Old 12-29-2009, 03:09 AM   #7636
Thanks.
How many teeth for the the rear diff pulley of 416X?
ioxqq is offline   Reply With Quote
Old 12-29-2009, 03:31 AM   #7637
dodo's Avatar
Send a message via Yahoo to dodo
Originally Posted by ioxqq View Post
Thanks.
37T
dodo is offline   Reply With Quote
Old 12-29-2009, 08:48 AM   #7638
94eg!'s Avatar
Trader Rating: 17 (100%+)
My friend is selling me his universal set from his 415. Does this universal set is the same as 416X? thanks
For the most part it won't work. Save your money...
94eg! is offline   Reply With Quote
Old 12-29-2009, 09:34 AM   #7639
jonest's Avatar
I've been using 46mm uj on the front for the past many months and since then, the spool cup is still in fine condition. There were some mentioned "chattering" and I din't know what it really was till just now.
I were testing the car "off-load" and when I turn the wheels while still on the throttle, the drive train made some funny noise, something like the motor cogging. Is that it, chattering?
jonest is offline   Reply With Quote
Old 12-29-2009, 12:52 PM   #7640
TryHard's Avatar
Yup
Old 12-29-2009, 06:28 PM   #7641
I want to know for 416x front universal. I should use:
54077 - 44mm alum swingshaft
53502 - 42mm alum swingshaft
Which one?
Old 12-29-2009, 07:02 PM   #7642
syndr0me's Avatar
Trader Rating: 32 (100%+)
If you plan to run the spool, you should probably run the 46mm steel bones. The 44's tend to break the plastic spool inserts in the slightest incident, and anything alum in the front will bend even if you talk to them with a strong voice. 51092 is the part for 46mm steel.
syndr0me is offline   Reply With Quote
Old 12-29-2009, 07:27 PM   #7643
Toh WL's Avatar
I play around with the 44mm & 46mm uj. The length obviously change when I change the suspension mounts. Just don't put the shock first. Hold the car up down slowly to see if there is knocking to the one way joints.
If there are some play, you can put an urethane bushing in between. It will help to absorb the impact.
Do check your bearings as they are one of the contributor also. A worn bearing will make uneven knocking, cracking sound on the wheel axle.
Toh WL is offline   Reply With Quote
Old 12-29-2009, 07:30 PM   #7644
Toh WL's Avatar
True also, you may need to look at suspension mounts. As they alter the distance between the UJ & spool cup.
Old 12-29-2009, 08:03 PM   #7645
jonest's Avatar
Lol! Talk to them with a strong voice.
Well does the chattering effect the handling of the car?
I just hate the sound.
Old 12-29-2009, 08:18 PM   #7646
M-Technic's Avatar
Trader Rating: 15 (100%+)
Lots of chatter will reduce your steering (mostly on-throttle).
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-29-2009, 08:40 PM   #7647
has anyone run the 416x on carpet with the kit setup on jaco blues? 17.5 or 13.5?
M3dreamin2008 is offline   Reply With Quote
Old 12-29-2009, 09:02 PM   #7648
Toh WL's Avatar
Not forgetting chatter will wear your bearings too.
Old 12-29-2009, 09:13 PM   #7649
tandman's Avatar
Send a message via Yahoo to tandman
M3, the kit setup will work but if you look back a couple pages for Joe Glovers setup, it works way better
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks
tandman is offline   Reply With Quote
Old 12-30-2009, 02:03 AM   #7650
i spoke to a team driver at my last race who had tried the ECS type universals and he said he didn't like them because he was carrying too much speed into the corners and running wide because the chatter was not slowing the car down enough
he was slower with the ECSs than he was with the normal drive shafts
and i thought the 80 euro Xray ECS's were better
sidecarphil1 is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
