Old 02-18-2010, 11:09 AM   #8236
M-Technic's Avatar
Trader Rating: 15 (100%+)
Wanted to share a couple pictures of my electronics layout. It might help others running lipos. Our weight limit is 51oz and mine will tip the scale at 51.0 to 51.2 depending on the body I am running. It's balanced just about perfectly left to right.
Setup: JR digital servo (full size), AMB transponder, Airtronics DSSS receiver, Tekin RS, Duo2 17.5 w/ heat sink, 30mm fan behind motor, Epic 5000 40c batteries. I run the batteries offset so the bumps under the pack straddle the side of the chassis. I tape the battery in.
The only weight on the car is 1/2oz between the motor and fan, and 1oz directly behind the battery.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 02-18-2010, 12:19 PM   #8237
rajaburger's Avatar
Send a message via Yahoo to rajaburger
Default trf416x
alooo boleh join......
rajaburger is offline   Reply With Quote
Old 02-19-2010, 12:28 AM   #8238
RC MARKET's Avatar
Nice pics
RC MARKET is offline   Reply With Quote
Old 02-19-2010, 12:39 AM   #8239
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
your car is well balanced....
Give the best while u can !
kschu is offline   Reply With Quote
Old 02-19-2010, 04:44 AM   #8240
Trader Rating: 47 (100%+)
Send a message via AIM to smitty2802
you guys are dedicated to your cars...lol Noone sells there 416's...lol
but incase you didn't get the hint... anyone wunna help me out
Thanks,
-DC-
smitty2802 is offline   Reply With Quote
Old 02-19-2010, 10:10 AM   #8241
What do you guys think of this?
http://www.smokem-racing.com/416LP.html
redbones is offline   Reply With Quote
Old 02-19-2010, 11:06 AM   #8242
syndr0me's Avatar
Trader Rating: 32 (100%+)
I wish it was recessed like the other LiPo chassis so the battery could sit a little lower (better top deck clearance) and had an easy away to avoid sliding around. How are flat packs going to stay secure on that chassis?
syndr0me is offline   Reply With Quote
Old 02-19-2010, 11:28 AM   #8243
94eg!'s Avatar
Trader Rating: 17 (100%+)
Their idea was to provide two sets of tape holes that run laterally as well so you can tape your pack in both directions. Of coures you then run the risk of snagging tape at the edge of the chassis. I only see this working well if there is a recess milled into the bottom of the chassis (like the Sakura Zero), for the lateral tape strips...
I'm also wondering why it looks about 4mm thick???
94eg! is offline   Reply With Quote
Old 02-19-2010, 11:41 AM   #8244
syndr0me's Avatar
I think the thickness is probably a drop shadow, but it would be nice to know the actual thickness.
The tape thing is interesting, though using 3 pieces of tape sounds like a pain. I do think they're on the right track, though. I'd like the option of flipping the belts.
Old 02-19-2010, 11:47 AM   #8245
M-Technic's Avatar
Looks nice, I'd love for a set of the Ti axles.
Old 02-19-2010, 12:06 PM   #8246
Hebiki's Avatar
Trader Rating: 26 (100%+)
how does the bottom look?
3Racing's Sakura's chassis is dialed! they created an indent for the tape on the bottom of the chassis.
Hebiki is offline   Reply With Quote
Old 02-19-2010, 01:17 PM   #8247
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
you just like it because the Car is PINK... ( Camper)
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 02-19-2010, 01:19 PM   #8248
94eg!'s Avatar
This chassis does allow you to flip the belts. You can see the holes cut to clear the pulleys are now centered (and enlarged) to allow pulleys installed in either postiion. It's even got an extra screw hole for the servo to normal, or closer to the center. Pretty nifty. I would definitely try this if I ran a 416...
Old 02-19-2010, 02:38 PM   #8249
jonest's Avatar
That would be nice to be added to the "smokem" chassis.
jonest is offline   Reply With Quote
Old 02-19-2010, 02:52 PM   #8250
Hebiki's Avatar
pink camper.... geez.. thats rated-R. LOL
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
