Old 01-06-2008, 03:58 PM   #916
OleC's Avatar
How many of you guys are going to the DHI Cup in Denmark?
I'm really looking forward to participate in this race again
I know I've never been more confident with my car before going to a big race
I have built a spool for my 416 but havent had time to test it. So I'll start out with the base setup.
Weighted the car today. 1335g with transponder Now, where to place those pieces of lead.....
OleC is offline   Reply With Quote
Old 01-06-2008, 04:29 PM   #917
miccal's Avatar
Trader Rating: 23 (100%+)
Originally Posted by miccal View Post
I have edited the TRF416 setup sheet and attached it as a png, since the pdf is too large to attach on rctech. If anyone wants the pdf, you can PM me your email.
I played with the setup sheet some more. I looked at the setup sheets for other cars such as the Cyclone and Xray and added some more things. Again, it is attached it as a png, since the pdf is too large to attach on rctech. If anyone wants the pdf, you can PM me your email.
miccal is offline   Reply With Quote
Old 01-07-2008, 01:09 AM   #918
Great work on the setup sheet! The only thing that is missing in my opinion is shock rebound in percent just like on HB and xray sheets. This is far more important than spring collar.
Mr_Orange is offline   Reply With Quote
Old 01-07-2008, 01:36 AM   #919
miccal's Avatar
I saw that on the Xray sheet (not on a cyclone sheet, though), but I am not sure what it is a measure of. Can you explain it to me?
Old 01-07-2008, 02:05 AM   #920
Shock rebound is the amount that the shock shaft rebounds back when fully pushed in. The percent is of the full travel of the shock. An example of how it is set: lets say you want 25% rebound, push the shaft in 75% without the bladder attached and then put on the bladder and screw on the cap. Now you should have 25% of rebound.
Hope this explains it.
Old 01-07-2008, 04:33 AM   #921
fadzli's Avatar
Default set up
hi have question for set up sheet.
1. rear and front camber angle. most people write 1.5 deg. no plus or minus sign. is this for positive value?.
2. what does it means - piston 3 hole? when filling shock oil should the shaft be pulled outside 100%?
2. toe angle. only one toe angle value. is it for front or rear? still most dont wrtie minus or plus.
beginner question.
Do Not Follow Where The Path May Lead. Go Instead Where There Is No Path And Leave A Trail.
fadzli is offline   Reply With Quote
Old 01-07-2008, 04:37 AM   #922
TryHard's Avatar
Negative, always negative (top of tire leans in). Never seen a setup run positive camber.
Simply the number of holes in the shock piston (i.e. Tamiya also make 2 hole ones)
3. toe angle. only one toe angle value. is it for front or rear? still most dont wrtie minus or plus.
Toe angle is for the front, set by the steering links. The suspension blocks and rear hubs set the rear toe-in. I run 0deg so no is needed...
HiH
Ed
TryHard is online now   Reply With Quote
Old 01-07-2008, 04:51 AM   #923
TryHard's Avatar
So reporting back on my racing yesterday....
Car felt good all day. Started out on with effectively kit setup, bar short arms. First run was good, car handling nicely, but seemed a little too stiff for the track conditions. Still snapping a little on some corners too.
Second run I changed to Tam White/Tam Blue F/R spings, with only a soft bar on the front. This combo felt a little softer (car seemed to be rolling a little more), but improved the feel and lap time, so stuck with that for the rest of the day.
Next run... not entirely sure about this one, as when I got back to the pits, I discovered I had knackered one of the front driveshafts, snapping one pin hole in the axle, and twisting the alloy dogbone. So took them out and put in 46mm steel ones from the 415. They fit, just, even with the kit blocks (B/A) and short arms... had to remove the o-ring from the outdrive first though.
I had made a change to the rear end with more rear toe-in (up to 2.5deg), and 1mm under the inner rear link. Not sure I can consider that run given I was 3WD for most of it :s
4th run, Up to 3deg rear toe-in now, and laid the rear shocks in. Certainly an improvement again... car seemed more stable on the rear end, but not at the expense of good front end response. Still having an issue with snap mid corner.
5th run. Decided to try a change to the front-end width, so went to C/B (used an old 415 block for C, and the 416 one for the B to clear the belt). Now, I would really liked to have tried C/C (losing the arm sweep), but didn't have an old 415 block modded to make it work properly with me... although as it turns out didn't really matter. Clipped the inside of the flat out sweeper about 1min30 in, and that bounced me out to a nice roll of tyres... cue a DNF due to a broken front C-Hub (annoyingly the only part I don't have a spare for yet... ). From the short time on track, the car did feel better again, more settled on the front, and almost eliminated the snap mid corner.
So end of the day, but overall a good positive feeling with the car. I think for next weekend I'm going to switch back to the stock spring / roll bar setup, as I'll be on a much bigger track, with a load more grip, so corner speed will be key (especially as I'll be running stock rather than 10.5 too).
Other things I want to try also are C/C and B/B on the front, and a longer front link. Hopefully that will settle the front a little even more, and make it fully stable mid corner. Other than that, I'm leaving as is for now
Cheers
Ed
Old 01-07-2008, 05:32 AM   #924
beginner question.
Beginner answers
Arn0 is offline   Reply With Quote
Old 01-07-2008, 05:56 AM   #925
Fastforward's Avatar
Ed-
Do you think the issue with snappieness is arm sweep or front track width? I am not sure that I understand the effect of arm sweep, can someone please explain.
Bob
Fastforward is offline   Reply With Quote
Old 01-07-2008, 06:16 AM   #926
C van der Hagen's Avatar
Default 19T Set-up
My 19T setup, carpet, 5 cell, rubber tires
C van der Hagen is offline   Reply With Quote
Old 01-07-2008, 06:18 AM   #927
Default 3,5 BL set-up
3,5 BL set-up, 5 cell, rubber tyres
Old 01-07-2008, 06:29 AM   #928
fadzli's Avatar
Default help
when i accelerate (high throttle) the back side move/ slide to side. is it because of tyre alignment or diff?
Old 01-07-2008, 06:31 AM   #929
fadzli's Avatar
Default help
when i accelerate (high throttle) the back side move/ slide to side. is it because of tyre alignment or diff slip? how tight should be the diff ?
Old 01-07-2008, 06:37 AM   #930
fadzli's Avatar
Default help
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
