
Originally Posted by CraigM View Post
we really need to give the suspension mounts nicknames, any suggestions?
Front / Rear of car, and Fore(ward) / Aft within the end of the car?
For example, "place a shim under the rear foreward hinge pin mount".
-Mike
Old 07-15-2010, 07:07 PM   #9302
cheehtae's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Mugen10 View Post
This new lipo. chassis. Will it be the same 2.5mm? Will this not make the chassis stiffer and better for carpet rubber racing? I will be racing rubber on carpet so this is one car I am considering.
You need to give in BTW chassis right now is not 2.5 it's 2.25 (2.5 is an option chassis)
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 07-15-2010, 07:11 PM   #9303
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
Chi Chi I should have known that you would be sniffing around. I do want to run the non norm chassis. I like the Photon but now everyone is leaning to that chassis. So now it is the 416 and Xray for carpet season.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 07-15-2010, 08:43 PM   #9304
jonest's Avatar
He might also mean he is running anti-dive, .5mm under the front rear - we really need to give the suspension mounts nicknames, any suggestions?
If you are running anti-dive, you will get more initial steering and less mid corner. Compared to the 416X kit setup, adding 0.5mm extra under all the suspension blocks will maintain a similar balance but the car will sit much flatter through corners. If the grip is high, more corner speed will be the result, if the grip is low the car will slide around.
I normally refer them as 1,2,3,4 or you may refer them as toe 1, toe 2, or t1, t2.
jonest is offline   Reply With Quote
Old 07-15-2010, 09:21 PM   #9305
dodo's Avatar
Send a message via Yahoo to dodo
i refer to susp mounts as FF FR RF and RR
dodo is offline   Reply With Quote
Old 07-15-2010, 09:38 PM   #9306
CraigM's Avatar
Trader Rating: 34 (100%+)
also my preferred method
I now have my preorder in for the lipo conversion, like someone said on the last page 5th of august is the release date in Japan, and if buying the 201 has taught me anything its that rc champ will have it at my doorstep by the 8th
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-16-2010, 12:40 AM   #9307
Taman's Avatar
Trader Rating: 64 (100%+)
Hi guy would really appreciate an answer on the question below:
the new TRF Li-Po chassis comes with either a one way spool or without. What do you use a one way spool for? I'm driving on asphalt so not sure if I need one?
cheers
Thanks for the replies CraigM & DirtyDog
Taman is offline   Reply With Quote
Old 07-16-2010, 12:47 AM   #9308
CraigM's Avatar
I would say not, but its up to you. In slower classes some people use one ways and they can be very fast but realistically a spool will always be better in a race. The reason they do an upgrade with the one way is because with the belts flipped the kit one way won't work
Old 07-16-2010, 12:55 AM   #9309
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Default lipo chassis
There are 2 different kits available (lipo conversions - not whole kits). They are both the same, except one comes without the centre oneway pulley and front oneway diff unit.
The part numbers are:
42181 - comes with oneways
42182 - comes without oneways
All other chassis parts and mounting parts are the same. Both chassis (main deck) is 2.25mm with a 2.0mm top deck.
42181 is available now (I have had mine since Monday this week).
42182 is not yet available.
It is personal preference and track type what conversion kit to get. Most tracks and people do not use oneways (front or centre) anymore. (except racers in Japan - hence why the oneway version is available now).
HTH.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 07-16-2010, 02:13 AM   #9310
Eirik's Avatar
Err, what is the question? Put the spacers in, your car will be much improved
Erick was your testing with the high diffs on carpet or asphalt?
On asphalt only.
I dont think the high diffs are a good idea on carpet, but I will check with my source what the team ran this winter on carpet.
Eirik
Eirik is offline   Reply With Quote
Old 07-16-2010, 02:24 AM   #9311
Jim_1987's Avatar
Does the new kit come with a gear diff at the rear?
Jim_1987 is offline   Reply With Quote
Old 07-16-2010, 05:41 AM   #9312
JCarr's Avatar
Originally Posted by JCarr View Post
Thanks for the replies guys, but now I'm a little more confused. I'll have to find the post, but it said to raise the rear RC to get more steering. The problem I have is that the rear is planted and pushes when on throttle, but if I let off and let the car "set" I can get back on throttle on make the corner. I'm losing a lot of time having to slow down way early so the car "set" for the corner. Right now I have no shims under any of the susp. mounts, what result would putting the .5mm shims under the rear mounts(fr/rr) get me?
This was my question.
Originally Posted by artwork View Post
When you put shims under your arms you are raising the roll center, and when you put shims under your camber links you are lowering the roll center...
To lower the roll center you would raise the inner camber link position and lower the front arm. You could also lower the outside camber link as well.
Lower
• More on-throttle steering.
• Car is less responsive.
• More weight transfer at front of car.
• Better on smooth, high grip tracks with long fast corners.
To raise the roll center you would lower the inner camber link and raise the front arm. You could also raise the outside camber link as well.
Higher
• Less on-throttle steering.
• Car is more responsive.
• Less weight transfer at front of car.
• Use in high grip conditions to avoid traction rolling.
• Use on tracks with quick direction changes (chicanes).
This was the reply that I got, but it was converse to the post that you, Craig M, made prior.
I was trying to figure out if putting the shims under the susp. blocks on the back of the car would get me the effect I am looking for. As for refering to the blocks I think it would easier to refer to them as f1,r2, f3, r4 going from front to rear on the car.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 07-16-2010, 05:55 AM   #9313
M-Technic's Avatar
No, Tamiya does not make a gear diff.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 07-16-2010, 06:24 PM   #9314
Johnny Wishbone's Avatar
Artworks discription is what I find as well. To put a shim under the suspension bridges front or back will loosen that end of the car, less grip.
How about calling them (from front to rear) front, mid front, mid rear, and rear, I think its pretty self explanitory.
Boy I hate this car, I have a worked over 416, not a WE or a X, I have shelved this car for about 4 months now, due to a disagreement, last week I took it out, put in a older speed control and a used up motor, proceded to turn more consistant laps and only a 10th off my best time with the car I have spent a lot more time on. They are both great cars, but my 416 is such a tease.
JCarr, what is it your trying to make the car do??
Old 07-16-2010, 08:14 PM   #9315
cheehtae's Avatar
HTH.
How much?
How about some pictures.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
