Old 03-28-2010, 01:54 AM   #8566
CraigM's Avatar
Trader Rating: 34 (100%+)
Tried the smokem chassis today and I'm really impressed. I didnt seem to lose any grip due to the stiffness but the car felt nicer changing directions due to the weight being more centred. It's certainly a worthwhile upgrade
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 03-28-2010, 03:48 AM   #8567
HK416's Avatar
It will be great if you can post some pics as we can compare the positioning of weight and ESC/RX positions.
It's good to hear positive things about this option chassis.
RC FOR FUN, NOT STRESS.
HK416 is offline   Reply With Quote
Old 03-28-2010, 10:07 AM   #8568
StevenOlsen's Avatar
hi guys.
just finish last round of nationals, finished 4th today and 2nd overall. is really happy with the season . will begin to build the smokem chassis tomorrow and vil try to post some pictures in hear of how i have placed my elektronics
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 03-28-2010, 03:05 PM   #8569
TryHard's Avatar
Originally Posted by CL View Post
Does anyone know how much wider the wide arms compare to the narrow arms? (mm?)
From memory, front's are a 1.5mm wider, rears 1mm wider... so double up for overall track change..
Old 03-28-2010, 07:11 PM   #8570
Fabricio's Avatar
Send a message via MSN to Fabricio Send a message via Skype™ to Fabricio
guys what is the feeling of drive the car without those blue shims that we put on the wheel? it increases the width of the car but what is the feeling driving with it and without it?
i have made my first race with box setup and the car was really good, but now i want to start working on setup.
thanks in advance.
ARC R10 - ORCA - SANWA - EPIC
Fabricio is offline   Reply With Quote
Old 03-28-2010, 09:54 PM   #8571
HK416's Avatar
Here are my new Smokem chassis pics.
Tamiya TRF416 / TRF416WE / TRF416X-036.jpg
Tamiya TRF416 / TRF416WE / TRF416X-035.jpg
Tamiya TRF416 / TRF416WE / TRF416X-034.jpg
Tamiya TRF416 / TRF416WE / TRF416X-032.jpg
Old 03-28-2010, 10:16 PM   #8572
veecee's Avatar
HK416. Thanks for the pics. I think your fans are adding extra weight to the electronics side and is affecting the balance. But looks like you need them so not much that can be done there. I would look at doing the following to improve balance:
1) Move receiver closer to the centerline
2) Move the ESC capacitor so they run in front of or behind the ESC. It looks like you should have just enough room
3) Then move ESC capacitor and ESC closer to centerline
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 03-28-2010, 10:20 PM   #8573
HK416's Avatar
Ok, will do.What esc you're using now?
Old 03-28-2010, 10:34 PM   #8574
veecee's Avatar
I am using a Venom V2 ESC which is very similar to SP V2 ESC. I place my capacitors in front of the ESC. I'm not sure if your ORCA ESC has a bigger capacitor or not. I assume it is similar.
Old 03-28-2010, 10:44 PM   #8575
veecee's Avatar
My car is balanced with this layout and battery at the inside position. Minimum weight is 1425g so lead is added as close to the centerline as possible.
Tamiya TRF416 / TRF416WE / TRF416X-smokem1.jpg   Tamiya TRF416 / TRF416WE / TRF416X-smokem2.jpg
Old 03-29-2010, 12:10 AM   #8576
jonest's Avatar
HK 416,
Did u superglue all chassis opening (battery slots, pulley slots)? Make sure u do.
Veecee,
I've placed all my electronics towards the centreline and push the battery out a lil bit (if necessary) to balance the car and it works great. One thing for sure is that my corner speed is slightly faster compared to the ori chassis!
Cheers.
jonest is offline   Reply With Quote
Old 03-29-2010, 12:20 AM   #8577
veecee's Avatar
Agreed Jonest. I really like the feel of the chassis as well. I find it rotates better than the stock chassis without being twitchy.
Old 03-29-2010, 12:41 AM   #8578
doriftu's Avatar
can anyone share the steering links length and its corresponding toe-out angle?
Would really appreciate if someone can help cos I dont have setup system.
Thanks in advance.
six-shifter.blogspot.com
supercharged-e36.blogspot.com
doriftu is offline   Reply With Quote
Old 03-29-2010, 12:58 AM   #8579
dameetz's Avatar
I just picked up my Exotek chassis today. Reading from the instruction, the PRO TIP says not to Super Glue (CA) the chassis edges coz it can introduce chassis tweak if not properly cure. Is this correct? I have always CA'ed my chassis edges from new before I assemble the whole kit. Can anyone make any input on this matter? I like using ZAP medium cure CA glue, its a little bit thick and cures longer than the normal thin type, if this make any difference. What viscosity of CA glue do you guys always use to glue the carbon chassis edges with?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 03-29-2010, 02:29 AM   #8580
Send a message via ICQ to rcnewb2004
I am not an expert at building cars, but I don't think CA your edges will cause your chassis to tweak. All CA the edges on all my cars.
If you don't CA your edges, the edges could flake or break, i think the chances of that happening are greater than you tweaking your chassis.
Ta04-TRF, EVO 5
Futaba
KO Propo
Spintec
rcnewb2004 is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
