Old 01-20-2010, 11:04 AM   #7906
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Got my 416X kit yesterday, and about 75% done with the build. I was surprised at how many changes they made to the car, a lot of small subtle things, but they all should make the car better overall.
Just awaiting my Schumacher diff grease so I can build the diff and throw the rear end together. Schumacher USA does have it in stock for any who are in need.
Old 01-20-2010, 11:08 AM   #7907
abailey21's Avatar
Trader Rating: 36 (100%+)
Yes we do
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 01-20-2010, 12:18 PM   #7908
gashuffer's Avatar
Trader Rating: 48 (100%+)
Originally Posted by inpuressa View Post
anyone use steel outdrives? My stock ones get deformed and bind the suspension movement. Heard that either the TB03 or the TA05 steel ones work. Anyone know more detail? Thanks.
Steel is the preferred choice.
T-Sal
gashuffer is offline   Reply With Quote
Old 01-20-2010, 12:20 PM   #7909
MikeR's Avatar
Trader Rating: 15 (100%+)
Building up mine too. It seems the center motor mount post does not line up with the chassis- about .3mm off. When I loosen the 2 main motor mount screws and attach only the center post screw and the rear motor mount screw then the middle hole position is off.
Can you confirm if this is happening on yours Randy?
Thx,
M
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 01-20-2010, 12:23 PM   #7910
94eg!'s Avatar
Trader Rating: 17 (100%+)
Originally Posted by Govert View Post
Edit I saw you edited your post. 0 degrees is fine..
Well, I myself haven't seen anybody using two diffs, but there are guys out there that are. Depends on track type and conditions...
Doesn't using zero toe result in an incosistent car? I was always told that zero toe allows the play in the suspension to bounce around and keep the car from tracking straight. If you run a little bit of toe-out, that will force slack in suspension to one side and allow the car to track straight and true. Personally I would start with a small amount of toe-out in the front.
At my local parking lot races, we almost all use dual diffs. The track setup is very narrow, so you spend lots of time making extremely tight 180's. A one-way works very well in these conditions, but restricts you to a single line. This doesn't allow you to defend your position.
The top guys at our races couldn't get spools to turn in enough. One of best runs a WE...
94eg! is offline   Reply With Quote
Old 01-20-2010, 12:57 PM   #7911
thanks. TA05 or the TB03 ones?
inpuressa is offline   Reply With Quote
Old 01-20-2010, 01:17 PM   #7912
artwork's Avatar
Trader Rating: 59 (100%+)
Here are the 42mm steel for the rear:
http://www.tamiyausa.com/product/ite...oduct-id=53501
Here are the 46mm steel for the front with a spool:
http://www.tamiyausa.com/product/ite...oduct-id=51092
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 01-20-2010, 01:43 PM   #7913
Thx,
M
Mine lines up perfectly, tightened everything down and my chassis lays flat on the setup board. Nothing seemed like it didn't line up right in my kit.. Try loosening the center mounting post and re-tightening it on the motor plate with everything snugged down to the chassis.
Old 01-20-2010, 02:02 PM   #7914
MikeR's Avatar
Ok I will try again. Just that it's is off left to right. Front to back is ok. Thanks- M
Old 01-20-2010, 03:11 PM   #7915
CraigM's Avatar
Trader Rating: 34 (100%+)
Do you mean outdrives or dogbones? don't use steel outdrives for the spool, you will lose steering
Look back a few pages there is a link to the site. They have them in stock.
I mean I ordered a few tubs about a month ago and so far they haven't turned up
CraigM is offline   Reply With Quote
Old 01-20-2010, 04:29 PM   #7916
Senna Racing's Avatar
Must be lost in the Xmas mass mail
Sure the will arrive so
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 01-20-2010, 05:04 PM   #7917
OK,
I can not work it out. I swapped the servo with another one that I know it working perfectly and nothing, same issue.
Tightened the rear diff up abit, nothing. Chassis is completely flatů
Could it be that I have a faulty front spool? I will try more toe out tonight...
rnd_tang is offline   Reply With Quote
Old 01-20-2010, 05:25 PM   #7918
oh that sucks. Guess I'll just order a lot of them. Wonder what mechanics are involved for the loss of steering.
Old 01-20-2010, 06:13 PM   #7919
gashuffer's Avatar
Swing shafts.
T-Sal
Old 01-20-2010, 07:23 PM   #7920
Joey4875's Avatar
Does anyone use ECSs instead of the CVDs on the X? What the next best option if the steel shafts takes away steering other then the aluminum one? One more thing whats the advantage of the 46mm over the 44mm shafts
Xray,Hudy,RC America
Joey4875 is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
