Old 07-05-2010, 03:45 PM   #9211
cheehtae's Avatar
Trader Rating: 15 (100%+)
What kind of spring is Marc usiing , look at the picture from the previous post.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 07-05-2010, 04:11 PM   #9212
fat500's Avatar
Trader Rating: 23 (100%+)
what do the 1mm shims under the suspension blocks do?
I have 1mm all the way around the car. Should I take them off? what kind of difference can I expect? thanks.
fat500 is offline   Reply With Quote
Old 07-05-2010, 04:26 PM   #9213
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by cheehtae View Post
Will do, currently I'm running HPI gold in the front and silver in the rear.
Good deal. ALWAYS try simple adjustments first. Droop & springs changes are simple. Its hard to give a quick fix for these things simply because the rest of your set-up isn't known.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-05-2010, 05:23 PM   #9214
CraigM's Avatar
Trader Rating: 34 (100%+)
HPI Silver
do you have 1mm shims under the blocks? kit is 0.5mm. Taking them off will lower the roll centre, giving more roll/grip. The most standard setup is 0/0.5mm front, 0.5/0.5mm rear. Anything less than 0.5mm under the rear blocks causes the rear end to be too stuck
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-05-2010, 06:13 PM   #9215
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Spec-r Geardiff anyone ??
Give the best while u can !
kschu is offline   Reply With Quote
Old 07-05-2010, 06:32 PM   #9216
bigkoitat2's Avatar
Trader Rating: 1 (67%+)
[QUOTE=sidecarphil1;7623782]yeah you can see the shims on this picture of Marc's car
I just noticed the front body moutnting post coming off of the shock tower.
JAWDESIGNS.COM
R/C Driver.com
Parma/Faskolor
Randy Caster Revealed
bigkoitat2 is offline   Reply With Quote
Old 07-05-2010, 08:24 PM   #9217
ark
The question is: what oil does the WC like to run in his diff
ark is offline   Reply With Quote
Old 07-06-2010, 04:24 AM   #9218
Default 416x Lipo chassis.
Does anyone know when it goes on sale and who will be stocking it first? Very keen on one.
Bumpy is offline   Reply With Quote
Old 07-06-2010, 05:18 AM   #9219
CraigM's Avatar
Some time this month. RC Champ is your best bet
Old 07-06-2010, 11:11 AM   #9220
sakaguchinet's Avatar
Send a message via ICQ to sakaguchinet Send a message via AIM to sakaguchinet Send a message via Skype™ to sakaguchinet
Hello,
back from the worlds. Without any practise on the track it was unable for me to feel competitive. But my car was still good (best laptime 12.7).
We used Diffoil#1000 from Kyosho (mine was from Tamiya).
Here is a pic of my car:
Best Regards,
Dai
http://www.rc-square.de (German and English manufacturers site)
http://www.sakaguchinetshop.com (Tamiya TRF related stuff)
sakaguchinet is offline   Reply With Quote
Old 07-06-2010, 02:58 PM   #9221
Ultraspeed84's Avatar
Trader Rating: 44 (100%+)
i need help with gearing. Im bout to go to memphis and run the beat the heat race and need to know what pinion gear to run in 17.5? im new to the Elec side of racing need all help i can get. Its on the 416x and i think the straight is around 150ft... thanks in advance!
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 07-06-2010, 09:06 PM   #9222
LOSI123's Avatar
Trader Rating: 63 (100%+)
What effect does standing up the rear shocks have , or laying them down a bit, as in the hole on the rear shock tower.
LOSI123 is offline   Reply With Quote
Old 07-06-2010, 09:23 PM   #9223
geeunit1014's Avatar
It will depend on which motor and more importantly, which ESC you run, and how it is set up. Assuming it is a fully boosted ESC (Tekin, Castle, SP, etc), with the stock spur id start with a 34
Laying the shocks down will make the car transfer weight faster, more steering on entry, more on power traction. More upright shocks will be smoother on entry, and more steering on power.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 07-06-2010, 10:57 PM   #9224
sorry its the Boss 17.5 and its on a tekin RS...
yokomo yz-2
Old 07-06-2010, 11:34 PM   #9225
Like I said, I would start with a 34, check temps, and go from there. 34 is probably on the conservative side, but caution is good when feeling equipment out I would try to keep temps under 180.
Mike Gee
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
