Old 01-01-2010, 10:44 PM   #7681
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Can anyone tell me who stocks the Jaad Racing diff seals? I have a set on my car now and they are working great, want to get some more for my X kits.
Old 01-02-2010, 12:02 AM   #7682
Stein Tumert's Avatar
See attached picture from Kentech :-)
http://kentech.blogs.se/
Tamiya TRF416 / TRF416WE / TRF416X-trf2010.jpg
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 01-02-2010, 12:14 AM   #7683
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
You can try precisionrc.com
Phil.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 01-02-2010, 10:09 AM   #7684
Raman's Avatar
Trader Rating: 54 (100%+)
Hi guys,
I have a GTB 3.5 system that I installed in the car. Novak recommends a final drive ratio of 10+. Right now the smallest pinion I have for the 105T is a 26T which puts me at 8.5.
I do have a 112T 0.4 spur (from TA04 / TRF414) and was wondering if any one has tried it and if it will fit?
Raman is offline   Reply With Quote
Old 01-03-2010, 06:10 AM   #7685
Trader Rating: 10 (92%+)
Default spurs for 17.5
Hi, I'm a off road guy about to jump into onroad, and I want to start off with the best kit, 416x.
I know nothing about roll-out, but Im going to start racing stock, which is 17.5 where I will be racing.
I need to know a few things before I place my order, as where I live I cannot get to a hobby shop, and do most of my ordering online.
What size spurs do I need?
What size pinions do I need?
48p or 64p?
sorry for the noob questions.
any help would be greatly appreciated, so I can order all in one hit.
captain stacker is offline   Reply With Quote
Old 01-03-2010, 10:03 AM   #7686
Johnny Wishbone's Avatar
48p or 64p?
Are you going to run rubber or foam? Carpet or asphalt? Which speed control will you be running? Inside on carpet most run 64p, something like 94 to 100 in increments of 2 for the spurs and anywhere from 38 to 50 for pinions, but that really depends on the size of the track, and you can probably narrow that range down. If you already have 48p from your offroad stuff that will work just as good, just not as fine FDR available. Give us some more info and we can narrow it down for you more.
Old 01-03-2010, 02:55 PM   #7687
Phil.
Never going to do business with them again.. Ordered 10 pairs of Sorex tires, received one, no reply to email or messages. When I did a chargeback on my card I got a threatening letter from them saying to cancel it.
Old 01-03-2010, 04:04 PM   #7688
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
i would like to ask, what should i do to forward the bodyshell more forward? where is the std position for a shell ??? how much i need to forward to gain extra steering ??from where to where i should measure ??
thanks
Give the best while u can !
kschu is offline   Reply With Quote
Old 01-03-2010, 06:06 PM   #7689
did bit of research, apparently at that track guys are running from 3.3-3.5 for 17.5 stock.
and the 416 has an internal ratio of 2.055 from what I looked up.
so is there anything preventing me from using a 48p, 60t spur and 35t pinion?
I know with my offroad car I cannot use 60/35 because my motor will hit the gearbox.
and you guys use kimbrough or robinson spurs with a 3/8" hole ? I have some from my offroad.
Old 01-03-2010, 08:22 PM   #7690
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
having trouble fitting my ta05 steel spool outdrives to the 416x... the outdrives seem to sit a bit farther out compared to the stock composite ones. anyone have tips on how to retrofit the steel outdrives?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 01-04-2010, 04:19 AM   #7691
no_byt_a's Avatar
try 3Racing spool Outdrive for ta05IFS (perfect fit)
no_byt_a is offline   Reply With Quote
Old 01-04-2010, 05:48 AM   #7692
Senna Racing's Avatar
It will depend on what speedi you are planning on running
cause with the new ones ppl are running 4.5 or lower
I run a tekin and I'm currently running 4.7 but with the new
sw that may go into the 5s
So go to your local track and have a look and talk to the
guys running stock most will tell ya wait there running
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 01-04-2010, 06:09 AM   #7693
maybe the 3.3-3.5 was for a normal esc.
4.5 sounds better, im running team wave, most likely a tekin by the end of the month.
Thanks for your suggestion.
I will start around 5, and work from there.
Old 01-04-2010, 06:47 AM   #7694
Ya my mate is running a teamwave and
he is around the 3.9-4.6 mark but the
3.9 is with the x12 lrp
Happy shopping
But have a look at grarchart.com
as it will give you a good idea were to start
Old 01-04-2010, 09:18 AM   #7695
hey all!
Can i use the tamiya 51344 rear belt on a 416we?
i didn't fint how many tooth it has and the we
are they the same?
Davzone is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
