Old 02-09-2010, 04:48 AM   #8131
Toh WL's Avatar
Originally Posted by RC MARKET View Post
XRAY parts is harder than Tamiya !
yes, that's for sure..
Toh WL is offline   Reply With Quote
Old 02-09-2010, 06:15 AM   #8132
bkspeedo's Avatar
Originally Posted by Apex View Post
Why don't you ask the fast guys running the 416's for some help?
I have asked the fast guys and have made changes but it has not helped yet.
Originally Posted by CraigM View Post
It's highily unlikely that you're problem is the servo saver. If anything, the kimbrough will have less steering than the tamiya because its softer. If you tell us what surface you're running on, and what tyres then we can help you out.
Carpet 90x40 using Jack for traction compound. I'm doping the inside 1/4 of the tire about 10 minutes before running. I fact I tried not doping the front tire at all which helped a little. Tires are Jaco Blue.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 02-09-2010, 07:16 AM   #8133
syndr0me's Avatar
Trader Rating: 32 (100%+)
I've tried a bit, but to be honest, I think my car often suffers from the same issue. I've just become used to driving an aggressive car. I don't like a stuck, safe feeling car. Maybe that's a bit of Stockholm syndrome?
Brent: If you haven't already, try 1D/1D up front, and 1XA/1F in the rear. Also, I'd put all the toe blocks flat on the chassis, and run blue/yellow springs front/rear. This should be about as soft and planted as the car will be. You could also take the rear sway off, though I never like the way that feels. Then from there, work your way back up to free up the car to your liking. Honestly, I'm not really that thrilled with how my car feels on our home track, but out of town (and at the old place) is always feels phenomenal. Right now, sometimes I feel like we're barely hanging on.
syndr0me is offline   Reply With Quote
Old 02-09-2010, 11:53 AM   #8134
Johnny Wishbone's Avatar
Is Jack the only traction compound you can run? I wonder if thats causing some of the problem.
I had similar issues with my car and also thought it was the servo saver, I ended up trying another setup (Jilles snowbird) and I could not believe the difference in the car. I really didn't think I had got that far off the setup, but I guess I did, in any matter, never did change the servo saver, but the car is much better now.
One other thing to check, is to make sure that your shock pivot balls are free to rotate, they may feel okay on the bench, but they have to be free on the track or you'll get some really wild reactions out of the car that will make you scratch your head. I had a car that noone could run, almost a evil beast on the track, but now seems much better since I freed these up.
I also most recently did the belt flip conversion, on track it seems to work very nice as well. Don't know if its worth the effort, but its a nice option to have as well.
Old 02-09-2010, 01:21 PM   #8135
bkspeedo's Avatar
Thanks for all the input. I've got a lot of things to try for Thur night.
Brent Klingforth
Old 02-09-2010, 02:32 PM   #8136
Randy Caster's Avatar
Trader Rating: 46 (100%+)
When using Jack, it's also a good idea to sauce the rear tires longer than the front, maybe 20-30 mins on the rears, and 5-10 on the fronts.
To mellow the car out, and give more exit steering you can also remove shims from the ackerman ballstuds. Try going to 4mm, if that's not enough, try 3.
I started off with Jilles' LRP TCM setup from thard.co.uk and actually had to make it more aggressive. I ended up saucing about 90% of the front tires and still had no oversteer problems. Good Luck!
Old 02-09-2010, 02:54 PM   #8137
CraigM's Avatar
Trader Rating: 34 (100%+)
I'm not sure if anyone noticed but in addition to an extra 1/2mm anti-dive spacers Jilles also ran hole 1 on the rear arms at snowbirds. That's the first time I've ever seen the TRF guys run the rear arms flipped so that could solve your oversteer issues if you have not already tried it
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 02-09-2010, 03:20 PM   #8138
Trader Rating: 35 (100%+)
Question:
I cut the excerpt below from the Tamiya USA webpage. It's one of the items from the "Specs & Features" of the TRF416X Chassis Kit.
  • Front pulley features a direct coupling while the center pulley also features a direct drive setup.
Is this describing a One Way or Spool? I'm guessing it's a One Way, since I have never heard of a center Spool.
If it's a Spool, what are the parts and part numbers needed to buy and install a One Way?
Last, are the suspension arms and most other parts common between the 416, WE and X?
Thanks!
Geppetto is offline   Reply With Quote
Old 02-09-2010, 03:49 PM   #8139
CraigM's Avatar
Originally Posted by Geppetto View Post
Question:
Thanks!
it's a roundabout way of saying that it has a direct centre pulley and a spool. The original 416 came with a front 1 way, and the Japan version of the X comes with both a direct centre pulley and a centre 1 way
The arms of the original 416 are not the same as the WE/X, all the other suspension components are common across the 3 though
not sure the part number but I'm sure the question has been asked before so try search this thread
Old 02-09-2010, 03:54 PM   #8140
Stein Tumert's Avatar
Question:
Thanks!
- Spool
The 416X Japan version comes with both spool and one way
Middle one way http://www.tamiyausa.com/product/ite...oduct-id=49492
Front One way http://www.tamiyausa.com/product/ite...uct-id=3454520 http://www.tamiyausa.com/product/ite...uct-id=9444623 http://www.tamiyausa.com/product/ite...oduct-id=54023
The 416X has a number of parts which are different. If you check back on this thread you will find the parts described. Bulk heads, top deck, chassi plate.....
The 416X (and 416WE?) comes with short swing arms http://www.tamiyausa.com/product/ite...oduct-id=53928
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 02-09-2010, 04:17 PM   #8141
KHoff7's Avatar
Question:
Thanks!
If you are running 17.5 or 13.5 with the car at The C a spool wont be a bad thing. I personally am using a spool in my 416 GT1 car.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 02-09-2010, 05:21 PM   #8142
Thanks guys.
It's been a while since I have run a carbon fiber chassis car (used to have Yokomo MR4BD). I like a front 1-Way a lot. I'm a bit apprehensive about using a spool for the first time.
I don't suppose the 1-way in my TA05 IFS-R will work in the 416X?
Old 02-09-2010, 05:22 PM   #8143
I'll try to catch up with you Karl before the C-Squared race at the C. I didn't realize you ran a 416. I thought that Austin V. was the only one.
Old 02-09-2010, 05:39 PM   #8144
KHoff7's Avatar
I just started running it after Snowbirds. Getting ready for TCS now. Xray remains as the "big race" car tho.
Karl Hoffmeister
Old 02-09-2010, 07:08 PM   #8145
cheehtae's Avatar
Trader Rating: 15 (100%+)
I replaced the pin on my spec r DCJ with a titanium pin, will see how it goes.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
