Like Tree3Likes
Old 02-12-2010, 05:53 AM   #8176
KHoff7's Avatar
Originally Posted by Fabricio View Post
what pitch the car uses? is it 64 or it is a tamiya type?
need to buy some for stock race, which ones do you recomend to have?
i am going to use the orginal spur that came with the car...
Its a tamiya specific gear but it is VERY close to 64 pitch and 64 pitch pinions work with it.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 02-12-2010, 05:57 AM   #8177
Senna Racing's Avatar
You can run which ever pitch you like or is easiest for you
to get
I run 48 pitch as all the hobby shop carry it here in oz
But I just had a look and it definetly comes with 64
But not to sure it would be to much use in stock
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 02-12-2010, 06:11 AM   #8178
Fabricio's Avatar
Send a message via MSN to Fabricio Send a message via Skype™ to Fabricio
to get
Senna I have all the stuff for 48 and would like to keep it as now it is more easier, i tried all the spurs I had here and they are too big what size you recomend that would fit the car?
ARC R10 - ORCA - SANWA - EPIC
Fabricio is offline   Reply With Quote
Old 02-12-2010, 06:30 AM   #8179
What speedi and motor you running as it will help with a narrowing
a range
Also what size the track is
I'm currently running a 66/27 in 17.5 an and 75/25 in 10.5
But I'm geared for in feild and my tekin turbo takes care
of the straight
Old 02-12-2010, 06:36 AM   #8180
Fabricio's Avatar
a range
of the straight
I am going to run the 10.5 class.
Old 02-12-2010, 06:47 AM   #8181
Have a look at gearchart.com I thing it is or if you and select
car type 416 then spurs ranging from 70-80 ish and pins. From
25-35 will give you a good idea
But again will depend on track size and layout
But also speedi
More info will help
p.s speedi and motor will determin fdr
And if I can't someone will
Old 02-12-2010, 06:55 AM   #8182
Fabricio's Avatar
But also speedi
More info will help
I am going to run Speepassion combo, 10.5T morto with GT Pro esc, the software is going to be the stock, the speedpassion dealer here in Brazil is going to prepare it to me.
I will give a look at the gearchart
Old 02-12-2010, 07:02 AM   #8183
Then you should be around the havier end high 5 to mid 6s
I would think
But motor temp is aways key
Old 02-12-2010, 09:02 AM   #8184
Stein Tumert's Avatar
The 416 comes with a special Tamiya pitch, is is not 64DP, but very close so you can use 64DP pinions. Tamiya has a range with pinions for their own system...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 02-12-2010, 09:09 AM   #8185
Ya sorry .4 is it
Old 02-12-2010, 09:41 AM   #8186
Toh WL's Avatar
yeah it's 0.4 pitch..
it goes will with Yokomo 64DP pitch for my car. the ori spur is too soft and wears quick fast.
Toh WL is offline   Reply With Quote
Old 02-12-2010, 09:51 AM   #8187
94eg!'s Avatar
Trader Rating: 17 (100%+)
It's 0.4module as this is a metric standard for gears. Tamiya spurs last fine as long as your using 0.4mod pinions. I have a TA05 105T spur that's run two seasons of parking lot races in a 415MSXX, yet it's still quiet as a mouse. 64pitch is close, but not perfect, so increased wear is to be expected. If you want to use 64pitch pinions, then simply replace the spur as well... o=!=
94eg! is offline   Reply With Quote
Old 02-12-2010, 10:04 AM   #8188
Toh WL's Avatar
i do agree the ori .4 spur & pinions are indeed quiet. however with harder spurs & pinion. there are slightly a bit more noise on both gears. i use both yokomo spur & pinions. that is only after the ori pinion & spurs worn out.
one thing is better durability..
Old 02-12-2010, 11:24 AM   #8189
Does anybody know where I can buy alu steering blocks, and Alu rear hubs for the 416we in the USA.
HoboShop is offline   Reply With Quote
Old 02-12-2010, 11:51 AM   #8190
composite's Avatar
Just wanted to say hello first off to everyone since im new to this big forum. I recently purchased a trf416we and love it, I have found it to be very durable , easy to work on, and handles like a champ. I have been tuning it to my handling preferences for about a month now and i think i am quite done with my setup besides the fact that esc's brakes are very weak so i need a better esc. My one question i have today is in regards to how the back differential affects the cars handling on the turns and straight aways? For instance, if i run my Diff tighter how will my car perform? or if i run it more loose, how will it affect the car? I have it curently nice and smooth so it turns the rear on the opposite side of the tire im spinning but almost barely picking up the front tires. It will pick up the front tires barely like 1 outta 10 spins so its like normal loose i can say i dunno. Also i run on asphalt track, if that helps to know.
composite is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
