Old 12-09-2009, 04:36 AM   #7396
yokemad's Avatar
it's very small tight low-med grip carpet track...
setup
40w oil f-r 50% rebound
6-5 droop (measured xray style)
1.5-2 camber
0.5-1 spacers under suspension blocks
d/d-xb/d (2.5) blocks
4mm shims for ankerman
5mm front inner camber link shims
5mm rear inner 3mm rear upright shims
Short arms
top deck cut
no alloy link in between steering posts
Yellow / red springs
front shock in the middle
rear shocks 3th hole from outside
Front spool
46-44 shafts
Both front drive shaft pins has moved out on 2 separate race
car feels so twitchy ,I have to be very gentle on steering ..
Very unpredictable lap by lap
yokemad is offline   Reply With Quote
Old 12-09-2009, 04:46 AM   #7397
veecee's Avatar
Trader Rating: 34 (100%+)
"0.5-1 spacers under suspension blocks" - can you be more specific as to which shims under which block? FF/FR and RF/RR
Also those springs are very soft if they are Tamiya springs. It's hard to generalise not having seen your track but your car may be over rotating because of the soft springs.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 12-09-2009, 05:09 AM   #7398
yokemad's Avatar
Shims under the block equal both Ff-fr ,rf-rr
0.5/0.5 on front of the car
1/1 rear of the car
springs are good point I've switched to xray 2.8-2.6 springs which we were using on same track even more grippy conditions car was better but another drive shaft pin failure ended my day
but car was defenately over rotating
and which way should I go to calm down steering
forgot to say 1 degree front toe-out! It sounds a bit too much now ...
that was from my xray setup LOL
cheers
Old 12-09-2009, 05:23 AM   #7399
veecee's Avatar
Try this link
And search for some other setup by syndr0me and TryHard. TryHard has a good 416 site with lots of setups - http://www.thard.co.uk
Old 12-09-2009, 08:34 AM   #7400
Johnny Wishbone's Avatar
setup
40w oil f-r 50% rebound TRY 30 OR 35 WITH 0 REBOUND
6-5 droop (measured xray style) TRY 2MM FRONT AND 3MM OVER RIDE HEIGHT
1.5-2 camber
d/d-xb/d (2.5) blocks TRY C/C - XA/D or E
4mm shims for ankerman TRY 5 OR 5.5
5mm rear inner 3mm rear upright shims MOST RUN 4 IN 3 OUT
Short arms
top deck cut
Yellow / red springs TRY WHITE/BLUE
Front spool
46-44 shafts
Also adjust your total steering throw and expo this will take the twitch out of the car.
Syndromes setup from Vegas is a good start but that was a bigger, high traction track.
Old 12-09-2009, 09:11 AM   #7401
yokemad's Avatar
Thanx a lot guys
Old 12-09-2009, 09:29 AM   #7402
setup
1.5-2 camber
Short arms
top deck cut
Front spool
46-44 shafts
This is the track he is talking about its very unique http://www.youtube.com/watch?v=uvtVIQ7mf5k
Burney is offline   Reply With Quote
Old 12-09-2009, 09:31 AM   #7403
syndr0me's Avatar
Trader Rating: 32 (100%+)
You might try XA/E or even XA/F in the rear. I'd also lose the shims under the rear blocks and try blue/yellow springs. Maybe some more camber all around, too. If that's too stuck, which it may be, you can start backing those changes out one at a time to find the right combination of speed and drivability.
If the car seems like it gets on the nose too much off power, don't be afraid to try a little anti-dive by sliding a .5mm shim under the front rear block.
syndr0me is offline   Reply With Quote
Old 12-09-2009, 09:45 AM   #7404
Hebiki's Avatar
Trader Rating: 26 (100%+)
holy cow... thats one tiny a$$ track.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-09-2009, 10:30 AM   #7405
our old one was smaller LOL
but it looks like there is no grip
i would ,
600 oil front
blue front springs
500 oil rear
yellow rear springs
front camber 2.0 rear 2.5
1c 1c front blocks
1xa 1f rear blocks
0.5mm spacer under front/front block
1.0mm spacer under front/rear block
no speacers under rear blocks
0.5mm wheel spacers on rear wheels hex
1mm wheel spacers on front wheels hex
0 degrees front toe , makes the car more settled
do you run any extra weight ?? if so is it front or rear ??
if it is at the rear i would move it forward , believe it or not more weight rear makes the cae rotate faster , as there is more weight to transfer
see what you think
sidecarphil1 is offline   Reply With Quote
Old 12-09-2009, 11:30 AM   #7406
yokemad's Avatar
with new sweep x1 additive we have much more grip than that...
cars 1350 grams so no extra weight but lipo pack pushed out from chassis to balance the car...
I pushed speedo(rspro) and sr3001 spectrum Rx to max forward position...
I should add more camber to the front 1.5 to 2
front toe out 1 to 0.5
firmer springs white blue or xray 2.8/2.6
how about ankerman? 4mm to 2mm is that calms down steering?
thanx again to all
Old 12-09-2009, 11:41 AM   #7407
Your track is as small and technical as ours.
I have run the xray spring combo you mention and thought it helped.
I also run the spacers under the rear bridges like you as well, it seems to help the car thru the very hard tight corners.
I prefer the lighter oil as the heavier just seem to create a push thru the high speed corners.
I would run more ackerman 5 or 5.5, I would also add 1mm spacer to the hex. The c/c front would help as well.
Hope this helps.
Old 12-09-2009, 11:45 AM   #7408
SammyZ's Avatar
Trader Rating: 138 (100%+)
that track looks so dissapointing
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 12-09-2009, 11:49 AM   #7409
You do with what you have, its better than nothing.
Ours is about the same, but its available 24/7 so you tend to put in a lot of laps.
Old 12-09-2009, 12:17 PM   #7410
SammyZ's Avatar
im gonna give you that...its better than nothing
Hotbodies USA
SweepRacing USA
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
