Like Tree3Likes
Old 03-01-2010, 08:06 PM   #8311
Johnny Wishbone's Avatar
Originally Posted by dodo View Post
has anyone tried the 2 joints (Xray ECS style) front axles-swingshaft combination on the 416? there are some available from 3rd party manufacturers. i wanted to try but wondering if they are necessary and how significant will they improve the handling of the car.
so any reviews/opinions will be much appreciated.
thanks
Do a search under my name, a little further back I did a write up/test of the Atomic ECSs for the Tamiya in this forum. In a nut shell, nice to have but not necessary, although if I where to do it again I'd do them in Xray as the spring steel is of better quality over the Atomics.
Old 03-01-2010, 08:10 PM   #8312
Originally Posted by artwork View Post
Here are some pics of my new 1E prototype block...So far all testing has been great!!!
Nice looking piece, I have to ask though, what is the reason for the new piece? Are you having issues with the original stock ones?
Old 03-01-2010, 08:19 PM   #8313
artwork's Avatar
Trader Rating: 62 (100%+)
been having issues with blocks twisting and bending...
I would guess that if you were to take the blocks off your car right now and check them they will not be straight.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 03-01-2010, 08:24 PM   #8314
Trader Rating: 26 (100%+)
Prototype blocks look great.
Just FYI to everyone, the Serpent S400 blocks are also interchangeable with the 416.
They are silver, but frankly, look pretty bulletproof.
Steve Boice
Sponsored by: Speedmerchant, Trinity/Revtech, Destiny, Protoform, Hobbywing USA, KO Propo, Ulti, Xenon, TQ Wire
Hyperform racing--In memory of Lino
Bigdaddyswank is offline   Reply With Quote
Old 03-01-2010, 08:53 PM   #8315
I'll have to check them out. Are you selling these items as well?
Old 03-01-2010, 10:03 PM   #8316
CraigM's Avatar
Trader Rating: 34 (100%+)
I've never bent a rear block racing outdoor on asphalt. I've bent a few front rear blocks but the split ones seem to have quelled that issue
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 03-01-2010, 10:54 PM   #8317
syndr0me's Avatar
Trader Rating: 32 (100%+)
The incident at our track that seems to bend the rear blocks is if you catch the beginning pipe leading on to the straight, it can send you into the wall with the side of your car, which bends the block almost every time. We actually have pretty forgiving barriers, but the outside pipes are secured, so it's usually the rear block that takes the beating. We both felt like something just a little more substantial would be effective, but decided to go a little overboard just in case.
Here's a pic of our track for reference.
http://www.rctech.net/forum/attachme...-1-5-2010.jpeg
syndr0me is offline   Reply With Quote
Old 03-02-2010, 12:25 AM   #8318
s13evo's Avatar
you have any extras for sale?
s13evo is offline   Reply With Quote
Old 03-02-2010, 02:16 AM   #8319
dodo's Avatar
Send a message via Yahoo to dodo
thanks... found it
Tamiya TRF416 / TRF416WE / TRF416X
i am looking at third party manufacturer branded specR,must be some HK or taiwan based. not sure how's the quality. price is not cheap as well.but am eager to try, will post more info shd i go ahead and try.
dodo is offline   Reply With Quote
Old 03-02-2010, 02:42 AM   #8320
Hi All,
any suggestions about a base setup for tamiya 416WE on a carpet and ashpalt with a 10.5T motor and sorex 36sh.
I used my trf416we only two times in two different indoor tracks, with sorex 36. I have some trouble because sometimes my car tend to reverse.
Any feedback are appreciate.
lynx75 is offline   Reply With Quote
Old 03-02-2010, 04:58 AM   #8321
Send a message via MSN to Bigger Brother
Originally Posted by lynx75 View Post
Hi All,
For Carpet, a good starting point would be go to Ed's site (www.thard.co.uk) and use Elliott Harper's setup from Carpet Wars - it's on Sorex 28's but should be a good place to start from.
As for asphalt, I think most are still tending to start with the Worlds' setup, but with softer shock oil to suit your local temperatures.
Hope that helps
Oli
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 03-02-2010, 08:26 AM   #8322
Trader Rating: 17 (100%+)
Hello eveyone My Name is Sean williams A new Team TRF/Tamiya USA Driver I have ran alot of touring car over the years and I am very excited about being a member of Tamiya USA......I can help or at least try to help anyone with any questions you may have. I hope everyone is enjoying there 416X just as much as I am.
Have a good day!
Sean Williams is offline   Reply With Quote
Old 03-02-2010, 09:01 AM   #8323
Trader Rating: 35 (100%+)
Have a good day!
Hi Sean. Thanks for joining RCTech, and offering your help to the mortals.
I saw your profile on the Tamiya USA website here: http://www.teamtrf.com/index.php/com...file/swilliams
While I don't have any "technical" questions, yet, I would like to know how you became a team driver? Did Tamiya approach you, or do you submit a resume?
I'm not looking to become a team driver (I'm not anywhere near good enough), just curious as to how it happens.
Geppetto is offline   Reply With Quote
Old 03-02-2010, 09:17 AM   #8324
artwork's Avatar
Yes, I will but not sure how many...I will post when I know for sure. I need to get more testing completed before I let them go out into the world. I don't have very many right now...but if there is interest I could get some more made.
When I first posted them I got very little response...glad to see there is some interest even if it is small.
I see this as really the only issue with the car...so if Tamiya wont fix it then I will.
If these blocks on this car we designed a little better then I think this would be the perfect car. Don't get me wrong it is still the best car available in my opinion, but not perfect. The HB blocks are great, the Serpent blocks look really string, but the Tamiya blocks are flawed in their design. the step is just too deep not leaving enough material to keep the block from twisting. The outside walls are too thin as well. These new blocks address both of those issues. They are not the sexiest blocks ever, but they are very functional and seem to work very well.
If I had enough made I would get them anodized but with the short run of prototypes I did I just cannot justify the costs of anodizing.
My plan is to develop some 1F, IC, 1D blocks as well, but unless there is interest then i wont waste my money. It costs a lot of money to have prototypes made...
I have some bigger pics up on www.projectgreenracing.com
Old 03-02-2010, 09:55 AM   #8325
Hebiki's Avatar
Have a good day!
PRIME TIME running the blue!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
