Old 07-15-2010, 10:54 AM   #9286
JCarr's Avatar
Originally Posted by CraigM View Post
do you have 1mm shims under the blocks? kit is 0.5mm. Taking them off will lower the roll centre, giving more roll/grip. The most standard setup is 0/0.5mm front, 0.5/0.5mm rear. Anything less than 0.5mm under the rear blocks causes the rear end to be too stuck
This is the post I was talking about.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 07-15-2010, 11:40 AM   #9287
kentech's Avatar
Originally Posted by Eirik View Post
kentech:
I posted a comment on your site, did you see it?
Eirik
Yeah but I've been on holiday!
No, seriously think I have lost your email so mail me at kentech at hotmail and I'll answer.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 07-15-2010, 12:54 PM   #9288
Eirik's Avatar
I bet it was a good holiday
You will hear from me tomorrow morning then.
Eirik
Eirik is offline   Reply With Quote
Old 07-15-2010, 02:30 PM   #9289
Taman's Avatar
Trader Rating: 64 (100%+)
Default front one way
Hi All,
the new TRF Li-Po chassis comes with either a one way spool or without. What do you use a one way spool for? I'm driving on asphalt so not sure if I need one?
cheers
Taman is offline   Reply With Quote
Old 07-15-2010, 02:35 PM   #9290
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
All I wanna know is when the tamiya lipo chassis will be available without the oneway, in a place that can get it to my american doorstep.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 07-15-2010, 02:41 PM   #9291
Skitee's Avatar
It's scheduled for release between Aug 5th and Aug 8th in Japan, with EMS shipping you could probably have it at your doorstep by Aug 13th.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 07-15-2010, 02:42 PM   #9292
Old 07-15-2010, 03:30 PM   #9293
CraigM's Avatar
Trader Rating: 34 (100%+)
Err, what is the question? Put the spacers in, your car will be much improved
Erick was your testing with the high diffs on carpet or asphalt?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-15-2010, 04:57 PM   #9294
sonic31's Avatar
question: running the front rear arm mount higher than the front will give me more or less steering? and also stock setting is no spacers in the front and .5mm spacer in rear under arm mount, i added a .5mm spacer in the front and put a total of 1mm in the rear, how will the car handle with the higher arm mount?
thanks for any info
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 07-15-2010, 05:16 PM   #9295
M-Technic's Avatar
Trader Rating: 15 (100%+)
thanks for any info
Carlos, if you raise only the front rear arm mount it will give you anti-squat, which will give you more onpower steering. If you continue to raise both front rear and rear rear arm mounts it will raise the rear roll center, which will free up the rear end and give you more steering overall.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 07-15-2010, 06:08 PM   #9296
CraigM's Avatar
He might also mean he is running anti-dive, .5mm under the front rear - we really need to give the suspension mounts nicknames, any suggestions?
If you are running anti-dive, you will get more initial steering and less mid corner. Compared to the 416X kit setup, adding 0.5mm extra under all the suspension blocks will maintain a similar balance but the car will sit much flatter through corners. If the grip is high, more corner speed will be the result, if the grip is low the car will slide around.
Old 07-15-2010, 06:19 PM   #9297
fat500's Avatar
Trader Rating: 29 (100%+)
ok good tip Thanks CCCCCCCCCCCCCCCCCCC
fat500 is offline   Reply With Quote
Old 07-15-2010, 06:20 PM   #9298
sonic31's Avatar
thanks TJ, thanks Craig... i kinda know what those settings do but i noticed a long time ago that each car seems to react differently to these adjustments so iwanted to get other 416 owners opinions. TJ are you going to run rcgt or just touring?
Old 07-15-2010, 06:22 PM   #9299
sonic31's Avatar
listen to me fat500, you will be destroyed on saturday
look at my signature, it says 416x!!! you have a low level ta05v.2 destruction is inevitable... biatch
Old 07-15-2010, 06:34 PM   #9300
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
This new lipo. chassis. Will it be the same 2.5mm? Will this not make the chassis stiffer and better for carpet rubber racing? I will be racing rubber on carpet so this is one car I am considering.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
