Old 04-07-2010, 11:40 PM   #8656
Originally Posted by syndr0me View Post
I found the Exotek chassis much too stuck on medium-grip carpet. The car was very planted, and I struggled to free it up. Lap times suffered as a result. I put the 2.5mm chassis on from the original car and it was much quicker. I'm not sure the 2mm is the right choice for carpet.
That said, with the belts flipped and the car properly balanced, I definitely felt like the handling characteristics were improved.
All in all, I'm VERY glad to see companies like Exotek support Tamiya, and I hope they continue to do so. This is the chassis I would run outside or in lower traction for sure. For higher grip, I'd have liked something closer to the stock thickness, or even 2.5 to try out.
That is true, I feel the car is more planted with the exotek. I run outdoor asphalt with no track additive, so it helps to be planted. Our track also has a banked sweeper so the chassis takes some severe beatings. The narrower exotek chassis is a little less prone to dragging than the standard one.
inpuressa is offline   Reply With Quote
Old 04-08-2010, 05:40 AM   #8657
dameetz's Avatar
Originally Posted by MikeR View Post
Hi Dameetz,
I have new 25% lighter weights coming in later this week. PM me if you want to switch to these
THX, M
MikeR, PM sent...
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 04-08-2010, 07:45 AM   #8658
artwork's Avatar
Trader Rating: 56 (100%+)
Originally Posted by Taman View Post
Hi artwork, can you show a picture of your lipo setup? interested to see how you secure it.
I will try to post a picture later today
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 04-12-2010, 04:38 AM   #8659
Trader Rating: 35 (100%+)
I raced my 416X this past Saturday in Stock (17.5) for the first time and I really like this chassis. I found it relatively easy to drive and the handling was very predictable. I haven't raced a "high end" TC car in four years, and then it was with a stock brushed motor. These 17.5 brushless ESC/motors (Tekin RS) can be a real handful in terms of speed. Still getting used to that.
I expected to break steering and or suspension parts but I guess I didn't hit many boards. The only part I broke was the ball connector used on the bottom of one of the rear shocks. That was freak incident, as my car actually went airborne and end over end.
I have made a few changes:
- 46mm front swing shaft
- off-set battery mount (I cut three 2.5mm carbon fiber pieces and shoo gooed them to the chassis to secure the battery.
- ceramic diff balls
- steel ball connector bottom of all 4 shocks
The only problem I couldn't seem to resolve was the body scraping the ground in the turns and loosing body pins. My Mazdaspeed 6 body was cut so that it doesn't extend below the bottom of the chassis, but it continually scrapped the asphalt. I trimmed and trimmed the body, but I never solved the scraping problem. Seemed to only happen when turning left.
Overall, I'm very pleased with this car, and I'm glad that I didn't get an Xray.
Geppetto is offline   Reply With Quote
Old 04-12-2010, 07:43 PM   #8660
team minkya trf's Avatar
Default set up help trf 416 we
i need setup help for my 416 on a medium grip track with 10.5 running stock setup with mazdaspeed6 body
thanks
team minkya trf is offline   Reply With Quote
Old 04-13-2010, 06:53 AM   #8661
M-Technic's Avatar
Trader Rating: 15 (100%+)
I've never had a problem with lipo's fitting my stock chassis simply because I run them offset. It also allows me to balance the car left-right with less weight. I do in fact love the that Tamiya is getting aftermarket parts attention.
I've posted these before but here is my car balanced out and showing the battery position.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 04-13-2010, 12:42 PM   #8662
Taman's Avatar
Trader Rating: 64 (100%+)
how do you keep the battery secure, so it doesnt move towards the centre of the chassis etc?
Taman is offline   Reply With Quote
Old 04-13-2010, 12:49 PM   #8663
M-Technic's Avatar
I just use one piece of strapping tape. The battery has never moved before, even if the battery is flat on the bottom.
Old 04-13-2010, 01:11 PM   #8664
RC MARKET's Avatar
ok !
RC MARKET is offline   Reply With Quote
Old 04-14-2010, 08:00 AM   #8665
hacker's Avatar
Trader Rating: 140 (100%+)
Default cross joint #93500
I'm rebuilding the universals.
I can get everything but the cross joints(where grub screw threads in). Where can I get them from as I have tried all HK online shops with no luck!
hacker is offline   Reply With Quote
Old 04-14-2010, 08:56 AM   #8666
geeunit1014's Avatar
Larry,
On my MS6 bodies, after trimming the front lip on the line, I will then cut the lip in half to keep from dragging. Not sure how much you have trimmed, but that is what works for me
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 04-14-2010, 03:00 PM   #8667
CraigM's Avatar
Trader Rating: 34 (100%+)
Don't you guys know the sharpie trick??
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 04-14-2010, 03:23 PM   #8668
Johnny Wishbone's Avatar
The one with the quarter??
Old 04-14-2010, 04:00 PM   #8669
CraigM's Avatar
We don't have quarters Down Under, but I think we're talking about the same thing...
I leave cutting the bottom of the body till last, instead just cut roughly near the line, then mount it up with the roof at the correct height for the local rules. With wheels on the car and ride height set I get a sharpie and lay it flat on its side on the setup board & drag it around the the car, then cut along the line it makes. The width of the sharpie is the perfect height for the body not to drag, plus normally the sides are not 100% straight compared with lines on the body
Old 04-14-2010, 04:01 PM   #8670
CraigM's Avatar
Ed,
What has happened to thard.co.uk?
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
