Tamiya TRF416 / TRF416WE / TRF416X
#7591
#7592
Yes !
#7594
#7595
Front
5.2mm ride height
4.5mm on inner camber link
longest link
1d front block, 1D split blocks
3 hole
hole drilled in cap for rebound
Tamiya white spring
500 muchmore shock oil
2mm of rebound
nothing above bladder
middle hole on shock tower
outermost hole on arm
stock sway bar
.5 degree of tow out
1.5 degree camber
5mm acerman
1.5mm of spacer behind front arm(wheelbase)
.5mm bumpsteer
1.5mm of uptravel(droop)
Rear
5.4mm ride height
3.5mm on inner camberlink
3mm outer
longest link
1XA, 1D blocks(2.5 degrees of rear tow)
3 hole piston
450 muchmore oil
hole drilled in cap
Tamiya Blue spring
2mm of renound
nothing above bladder3rd hole down on shock tower
outermost hole on shorter set of holes on arm
stock sway bar(ball stud on outmost hole, slightly stiifer than inner)
3mm of spacer in front of rear arm
2 degrees of camber
2mm of uptravel(droop)
.5mm shims under blocks
General
Car weight is 1425g 28g's outside of battery pack locating in the middle of the battery. 56g on inside of battery again as centerd as possible. 7g plus MRT PTX transponder in front of battery. 7g in front of motor. Dual fans behind motor.
removed screw above steering rack for more flex
I found this car doesn't need as much weight outside the battery to achieve left to right balance like the WE did(due likely to motor position obviously) nor do you have to keep it to the back of the car. I put it all as central as possible for front to rear balance which is probably 55% front-45% rear.
Used a Mazda speed 6 LW. I'm going to try the regulr Mazda as I think it will feel even better. Gearing with a 13.5 was 105/38 with Tekin RS and Trinity Duo 2
5.2mm ride height
longest link
3 hole
Tamiya white spring
2mm of rebound
stock sway bar
1.5 degree camber
5mm acerman
.5mm bumpsteer
Rear
5.4mm ride height
3mm outer
longest link
3 hole piston
450 muchmore oil
hole drilled in cap
Tamiya Blue spring
2mm of renound
2 degrees of camber
General
When you put the fans behind the motor,does the fans blow on the motor or away from the motor?
thank you
#7597
One more question,how do you connect the fan? Doesn't the lipo voltage too much for the fans?
thank you in advance
#7598
I like to wire them to the +/- on the speedo. I haven't had any failures from them getting the 7.4+ volts. They do spin faster of course but why I like it is when your done your run they stay on after you shut the car down. Helps cool everything down faster while you marshall.
#7599
what sort of volts do the fans do as i am going to do the same for my trf.
#7600
What diff grease you guys use? I used the muchmore one and my diff kept slipping. I switched back to my AE stealth duff lube, and it grabbed like how it is supposed to.
Also, do people put three extra balls into the open holes on the pulley? Read about it somewhere on the 501x forum. thanks
#7601
I like Kyosho diff grease. I've used it for years and it works great.
http://www.rckenon.com/public_html/s...oducts_id=2108
#7602
I'd suggest watching Jilles' video on diff building if you haven't already. He uses the Schumacher grease (and AE on the thrust) and details how he and the TRF team build their diffs.
http://www.youtube.com/watch?v=ZLLoRYm-QLg
+ YouTube Video | |
#7603
Got a part number or a place where I can purchase the Schumacher diff grease?
#7604
The part # U1301
http://www.speedtechrc.com/store/ebp...id=399&id=8812
http://www.the-border.com/product.ph...cat=429&page=1
http://www.racing-cars.com/products.asp?recnumber=619
#7605
I managed to track down that part number once on Schumacher USA's site and purchase it. It was such a monumental pain in the ass to find it that I bought like 5 so I wouldn't have to go through the pain again any time soon.
Edit: I just tried to find it again on their site and lost my will to live after waiting for their craptacular search to time out. Goodbye cruel world.
