Old 12-01-2009, 11:29 AM   #7306
over gear's Avatar
Trader Rating: 15 (100%+)
wouldn't the shims put scratches on the shock shaft?
over gear is offline   Reply With Quote
Old 12-01-2009, 12:32 PM   #7307
dsrbltoys's Avatar
I'm guessing thats why its a 4mm shim.
dsrbltoys is offline   Reply With Quote
Old 12-02-2009, 08:24 AM   #7308
Toh WL's Avatar
Just to check with you all on the lower deck chassis. Is 416X the same as 416WE?
Toh WL is offline   Reply With Quote
Old 12-02-2009, 09:08 AM   #7309
artwork's Avatar
Trader Rating: 56 (100%+)
No
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 12-02-2009, 10:33 AM   #7310
jonest's Avatar
Toh,
416X chassis is not the same as 416WE's as the rear diff is moved 1.8mm backward but the battery position is the same as the original 416's.
But I got a confirmation from Jilles that the new motor mount could be used on our existing 416 & WE's, but we have to shave off 1mm off the lower deck (motor part).
Cheerios.
jonest is offline   Reply With Quote
Old 12-02-2009, 12:05 PM   #7311
yokemad's Avatar
I can't wait to buy that motor mount
yokemad is offline   Reply With Quote
Old 12-02-2009, 12:17 PM   #7312
94eg!'s Avatar
Trader Rating: 17 (100%+)
Originally Posted by jonest View Post
416X chassis is not the same as 416WE's as the rear diff is moved 1.8mm backward...
Does that mean you cannot use the new rear bulkheads on the older cars? That seems a little silly since they only moved the diff a tiny bit. It could have easily been changed while maintaining the same lower screw positions (especially since the suspension mounts are in the same place)...
94eg! is offline   Reply With Quote
Old 12-02-2009, 12:22 PM   #7313
1.8mm is not a tiny bit backwards
sidecarphil1 is offline   Reply With Quote
Old 12-02-2009, 12:23 PM   #7314
do you think it will make a differance , only the motor mount ??
Old 12-02-2009, 01:59 PM   #7315
veecee's Avatar
Trader Rating: 34 (100%+)
To run the new motor mount, you'll also need the new top deck. And to use that top deck, you'll also need the center shaft mount and new rear bulkheads as the 4 sets of holes at the rear are different. And as mentioned u need to shave 1mm off the motor recess. That's a lot of bits for moving the motor in 1mm...
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 12-02-2009, 02:42 PM   #7316
yokemad's Avatar
here in uk stock 13.5T weight limit down to 1350 grams,that's why I was interested in but If we have to change all those parts ...
It doesn't worth
Companies like 3R etc. Able to make that kind of part for 416 direct fit let's wait and see
Old 12-02-2009, 04:40 PM   #7317
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default First batch...
dont miss out on the first batch, preorder your 416x.... Jeff told me there's about 4 left from his first order that's arriving...
http://www.speedtechrc.com/store/ebp...id=120&id=8811
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-02-2009, 06:52 PM   #7318
Toh WL's Avatar
Toh,
Cheerios.
Jonest,
To what I did a physical check the between the 416 & the 416WE. The notable difference is the battery holes are much to the front for 416WE. Hence much of the battery weight are shifted towards the front wheels. Hence the 416 lower deck is not the same as 416WE.
When you say the battery position is the same as the original 416's. Do you mean the 416X chassis is compatible with the old 416?
I was thinking also anyone did modification for the ori 416 to 416X.
Thanks....
Old 12-02-2009, 06:52 PM   #7319
Toh WL's Avatar
Originally Posted by artwork View Post
No
Thanks man...
Old 12-02-2009, 06:54 PM   #7320
Toh WL's Avatar
Have anyone tried modifying the 416 to 416X. Looking forward for your feedback.. Thx in adv.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
