Old 12-24-2009, 10:48 AM   #7576
Send a message via MSN to maxrcp
Default toe in
tks dodo
i use it ant it gives -3 in the left side and -1,5 on right
something is wrong with my car :P
tks for attention
maxrcp is offline   Reply With Quote
Old 12-24-2009, 10:53 AM   #7577
dodo's Avatar
Send a message via Yahoo to dodo
Originally Posted by maxrcp View Post
tks dodo
tks for attention
check your hingepin on the right side maybe it's bent hence giving the wrong toe angle on that side.
or check your rear upright, make sure you use 0deg...
dodo is offline   Reply With Quote
Old 12-24-2009, 11:01 AM   #7578
gashuffer's Avatar
Trader Rating: 48 (100%+)
Why does tamiya recommend the 44mm steel drive shafts in their description for the 416x? Don't they come with 44mm already?
gashuffer is offline   Reply With Quote
Old 12-24-2009, 11:07 AM   #7579
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
They have the correct "plunge" for the blocks that most people seem to run.
If you run the 42mm in the front with the c blocks, it will work, but you will have issues with the spool breaking becuase the plungs is not deep enough.
I have not tried the 46mm ones in the front, not sure if they will bottom out, and cause binding in the suspension...
If you run longer ones in the rear, you will hit the diff screw....
Originally Posted by gashuffer View Post
Why does tamiya recommend the 44mm drive shafts?
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 12-24-2009, 11:08 AM   #7580
syndr0me's Avatar
Trader Rating: 32 (100%+)
46mm steel is what you want. I believe the car comes with 44mm alum.
syndr0me is offline   Reply With Quote
Old 12-24-2009, 11:44 AM   #7581
TryHard's Avatar
tks dodo
tks for attention
Check your blocks too, if you've got a bent one, the toe will be out as well. Check em in all diretions (up/down and fore aft) by placing on a straight edge, and seeing if you can rock them/see daylight underneath.
HiH
Ed
Old 12-24-2009, 12:01 PM   #7582
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
This is my second block that I bent and I didn't even hit that hard. I was wondering if I can use TA05 V2 Separate Susp. Mnts (1C/1XC) WRONG PIC BUT THIS TYPE OF BLOCK
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 12-24-2009, 12:09 PM   #7583
dodo's Avatar
you can use the separate type blocks. check few pages back and you'll see pics of the 416X with it. 416 and 416WE can use the separate blocks too.
Old 12-24-2009, 12:12 PM   #7584
What about the shims or spacer that we use on the block
Old 12-24-2009, 12:31 PM   #7585
dodo's Avatar
i have the same question, seems that we have to simply use general spacers or the aluminium suspension arm spacers.
can anyone advise us on this
Old 12-24-2009, 12:51 PM   #7586
syndr0me's Avatar
Try longer screws in the 1pc blocks if you're having problems with them bending. Or use 2pc blocks where you can.
Anybody know if Tamiya has released slotted shims for the 2pc blocks yet?
Old 12-24-2009, 01:17 PM   #7587
Johnny Wishbone's Avatar
I use the stock shim on the inside screws and the equal thinkness washer on the outer screw. i.e. 0.5mm shim use a 0.5mm washer on outer screw, same thing for 1mm.
46mm steel on the front has no bind issues with the suspension.
Old 12-24-2009, 01:32 PM   #7588
i just used the 1mm spacers for the suspension arms
little bit of AW grease one them and they stick enough to get the screw threw
used to use 1mm rear and 0.5mm on the front block
i used the steel blocks all round 46mm front and the 44mm rear
no binding problems at all
sidecarphil1 is offline   Reply With Quote
Old 12-24-2009, 01:52 PM   #7589
I think you have got into the Xmas shooters a little to early side car, lol.
I read that your liking your new ride over the 416, good luck with it.
Old 12-24-2009, 08:45 PM   #7590
Want to know what are the part numbers for the 416X universal set? thanks a lot
ioxqq is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
