Old 01-13-2010, 07:57 AM   #7816
Toh WL's Avatar
Originally Posted by jonest View Post
Toh,
U seems like an experienced "416 breaker"
Well, I've raced the 416 for more than a year and arms are still solid!!!
Yes, I do agree that sometimes that screw could come loose so do check them occasionally.
That is how TRF can come up with improvements
Besides I got one car for bashing/racing & the other for misc testing + mods..
Back to the discussion subject, if they came out with rubber bumper & better mount. That's different keke cause eventually my wheels are protected.
Toh WL is offline   Reply With Quote
Old 01-13-2010, 08:32 AM   #7817
Who will be runing a Tamiya @ the birds ??
____________________
www.RCActionPics.com
Rojna is offline   Reply With Quote
Old 01-13-2010, 09:10 AM   #7818
Trader Rating: 45 (100%+)
Good question...Is there even a Tamiya On-Road Team in the US? Tamiya could have the TC market cornered in the US if they only got their act together like Xray. Xray has it all down from development to marketing to distribution, etc. Also, I'm not aware of any Tamiya sponsored drivers in the Mid-Atlantic region in the U.S. Are there any? Seems like all the drivers are in Cali.
Apex is offline   Reply With Quote
Old 01-13-2010, 09:15 AM   #7819
Trader Rating: 21 (100%+)
Hopefully we will be seeing a lipo chassis for the 416 in a month or 2.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 01-13-2010, 09:16 AM   #7820
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
lutka!
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 01-13-2010, 09:27 AM   #7821
94eg!'s Avatar
Trader Rating: 17 (100%+)
http://www.redrc.net/2009/12/east-co...416we-chassis/
I also like Kyosho's recent idea of swapping the belts left to right and moving the electronics inwards and the battery out. You could probably work something like this out on the standard 416 chassis with little to no effort. Simply turn the 3 drivetrain components around. Then you could move the servo, speedie and receiver in further towards the center. It should be especially easy since the servo uses a widened mounting stance to begin with. May require one custom servo mount for the outside...
94eg! is offline   Reply With Quote
Old 01-13-2010, 09:45 AM   #7822
I don't know if that chassis will provide equal flex with it all cut out.
Thanks to pops
Old 01-13-2010, 09:53 AM   #7823
Johnny Wishbone's Avatar
Because the diff and spool are in the low position you'll have to open up or notch the chassiss for clearance if you want to flip the drivetrain.
There is no TRF TC team, the best thing you can do is hawk this forum topic for information and ideas. The guys on here such as Syndrome, Try Hard, and many others are the guys that continually help out others on here, and all without any elite elusive team status. Makes one wonder why a person continues to run the product when its all privateer support with no chance of craking that egg.
Old 01-13-2010, 10:22 AM   #7824
dodo's Avatar
Send a message via Yahoo to dodo
Originally Posted by Stilo View Post
Final setup from DHI
Itīs kinda basic stuff for Sorex/LRP tires.
Things that I would have wanted to test at the event were:
-no shims in wheelhexes
-6mm under front ballstud
-C-C XA-Blocks
But too much to change and so few heats...
That setup doesnīt turn much, but it keeps the speed through corners better.
Some driver were traction rolling, but it wasnīt a problem for most of the drivers.
thanks for sharing!
just curious, you mentioned in your setup that you flipped the drivetrain hence moving the servo inwards and battery outwards.
when you do this, do you use custom servo mount or just secure the right side with servo mount and tape the servo down to the chassis?
thanks again
dodo is offline   Reply With Quote
Old 01-13-2010, 10:33 AM   #7825
syndr0me's Avatar
Trader Rating: 32 (100%+)
Maybe the US on-road market isn't big enough for Tamiya to care. TamiyaUSA seems to be spending most of its time on the off-road team. It's too bad, really, it seems like now more than ever, a lot of the country's better drivers are looking for a different ride.
As far as I'm concerned, this thread is the team.
syndr0me is offline   Reply With Quote
Old 01-13-2010, 11:08 AM   #7826
Stilo's Avatar
I use the L-shape mount and "some" shims. Idea came from a friend.
When mounting the servo with non regular mountings, it seems to be really easy to tweak the whole chassis with just screwing servo post to the chassis. Try to keep an eye on that. Also it might be better to do a new hole to the chassis and use regular post also on the outside, that way you can remove the outer hole that hangs out quite far.
I took some material off the chassis under diffs to be able to put the diffs in low position. But I usually run with Xenon tires and with those, diffs high is the best option.
Team EuroRC.com
Stilo is offline   Reply With Quote
Old 01-13-2010, 11:24 AM   #7827
jonest's Avatar
Stilo,
Noticed that ur running the cut top deck. Do you run this car @ DHI; on carpet? Tot u need to stiffen the chassis when running on carpet?
jonest is offline   Reply With Quote
Old 01-13-2010, 11:35 AM   #7828
Stilo's Avatar
Stilo,
No need for stiffening the car, i havent tested cut and non-cut top decks back to back on lower grip (in those conditions it should give more traction), but for High grip with traction rolling etc. cut top deck works better. It makes the car smoother and a lot easier to drive and reduces the risk of traction rolling. Donīt really know why, but I think it kinda eats up the momentum and makes the cars suspension and chassis to roll, not the whole car. Other teams like Xray also uses cut top deck especially on Xenon tires that have tendency to traction roll.
Team EuroRC.com
Old 01-13-2010, 02:12 PM   #7829
DS Motorsport's Avatar
Default Question about suspension blocks.
Hi,
I have a question to the Tamiya guys.
I'm currently busy with a custom project and i'm looking for some already made suspension blocks which will fit my needs.
I need a block which has centre to centre distance (for the suspension pins) of 32mm.
So if someone knows if Tamiya (or other manufacturer) has a suspension block which has that size could you let me know?.
And if so I would like to have some dimensions of the block so I can put in in Cad straight away.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 01-13-2010, 03:31 PM   #7830
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Honestly there isn't a big on-road team for the USA unfortunately. Tamiya USA's main focus has been the development and promotion of their own 801 1/8 line, so the brunt of the sponsored drivers are running that, and the traveling budget is more focused to that program as well.
Although I do run some off-road, I am mainly focused on the on-road cars. It's rare since he is the main designer for the 801's, but every now and then there is a Dave Jun sighting on the on-road track as well.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
