Old 04-16-2010, 06:13 AM   #8686
myan_gsr's Avatar
Don't know if this is dumb question but what would the advantage of a gear diff be over a ball diff?
---Tamiya 416X---Tamiya TRF416WE---Tamiya TA05R---Tamiya F104 Pro ---Tamiya F103R 15th Anniversary ---Tamiya F103---Tamiya F103GT---Tamiya TL01---
www.brccc.org
myan racing (coming soon)
myan_gsr is offline   Reply With Quote
Old 04-16-2010, 06:37 AM   #8687
geeunit1014's Avatar
If its good, the advantage would be you could go forever between rebuilds, and that would be just changing fluid, instead of replacing rings & balls. Also dont have to worry about break in, and a gear diff shouldnt ever slip.
Downside is you lose external adjustability, and it weighs a bit more than a ball diff
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 04-16-2010, 06:43 AM   #8688
myan_gsr's Avatar
Thanks for the reply. Are there any off/on power differences in traction ( Basically will it turn differently )
Again sorry if i sound stupid but my experience with gear diffs is rather non existent, last time i used one was on my TL01
EDIT: Just clicked that you can use different gear oils would give the similar effect of tightening/loostening the diff.
www.brccc.org
Old 04-16-2010, 07:44 AM   #8689
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 04-16-2010, 10:14 AM   #8690
TryHard's Avatar
Originally Posted by Senna Racing View Post
Hopr you get your site back up and without
any loss of data
As it is a great source of information
Sites all back up, and thankfully no info lost
(And yes, I've already made a backup!)
Old 04-18-2010, 12:50 PM   #8691
Trader Rating: 35 (100%+)
Default Cleaning Bearings
Can anyone assist me with cleaning my bearings. How should I go about cleaning the bearings in my 416X? If it's necessary to take the bearing apart, how is it done? I have tried to remove the metal shields on some bearings with mixed success. Typically, I can get them apart, but not back together.
Geppetto is offline   Reply With Quote
Old 04-18-2010, 04:23 PM   #8692
LOSI123's Avatar
Trader Rating: 63 (100%+)
I was wanting to know what the max height is for a li-po to fit in the 416WE or X are they the same?
Does anyone know if a IP 5600 50C With Corraly plugs will fit in the WE or X, with out any mods?
LOSI123 is offline   Reply With Quote
Old 04-18-2010, 04:58 PM   #8693
I use an IP 5600 and I don't think that it will fit under the upper chassis plate. I have my LiPo packs off-set on the chassis so it doesn't need to fit under the upper plate. Having it off-set also help with chassis balance.
Old 04-18-2010, 06:10 PM   #8694
LOSI123's Avatar
will the ip 5000 fit???
Also are there any li-po trays that also protect the li-po that fit the WE.
Old 04-18-2010, 06:33 PM   #8695
CraigM's Avatar
Trader Rating: 34 (100%+)
5000s fit without issue, if mounting them under the top deck you need to make an L shaped plug but that's pretty simple, otherwise you can do what many of us do and just mount them offset a bit. 5600s also fit under the top deck but only by the width of a piece of paper. There are heaps of lipo trays around, e.g. demon, bitty design
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 04-18-2010, 06:46 PM   #8696
LOSI123's Avatar
thanks guys
Old 04-18-2010, 08:03 PM   #8697
Larry,
I use an RPM Bearing Blaster. It works great at getting grease/crud out of bearings. If you find they still arent free after a cleaning, then its time to replace them
Mike Gee
Old 04-18-2010, 09:43 PM   #8698
mikus's Avatar
Exotek makes an awesome chassis kit that secures the lipo, offsets the lipo for better balance,narower for less chassis side scrub and cures the topdeck battery interferrence issue.
ATHERTON RACING
RUBY RACING MOTORS
ROADRUNNERSRC.COM
mikus is offline   Reply With Quote
Old 04-19-2010, 01:52 AM   #8699
LOSI123's Avatar
anyone know the part number for the esc mounting plate that is an air duct as well
Old 04-19-2010, 02:47 AM   #8700
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
This is it: 3454480
I've got a spare one...
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
