Like Tree3Likes
Old 03-02-2010, 10:11 AM   #8326
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
Originally Posted by Hebiki View Post
PRIME TIME running the blue!
whats that famous quote.. " once you go Tamiya Blue there Aint no going Back"
Prime Time AKA HollyWood..
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is online now   Reply With Quote
Old 03-02-2010, 10:14 AM   #8327
Hebiki's Avatar
Trader Rating: 26 (100%+)
we'll see how long PrimeTime stays
Sean.. we gonna see you at the tamiya track more often now?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 03-02-2010, 10:49 AM   #8328
Trader Rating: 17 (100%+)
Originally Posted by Geppetto View Post
Hi Sean. Thanks for joining RCTech, and offering your help to the mortals.
I saw your profile on the Tamiya USA website here:
While I don't have any "technical" questions, yet, I would like to know how you became a team driver? Did Tamiya approach you, or do you submit a resume?
I'm not looking to become a team driver (I'm not anywhere near good enough), just curious as to how it happens.
Geppetto - I submitted my resume! As you have to do that with any other Team. But of course winning some races and or making yourself recognizable helps. Carry yourself well and speak well, I believe that counts just as much as being able to get around the track quickly.
SANWA / TEAM ORION / PRO-LINE / PRO-SPEC / P1 BRAND / PROTOFORM / ACTIVRC
I'm not a Business man, but I'm the Bizzness man!!!
Sean Williams is offline   Reply With Quote
Old 03-02-2010, 10:50 AM   #8329
J - You got that right!
Old 03-02-2010, 10:51 AM   #8330
Yes Sir!
Old 03-02-2010, 12:45 PM   #8331
Trader Rating: 47 (100%+)
Thanks Sean for all your help via pm, can't wait to get that new 416X.....
jakeg1999 is offline   Reply With Quote
Old 03-02-2010, 01:31 PM   #8332
Awesome......let me know if you need any help ok! Happy Building!
Old 03-02-2010, 01:35 PM   #8333
Originally Posted by Bigger Brother View Post
For Carpet, a good starting point would be go to Ed's site (www.thard.co.uk) and use Elliott Harper's setup from Carpet Wars - it's on Sorex 28's but should be a good place to start from.
As for asphalt, I think most are still tending to start with the Worlds' setup, but with softer shock oil to suit your local temperatures.
Hope that helps
Oli
Hello,
thank you so much for help, I'll try carpet setup at end of the month during the Italian championship. Unfortunately it's seems impossible to find white spring out there.
I'll give you a feedback after the race. I'm not an expert because it only the third time I'm use a touring car and Tamiya too but I love it :-)
thanks
lynx75 is offline   Reply With Quote
Old 03-02-2010, 01:39 PM   #8334
Will do Sean, thanks for your help....it's paid for and on it's way....just need to find tires, and a Tekin RS....woohoo...
Old 03-02-2010, 09:32 PM   #8335
doriftu's Avatar
Originally Posted by doriftu View Post
When testing the anti roll bar's function, the right arm has more free play and feels softer compared to left side. I have checked and everything measured equally. What could be the cause? How to have both sides have equal play and stiffness?
Also, looking at Jilles tips video, he advised to use 0.75mm shim at the suspension block shafts. Where to get that 0.75mm shim/spacer?
Thanks!
hi guys,
i posted the above 2 pages back... hope to get some help...
thanks!
six-shifter.blogspot.com
supercharged-e36.blogspot.com
doriftu is offline   Reply With Quote
Old 03-02-2010, 09:35 PM   #8336
geeunit1014's Avatar
hi guys,
thanks!
Check that the set screws in the mounts on the bulkheads are tightened equally. If its not that, and everything else measures the same, the bar is probably tweaked (need a new one)
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 03-02-2010, 11:13 PM   #8337
Trader Rating: 31 (100%+)
Don't worry about the sway bar links being equal lengths. Most of the time the swaybar is bent and so you need to play with link lengths to get equal up play/travel.
ittjv is offline   Reply With Quote
Old 03-02-2010, 11:22 PM   #8338
Stein Tumert's Avatar
Originally Posted by lynx75 View Post
Hello,
thanks
Here is Tamiya springs in stock
http://www.planet-rc.ch/product_info...et-Onroad.html
Use Blue (rear) and White (front) on carpet.
If you go outside on asphalt, try the blue, sliver and gold HPI springs...
http://www.planet-rc.ch/product_info...--7-Paar-.html
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 03-03-2010, 12:42 AM   #8339
TryHard's Avatar
Indeed, have a look at sway bar setup thread on my site, as I ran through a method to use
Basically you need to adjust the link lengths. Best way I find of doing this is to set your droop to something like 6 or 5 on a gauge, then slide the same gauge under the arm and see at what value the arm lifts. Note the value, and do the same for the other side (and they will no doubt be different), and then adjust the links as per the guide to make it equal.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 03-03-2010, 02:07 AM   #8340
CraigM's Avatar
Trader Rating: 34 (100%+)
I like to drop the shocks off then hold one arm all the way and check the play on the other, then change sides. It's pretty easy to get them feeling the same, they'll never be 100% perfect anyway
rcmarket has 0.75mm HPI shims, you can get them in all sorts of colours too
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
