Old 12-25-2007, 10:02 PM   #751
bigbutstupid's Avatar
Also, the 0.5mm shims on the suspension shaft it too big and will bind. I had to use series of 0.1 shims to get it right.
i did get the bind as well, but i used the 0.5mm shims anyway, just 5min of play around my backyard, and it will loosen after that, no binding at all, i guess just wear and tear.
bigbutstupid is offline   Reply With Quote
Old 12-25-2007, 10:37 PM   #752
syndr0me's Avatar
Trader Rating: 32 (100%+)
I bought some 4 degree chubs from multiple sources, and they're a distinctly different looking material, though the part numbers are the same. One is the graphite composite look, like the stock pieces or the arms. The other is kind of a shiny black plastic. Was there some kind of running change on the material, or is there something else going on? The parts seem to have been originally designed for the TA05-IFS.
syndr0me is offline   Reply With Quote
Old 12-25-2007, 11:46 PM   #753
JimmyMac's Avatar
I notice some shops sell the plastic chubs. You will find them cheap for around $2ish. Then they sell the carbon reinforced chubs around $4ish. Just be sure the package says reinforced. You'll also find cheap LW arm set like this too. I think they are around $7 for a full set. But they are plastic. Not the reinforced ones we normally have for like $8ish for 1 front and 1 rear. So becareful what you buy.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 12-25-2007, 11:57 PM   #754
JimmyMac's Avatar
TA05 IFS Carbon reinforced 4 CHubs 54031 $4.93ish
TA05 IFS 4 CHubs 51293 $3.40ish
TA05 IFS Suspension arm set 51297 $5.10ish
Two different part numbers.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 12-26-2007, 03:30 AM   #755
kentech's Avatar
Just posted some scans of TRF416 stuff from the Japanese RC mags on my blog. Testing at Yatabe, setup and JMRCA race tech chart...
Check my blog for all of them, just attached 2 of the 15 pages here.
http://kentech.blogs.se/
Tamiya TRF416 / TRF416WE / TRF416X-img002-500.jpg   Tamiya TRF416 / TRF416WE / TRF416X-img011-500.jpg
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 12-26-2007, 07:41 AM   #756
KoE
KoE's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to KoE
Default replacement drive shaft
anyone with access to hotbodies...would HB 44mm steel drive shaft part no. #61398 fit in the front?
Yo!
KoE is offline   Reply With Quote
Old 12-26-2007, 08:12 AM   #757
Core Creations's Avatar
Trader Rating: 94 (100%+)
Send a message via AIM to Core Creations
Yes...HB and Tamiya bones are interchangable.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 12-26-2007, 08:38 AM   #758
Trader Rating: 45 (100%+)
What rubber tires would you guys recommend starting out with for a medium to high bite CRC FastTrak Ozite carpet track?
Apex is offline   Reply With Quote
Old 12-26-2007, 08:42 AM   #759
If there isn't a spec tire rule I like Team Sorex 28 up front and 24 out back with Yokomo firm inserts. If the track is lower grip then Sorex 24 up front and 20s out back...same insert.
Old 12-26-2007, 09:04 AM   #760
KoE
KoE's Avatar
thanks CC
Yo!
Old 12-26-2007, 10:21 AM   #761
syndr0me's Avatar
Wait, the HB steel bones work? That's good news, since you can use them in the rear if you have trouble.
Old 12-26-2007, 10:34 AM   #762
KoE
KoE's Avatar
the front end will see more trouble...most of the times tho i usually keep steel front/alu rear on other setups
Yo!
Old 12-26-2007, 01:29 PM   #763
JimmyMac's Avatar
Thanks for the pics Kentech!
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 12-26-2007, 03:44 PM   #764
what are you guys using to strap the battery onto the car?
Old 12-26-2007, 03:57 PM   #765
JimmyMac's Avatar
Tape.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
