Like Tree3Likes
Old 03-04-2010, 08:14 AM   #8356
94eg!'s Avatar
Trader Rating: 17 (100%+)
Originally Posted by Davzone View Post
There is no white in the pack?
I thought it will be the same as the wilky blue set but black.
Anyway it looks great!
Those are the "Short" springs for the mini chassis. Black colored version of 53333. No white spring contained:
94eg! is offline   Reply With Quote
Old 03-04-2010, 09:24 AM   #8357
Yeah, those are for the mini and they are really soft. I first used it for my TA02. Too soft for TC imo unless you are running in a really dusty track or even wet. Mainly use those for my mini.
redbones is offline   Reply With Quote
Old 03-04-2010, 09:31 AM   #8358
Anyone going to try out the new exotek lipo chassis?
http://www.exotekracing.com/EXOTEK_N.../22_416XL.html
Old 03-04-2010, 12:29 PM   #8359
sonic31's Avatar
looks really good but myself, i'll be buying the smokem chassis. i like the way that one is made, simple as far the weights i can manage. besides i dont have 30 dollars more for the exotek chassis let alone the extra 15 for the batt. strap
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 03-04-2010, 01:01 PM   #8360
94eg!'s Avatar
According to this chart floating around, they are actually stiffer than the corrosponding TC springs of the same color. That makes sense since a shorter spring of the same diameter wire will have a higher rate.
Old 03-04-2010, 02:25 PM   #8361
TryHard's Avatar
Nope, got my own being made as we speak
TryHard is online now   Reply With Quote
Old 03-04-2010, 02:41 PM   #8362
TryHard's Avatar
Actually, there's three springs sets around...
The standard ones (53440/49389/49382) are the ones we all use anyway.
The short ones are 53333, as are the new black ones...
And there are also the 53163 springs, which are the ubber soft ones included with the Pro-mod suspension (bottom three of the chart
HiH
Ed
Old 03-04-2010, 04:11 PM   #8363
tandman's Avatar
Send a message via Yahoo to tandman
Where can I get a lipo chassis asap??? Exotek or Smokem
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks Team Canada
tandman is offline   Reply With Quote
Old 03-04-2010, 04:28 PM   #8364
If you need one right now, I would pick the Exotek. Smokem is still waiting for the first batch that is coming soon...
www.rcpit.nl , RC dealer
www.machheemstede.nl
..................................Youtube: https://www.youtube.com/watch?v=_-Gkh2xZcQU
Modified 4 life
Govert is offline   Reply With Quote
Old 03-04-2010, 05:59 PM   #8365
veecee's Avatar
Trader Rating: 34 (100%+)
Exotek is listed as coming soon. So looks like a wait on both...
SMOKEM --- XPRESS --- HIRO SEIKO
veecee is offline   Reply With Quote
Old 03-04-2010, 06:23 PM   #8366
veecee's Avatar
Originally Posted by Mr_Orange View Post
The old suspension blocks (only A-E) for the 415 are slightly wider then newer 416 ones. The 415 blocks were designed for the old suspension (TA04) on the original 415 which uses ~50mm suspension shafts. This was later changed to 46mm shafts with slightly more toe in the rear as result. This was corrected with the new blocks. As comparsion on 46mm shafts: XA-old E = 3.2 degrees, XA-new E = 3 degrees.
That makes a lot of sense. Thanks for the explanation.
Old 03-04-2010, 06:34 PM   #8367
veecee's Avatar
Redbone is right. The 53333 spring set is very soft. I too still have them from the TA02 days and they are way softer than any current touring springs. Their wire diameters are quite small so they are probably the ProMod springs from that chart.
Old 03-04-2010, 08:02 PM   #8368
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Has anyone documented the range of gearing that will fit in the standard 416X chassis?
ie: a 50 spur won't mesh with a 19 pinion (as an extreme example)
48P and 64P data would be helpful.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is online now   Reply With Quote
Old 03-05-2010, 01:46 AM   #8369
CraigM's Avatar
Phil,
I don't know that anyone has done anything formal on min/max gearing, but I know at about 80t the clearance is starting to get a bit marginal for spur gears in 48dp
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 03-05-2010, 02:02 AM   #8370
dodo's Avatar
Send a message via Yahoo to dodo
any news on price, Ed?
dodo is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
