Old 12-18-2009, 10:05 AM   #7501
No those were things I moved over from the other cars.
That camera has always sucked at close ups. I used a mini tripod on the one pic
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 12-18-2009, 10:10 AM   #7502
jonest's Avatar
Originally Posted by B18C Turbo View Post
lol...well the first pic came out great, just need to steady your hands bro.
So did the kit include titanium steering tie-rods and the ESC ramp? Or did you add those?
U have to add those.
jonest is offline   Reply With Quote
Old 12-18-2009, 11:11 AM   #7503
artwork's Avatar
Trader Rating: 56 (100%+)
So I have a question for you guys about the Tamiya diffs in the 416.
I have found recently that my diffs feel pretty gritty. I am very well versed in the ways of diff builds and maintenance, but I have to say that the Tamiya diffs don't feel so great after a few runs.
What causes that gritty feeling in diffs?
I run 13.5 rubber tire inside on carpet. I use Schumacher diff grease and AE thrust grease. I am using Carbide diff balls but I have also tried ceramic as well. I sand rings with 600 grit sand paper. I break in my diff after a fresh build.
I just dont get it...when I rebuild them they feel like butter, but after only a run or two they get really bad. I know it sounds dumb, but is there a part that is usually associated with that gritty feeling in diffs.
My old Cyclone TC diffs have never felt like this after weeks of hard running. I just felt the diffs of some of my old cars that I sold to one of the locals and they still feel great.
Any ideas?
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 12-18-2009, 11:12 AM   #7504
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
I'll try to do some shots as I build the car tonight...
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 12-18-2009, 11:17 AM   #7505
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
Any ideas?
Check your thrust bearing, you might have one going bad on you. You might also want to try some diff covers to keep dust and other gunk out of the diff ball/ring area.
JamesArluck is offline   Reply With Quote
Old 12-18-2009, 11:36 AM   #7506
TryHard's Avatar
Any ideas?
As James has said, its more than likely dirt getting into the diff...the balls do sit very close to the edge of the rings, so dirt can get in easy. Diff covers will certainly help.
I'm not running covers indoors at the moment, and seem to have to re-build more often than before... having said that, I can easy tend to go 3 meetings or more before I even feel llike it needs to be re-built....
HiH
Ed
Old 12-18-2009, 12:04 PM   #7507
Stilo's Avatar
Has anyone tested these RC devil lexan diff covers?
Team EuroRC.com
Stilo is offline   Reply With Quote
Old 12-18-2009, 01:20 PM   #7508
mutley001's Avatar
Originally Posted by Stilo View Post
Yep, they 're great. Just push fit on and no more gunk. Diffs last ages between rebuilds
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 12-18-2009, 01:29 PM   #7509
Trader Rating: 68 (100%+)
Originally Posted by JoeGlover View Post
No but here are some part numbers for the different parts
left bulkhead(front)-13454690
right bulkhead(front)-13454691
motor mount bulkhead-134546787
center bulkhead-13454689
rear bulkhead(right)-13454693
" " (left)-13454692
rear belt-54207
upper deck-14004070
lower deck-14004071(not necessary if you use old front bulkheads)
layshaft bearing-42109
I don't think I'm forgetting anything
These parts are a direct fit on the original chassis?
steve eaves is offline   Reply With Quote
Old 12-18-2009, 01:31 PM   #7510
RC MARKET's Avatar
TAMIYA Japan had Manual download !
these parts around end of this month arrive !
RC MARKET is offline   Reply With Quote
Old 12-18-2009, 02:14 PM   #7511
Everything aside from the Front bulkheads are a direct fit on either the WE or original.
Joe
Old 12-18-2009, 02:36 PM   #7512
veecee's Avatar
Trader Rating: 34 (100%+)
Any ideas?
I used the have the same problem before I started using diff covers/stickers on the 415. I have had my 416 for almost 2 yrs and have rebuilt the diff maybe 3 or 4 times. Try these.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 12-18-2009, 05:04 PM   #7513
Skiddins's Avatar
Is there one particular place where you can find all the setup sheets for the 416 cars?
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-18-2009, 05:18 PM   #7514
here has some 416 setups
http://www.thard.co.uk/
rwmjd007 is offline   Reply With Quote
Old 12-18-2009, 05:56 PM   #7515
lyoha's Avatar
Originally Posted by veecee View Post
I used the have the same problem before I started using diff covers/stickers [/URL].
I wash my diff pulley, diff outdrives with soap and hard brush. I wash thrust bearing with brake cleaner. After this procedure diff working smooth. I use x-ray silicone grease for diff balls and AE black grease for thrust bearing. I make dust covers from oracal film.
Tamiya TRF-416WE - Speed Passion GT V2.0 - EPIC 10.5
BMI12RR - Sphere SSX - Vector X12 4.0
CRC Gen-X - Speed passion GT - Orion Vortex 5.5
Futaba T3VCS 2.4 FASST
lyoha is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
