Like Tree3Likes
Old 01-28-2010, 05:00 PM   #8011
Originally Posted by tandman View Post
Hey guys, just a quick update on the 416X. I won my first regional race this past weekend (since switching to Tamiya) against some pretty fast guys and must say that the X is a step above the WE. My X had wicked corner speed and very good straight line stability that made it easier for me to drive around the other guys in tight situations. I took the win in Touring Stock with the X and 3rd in Touring Superstock with WE. I was very close to Joe Glovers setup on both cars except that as traction came up I added 1mm shims under the outside camber links to keep the car from traction rolling....this change actually worked very well, and I have been experimenting with front arm sweep and ran an F-block in the front mount position to give me 1.5 degrees of arm sweep.....this worked very well in the high speed sweeping sections of the track.
Thanks.........Dwayne Flodell
Great to hear the set-up is working for you! Great job showing the Xray's the way around the track too
With guys using the HPI springs other than the silver what other spring is good to have. Are these better on asphalt or carpet. I've been using the Tamyia spring and really like them but would like to try a progressive spring out.
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 01-28-2010, 05:28 PM   #8012
Angry
Originally Posted by 190mph View Post
Can anyone tell me how many teeth that are on the folllowing belts below?
6244017 TRF416 Rear Belt
6244016 TRF416 Front Belt
54144 TRF416 WE Rear Belt
Just curious if they would be a good size to fit on the TRF415 with 36T Front and Rear pulleys and the 18T center pulley setup.
I got most of the other belt sizes of the whole TRF415 series and 416X car belts. I did order some Hot Bodies Cyclone car belts 170T front and 62T rear for this setup.
Hi
Ionly have the WE belts which are a low friction type.
In the past Tamiya low friction belts are usally 1 tooth
Shorter than the stock belts. Go figure.
Tamiya # 54143 416 low friction front belt 172 tooth 516mm long.
Tamiya # 54144 416 low friction rear belt 58 tooth 174mm long.
For your 415 with 18/36 pullies your looking for around180mm rear,
507mm front.
HB belts work OK
XRay 30-5431 High performance Kevlar front belt 169 tooth 507mm long and
XRay 30-5442 High performance Kevlar rear belt 60 tooth 180mm long are constructed with material that is very similar to the new Tamiya low friction belts
and work the treat on my 415 for years now.
Please everyone , excuse me for using the X word on a tamiya site
TBOTubed is offline   Reply With Quote
Old 01-28-2010, 05:55 PM   #8013
tandman's Avatar
Send a message via Yahoo to tandman
Thanks Joe, the Tamiya is really working well for me right now. The Xray guys did not have the corner speed to keep up....2 tenths a lap faster is quite a bit in 17.5 considering we were all running the Tekin RS esc's I have a WCICS series race in 2 weeks, I will see how it goes then and keep you posted.
Thanks...........Dwayne Flodell
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks Team Canada
tandman is offline   Reply With Quote
Old 01-28-2010, 06:47 PM   #8014
tandman's Avatar
Good news, looks like Jilles is on top of mod touring after 2 rounds at the snowbirds race
Dwayne Flodell
Team Mad Scientist
Old 01-28-2010, 07:07 PM   #8015
Goingfast's Avatar
Trader Rating: 29 (100%+)
Hey Bucko
where's my 416 set up?????? j/k
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 01-28-2010, 08:28 PM   #8016
tandman's Avatar
Settle down Franko.......I haven't typed it out yet
Dwayne Flodell
Team Mad Scientist
Old 01-28-2010, 08:56 PM   #8017
CraigM's Avatar
Trader Rating: 34 (100%+)
HPIs for asphalt, tamiyas for carpet
HPI silver and blue are all I've ever used on the 416, you might want to grab pink and maybe gold as well if you are running in super high grip
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-28-2010, 09:19 PM   #8018
Stein Tumert's Avatar
As stated above, HPI for asphalt, Tamiya for carpet.
You should get the gold, silver and blue HPI ones.
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 01-28-2010, 09:35 PM   #8019
Senna Racing's Avatar
Pink blue also work well
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 01-28-2010, 09:48 PM   #8020
artwork's Avatar
Trader Rating: 61 (100%+)
Originally Posted by kentech View Post
Coming soon...
42168 Touring Car Short Type Spring Set (Black)
TRF sticker set
http://kentech.blogs.se/
Thanks for the heads up...any pics of the springs yet?
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 01-28-2010, 09:48 PM   #8021
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by CraigM View Post
meh, I've been using them with the tamiya retainers for a couple years now and only had the retainer disappear into the spring once
prob not a bad idea if you're shock ends need replacing tho
It's more for consistency, I've never had a retainer slip into the spring, but I have gotten really inconsistent results when trying to set the tweak on my car using the stock Tamiya retainers.
Old 01-29-2010, 12:57 AM   #8022
Gonzo Racing here makes retainers especially for the HPI springs...
http://www.gonzo-racing.ch/produkte.html
Stein Tumert
Old 01-29-2010, 01:05 AM   #8023
Mr.Che's Avatar
They're too expensive .... I got 3 retainer set of HPI :-)
Mr.Che is offline   Reply With Quote
Old 01-29-2010, 04:22 AM   #8024
Thanks for the feedback fellas
Joe
Old 01-29-2010, 05:39 AM   #8025
thekthai's Avatar
Default hi bro rc
any idea to getting white colour turnbukle end @any web pls
thekthai is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
