Old 12-31-2009, 12:18 PM   #7666
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Chris Griffiths View Post
Links dont seem to work for me, just brings up a blank grey screen!
Thanks tho
look up part #53439 or "aw grease" on the tamiyausa site...
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-31-2009, 12:29 PM   #7667
Chris Griffiths's Avatar
and this is what he uses in the video on outside of diff plates??
Tamiya TRF 801x
Tecnopower
Futaba 4PK
Chris Griffiths is offline   Reply With Quote
Old 12-31-2009, 12:48 PM   #7668
94eg!'s Avatar
Trader Rating: 17 (100%+)
No, he was using Tamiya "Hard" Friction Damper grease (for non oil dampers). It's part Tamiya part number 53176...
The AW Grease Hebiki mentioned works quite well too.
94eg! is offline   Reply With Quote
Old 12-31-2009, 12:50 PM   #7669
Hy everyone,
What do you guys recommend for a 416we front steel shaft?
44mm will be ok?
I want to change the alu shaft to steel.
The car is stock, 1c 1c ,short arms ,spool .
C-hub and burnt motor free happy new year to every rc car driver in the world!
Davzone is offline   Reply With Quote
Old 12-31-2009, 01:00 PM   #7670
Thank you very much!!!
Tamiya TRF 801x
Tecnopower
Futaba 4PK
Old 12-31-2009, 03:11 PM   #7671
Johnny Wishbone's Avatar
Originally Posted by Davzone View Post
Hy everyone,
44mm will be ok?
44 will work but most run the 46 steel shafts.
Old 12-31-2009, 06:01 PM   #7672
tandman's Avatar
Send a message via Yahoo to tandman
Lanzer, try out Joe Glovers setup if you are still having some issues. Also I switched to the regular Mazda 6 and the 416X is really good.......hopefully it will be as dialed at the next WCICS race
Oh yeah.........Thanks Joe the setup is dialed when traction comes up
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-Rcamerica
tandman is offline   Reply With Quote
Old 01-01-2010, 06:10 AM   #7673
gashuffer's Avatar
Trader Rating: 48 (100%+)
With the 105 spur that came with the kit can I use 64 pitch pinion's They look the same because after I built up my kit, I don't know if it's the motor but when I roll the car the drivetrain seem louder than normal coming from the pinion/spur.
gashuffer is offline   Reply With Quote
Old 01-01-2010, 06:52 AM   #7674
the spur from tamiya is 0.4 and 64 pitch ist about 0.39 so it does suit...
method699 is offline   Reply With Quote
Old 01-01-2010, 09:07 AM   #7675
94eg!'s Avatar
Chris just informed me that Jilles was using a small tub of grease instead of a large tube. In that case it was probably the Hard grease from this set for mini 4WD (Tamiya part 15129). Probably the exact same stuff:
Old 01-01-2010, 09:30 AM   #7676
Cheers again!!
Tamiya TRF 801x
Tecnopower
Futaba 4PK
Old 01-01-2010, 09:31 AM   #7677
Does the 416x come as 48dp standard or 64??
Thank you
Tamiya TRF 801x
Tecnopower
Futaba 4PK
Old 01-01-2010, 09:53 AM   #7678
Thank you
think this post answers that one
sidecarphil1 is offline   Reply With Quote
Old 01-01-2010, 09:35 PM   #7679
nitro rat's Avatar
Trader Rating: 5 (86%+)
hey guys, just wondering how the 416x handles outta the box? im decideing between this and the TOP Photon. Im coming from a tc5r and havent driven either. i would like the tamiya though as i run there 1.8 offroad cars
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
nitro rat is offline   Reply With Quote
Old 01-01-2010, 09:38 PM   #7680
94eg!'s Avatar
Thank you
If you plan on using the Tamiya spur gear, it's best to get the Tamiya pinions. The pitch is 0.4 module and not exact.
Tamiya sells the 0.4 mod pinions in steel from 20T to 29T. They are called the RD pinions. Everything bigger than that is aluminum and simply called 0.4 module...
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
