Old 04-19-2010, 02:49 AM   #8701
Taman's Avatar
Trader Rating: 64 (100%+)
Originally Posted by LOSI123 View Post
anyone know the part number for the esc mounting plate that is an air duct as well
Hi mate, I think the part number is TA-3454480. I pm'd you as I have one for sale.
cheers
Taman is offline   Reply With Quote
Old 04-19-2010, 05:11 AM   #8702
LOSI123's Avatar
Trader Rating: 63 (100%+)
thanks, ill have a think about it.
Any one know if the 416X lower chassis plate will fit the 416WE
LOSI123 is offline   Reply With Quote
Old 04-19-2010, 05:40 AM   #8703
Ritchie T's Avatar
Exclamation
Finished mine a few days back...
Done a few meetings now and the kit setup is actually pretty good! Not sure what to change... Would like to try my Xray springs because i think its a touch soft, only the plastic things that hold them on at the bottom are too small. Can you buy bigger ones?
Which things should i be looking to adjust that make the biggest changes?
Ritchie T is offline   Reply With Quote
Old 04-19-2010, 07:51 AM   #8704
Trader Rating: 35 (100%+)
Originally Posted by geeunit1014 View Post
Larry,
I use an RPM Bearing Blaster. It works great at getting grease/crud out of bearings. If you find they still arent free after a cleaning, then its time to replace them
Hey Gee, you mean that thing really works??? I have seen that Bearing Blaster advertised for years, but I assumed that it was like the "As Seen On TV" products.
Do you remove the shields then clean, or just drop the bearings in and blast away?
Thanks!
Geppetto is offline   Reply With Quote
Old 04-19-2010, 08:28 AM   #8705
geeunit1014's Avatar
Thanks!
Just blast away
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 04-19-2010, 08:55 AM   #8706
John_S's Avatar
Is there anything that you think it could improve on? I personally run Jilles groskamps base outdoor setup. i am also racing on large uk outdoor tracks. the only thing i have changed is i run hpi blue and silver springs and my rear link is on the inside hole on the rear hub as my local track is quite bumpy. Other than that its fairly awesome.
John_S is offline   Reply With Quote
Old 04-19-2010, 11:01 AM   #8707
dodo's Avatar
Send a message via Yahoo to dodo
yes it will fit, 416X lower chassis is backward compatible with 416 and 416WE
dodo is offline   Reply With Quote
Old 04-19-2010, 02:51 PM   #8708
LOSI123's Avatar
Thanks man
Old 04-19-2010, 03:43 PM   #8709
RC MARKET's Avatar
Nice pics !
RC MARKET is offline   Reply With Quote
Old 04-19-2010, 07:46 PM   #8710
CraigM's Avatar
Trader Rating: 34 (100%+)
Default Setup
Hi all,
I've posted my latest 416X/10.5 set-up on Ed's site, it's from a large-ish interclub event held last weekend at my home track, which is low-to-med grip asphalt. The car was really dialed and I managed 2nd overall and fastest lap of the event.
http://www.thard.co.uk/viewtopic.php...4&p=1169#p1169
Compared to the set-up from my original 416 I am running a narrower front blocks (C/C vs D/D) and the same shock oil all around rather than 500/400. When I tried my old set-up on the X it understeered terribly, so the changes they have made to increase rear traction have obviously worked
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 04-19-2010, 10:24 PM   #8711
Stein Tumert's Avatar
Yes, and that combination works very well. That is what we are running now.
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 04-20-2010, 03:36 AM   #8712
LOSI123's Avatar
So every thing else off the WE will fit ok then?
Also this will move the battery back a bit is this correct?
Old 04-20-2010, 04:51 AM   #8713
Ritchie T's Avatar
Exclamation
Not too sure, ive ran on 2 different carpet tracks so far and it was a touch skittish on the back to start with so i took the rear roll bar off and it was pretty good! Do the HPI springs work with the standard kit parts? Becuase as i said earlier (which no one answered ) the Xray springs wont fit
Originally Posted by RC MARKET View Post
Nice pics !
Thanks! My spares came by the way thank you
Old 04-20-2010, 05:03 AM   #8714
Send a message via MSN to Bigger Brother
[QUOTE=Ritchie T;7295336] Do the HPI springs work with the standard kit parts? Becuase as i said earlier (which no one answered ) the Xray springs wont fit
[QUOTE]
Yep the HPI springs fit fine. They are slightly larger than the Tamiya springs so may look a little loose, but the majority of people are running them with all the standard parts and no issues at all.
Never tried Xray springs, and don't really intend to - 99.9999% of the time its Tamiya springs on Carpet and HPI springs on tarmac.
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 04-20-2010, 05:14 AM   #8715
Default Set up ??????
Would anybody happen to have a food starting set-up for a 416 we for a small-medium track with low traction. I am running rubber tires.
Front toe?
Front droop?
Front camber?
Front ride height?
Rear camber?
Rear droop?
Rear ride height?
Need opinions?
HoboShop is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
