Old 12-30-2007, 08:47 PM   #826
syndr0me's Avatar
Trader Rating: 32 (100%+)
Also, I LOVE this car. I'm especially impressed with how well it resists tweaking (9 top deck screws!) and holds other adjustments, like camber. I couldn't be more pleased with my decision to go this route. Now I just need to give this car the driver it deserves.
syndr0me is offline   Reply With Quote
Old 12-30-2007, 10:39 PM   #827
STLNLST's Avatar
Trader Rating: 17 (100%+)
Originally Posted by dawgmeat View Post
thanks which 1 did you use...any pics
the Orion 4800 fits. You just have to evr so gently file the inside rear of the top deck in order to get your plug into the pack. The top deck covers a very small portion of the plug insert.
STLNLST is offline   Reply With Quote
Old 12-30-2007, 10:52 PM   #828
miccal's Avatar
Trader Rating: 23 (100%+)
Me too, just wish I understood setup!
miccal is offline   Reply With Quote
Old 12-31-2007, 12:17 AM   #829
syndr0me's Avatar
The foam inserts seem to give the shocks a lot of rebound. I mean, full stroke, fairly quickly the way I'm building them. What's the preferred amount of rebound on this car, in general? I'm thinking of rebuilding them so they don't rebound much to see how things feel.
Old 12-31-2007, 01:10 AM   #830
to me,shock rebound should be slow and smooth.shock rebound should be controled by the spring IMHO.
i know most people inc. me dont use anything about the diaphram.this gives minimum rebound and makes the shock smoother.By andding o-rings of different softnesses effect the rebound,,going hard gives it a fast rebound.
all i do is after bleeding the shocks i sit the black diaphram on top and push it down GENTLY all the way home,then i put the cap on,when the cap is 3/4 the way on i push the damper shaft about 1/2 way up.then pull down and sit the cap all the way home.
What that does is any excess oil u got in the cylinder lets it escape so you havent got a hard shock or a fast rebound.
when that is finshed it gives me a silky smooth shock and when the shock is fully compressed it just extends about 1/4 way out but feels real smooth.
i dunno if this is what most peope o but i have always built my shocks that way and had no problems.
i do this no matter what oil iam using or wether iam running carpet or ashphelt.
hope it helps.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 12-31-2007, 04:06 AM   #831
TryHard's Avatar
I tend to run without any of the foam inserts when running indoors... no bumps to cope with Outdoors I tend to run them, as it helps the car to stand-up quicker and helps with bump absorbtion... IMO.
Anway, some pics of my car... finally
HiH
Ed
Tamiya TRF416 / TRF416WE / TRF416X-dscf0073.jpg   Tamiya TRF416 / TRF416WE / TRF416X-dscf0075.jpg   Tamiya TRF416 / TRF416WE / TRF416X-dscf0077.jpg   Tamiya TRF416 / TRF416WE / TRF416X-dscf0080.jpg   Tamiya TRF416 / TRF416WE / TRF416X-dscf0066.jpg
Old 12-31-2007, 04:42 AM   #832
Ed, nice write up and pixs ... good read - Thanks
Andyg01 is offline   Reply With Quote
Old 12-31-2007, 06:16 AM   #833
dawgmeat's Avatar
Does the 415 front diff works on the 416 and can you use foam tires with the stock steering knuckle
dawgmeat is offline   Reply With Quote
Old 12-31-2007, 06:38 AM   #834
No but the 416 rear diff works in the front of the 416.
Rick Draper is offline   Reply With Quote
Old 12-31-2007, 07:55 AM   #835
mac853's Avatar
Originally Posted by Mr_Orange View Post
Thatīs a 415 spool with the pulley flipped over. This has been covered before and is easy to do.
Pardon , i don't understand as well: what do you mean flipped over, doesn't fit with 415 spool?
Do you take note there's a white bushing, like made with nylon, something like that, what is this?
I hope other guys could reply too...
mac853 is offline   Reply With Quote
Old 12-31-2007, 08:24 AM   #836
TryHard's Avatar
It's simply the 415 MRE spool, but with the pulley mounted the other side.
The white bushing simply looks like the delrin outdrive.
From what has been posted, it works fine in terms of fitment, but the outdrive sleaves need to be cut back by ~1mm to clear the bearing holders, OR use TA05 spool outdrives (the steel ones, with 4 slots).
HiH
Ed
Old 12-31-2007, 08:37 AM   #837
TryHard's Avatar
As above for the diff (flip the rear, the spacing on the bulkheads is the same).
As for the knuckles... heres a comparison.
First pic is the 416 knuckles, second the 415... probably enough room for some 28mm foams
Some more comparisons (just bare in mind, these were taken with the rear suspension blocks of both cars lined up)...
Third pic is the steering, obvious to see the shorter bell cranks on the 416. Also interesting to note is that the suspension blocks are further forward (circled top of pic), by ~1mm, and the steering posts themselves seem slightly further forward.
Forth pic shows motor mounting of 416 vs 415, layshaft and motor are obviously further back in the car..
Regards
Ed
Tamiya TRF416 / TRF416WE / TRF416X-dscf0081.jpg   Tamiya TRF416 / TRF416WE / TRF416X-dscf0084.jpg   Tamiya TRF416 / TRF416WE / TRF416X-dscf0095.jpg   Tamiya TRF416 / TRF416WE / TRF416X-dscf0088.jpg
Old 12-31-2007, 08:50 AM   #838
mac853's Avatar
HiH
Ed
Oh my bad, it's just a delrin outdrive.
Recommend me using MRE spool with ta05 outdrives?
Could be too with JAAD spool, this 1 fits also with Tamiya ta05 outdrives?
Best regards
Old 12-31-2007, 09:11 AM   #839
When running the 416 for the first time in a 2 day test I tried removing the foam inserts and built the dampers with much less rebound. I found that this seemed to give the car slightly more grip but more damper testing need to be done.
I also think that removing the foam changes the damping in bump (instroke) something that maybe should be considered.
moonman is offline   Reply With Quote
Old 12-31-2007, 09:34 AM   #840
HiH
Ed
I noticed that when mounting the pulley on the other side on the MRE spool it can be difficult to get the pulley centered on the spool axle.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
