Old 11-29-2009, 07:19 PM   #7276
Randy Caster's Avatar
Trader Rating: 45 (100%+)
Sorry it's been so long since I've dropped by the thread! Been really busy the past couple months with a few projects I'm working on.
Anyway, the KO race is coming up in a couple weeks, so I decided to build a new sedan so I can be sure everything is as good as it can be. Picture is attached
Also shown in the picture are the new threaded setup wheels I designed and had made, no need for nuts to hold the wheel on, and they center perfectly every time for perfect tweak adjustment.
Tamiya TRF416 / TRF416WE / TRF416X-3.jpg
Old 11-29-2009, 09:53 PM   #7277
linger's Avatar
Hey Randy, you got a baseline setup for the KO race at WCRC?
See ya there.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 11-29-2009, 11:31 PM   #7278
Originally Posted by CraigM View Post
is that for rubber/carpet?
carpet mate rubber tyres , sorry
sidecarphil1 is offline   Reply With Quote
Old 11-30-2009, 02:05 AM   #7279
kentech's Avatar
Looking great!
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 11-30-2009, 02:21 AM   #7280
kentech's Avatar
TRF416X setup sheet
Old 11-30-2009, 02:31 AM   #7281
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
Default building 416x
hi guys,
i finished building the new 416x yesterday. building was no problem. everything fits perfectly. upper bulkheads should be raised with 0.1 or 0.2 mm shims to fit the diff excenter perfectly. cant wait to take it for a spin probably wednesday.
vitomon is offline   Reply With Quote
Old 11-30-2009, 01:02 PM   #7282
SammyZ's Avatar
Trader Rating: 138 (100%+)
i have 44mm universals in the rear and they are to long for my WE w/ short arms. It binds with the T-nut in the ball diff!
I noticed that the 42mm universals are rare and very expensive. Is there
any way around this?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 11-30-2009, 01:19 PM   #7283
Johnny Wishbone's Avatar
You can file a little bit of the pin cushion flat and file a dish or grove in the t nut " ( " that shold give you better clearance, works for me.
Old 11-30-2009, 01:24 PM   #7284
Hebiki's Avatar
Trader Rating: 26 (100%+)
curious..how narrow are you running your suspension block set up? the 416 and WE all came with 44mm universals.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 11-30-2009, 01:28 PM   #7285
Stein Tumert's Avatar
My 416 came with 44 at the rear, but my WE came with 42mm at the rear...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 11-30-2009, 01:31 PM   #7286
Hebiki's Avatar
ahh... still quite narrow if your hitting with 44mms. i would think he's running something narrower than XA... maybe XC or even XD?
Hebiki Design Works
Old 11-30-2009, 02:25 PM   #7287
kentech's Avatar
There are a few changes to the 416X upper deck other than that it's longer and with different bulk attachment holes. Attached a photo showing a WE and X upper deck side by side.
- The front cutout in front of the hole for the steering brace is slightly differently shaped (arrow shape facing forward)
- Curves a bit differently at the rear with rear "legs" narrower
- Front holes for the motor mount / right middle bulk is a bit more inside compared to the other holes whereas they were all on a line on the WE
On a side note, for a trick on preparing the carbon parts check out; http://kentech.blogs.se/ Also some good looking new Muchmore stuff there.
Tamiya TRF416 / TRF416WE / TRF416X-img_8262.jpg
Old 11-30-2009, 03:16 PM   #7288
syndr0me's Avatar
Trader Rating: 32 (100%+)
RCMARKET has a D-ring diff made by 3 Racing for the 416. It looks like the entire thing is $15.
syndr0me is offline   Reply With Quote
Old 11-30-2009, 03:23 PM   #7289
veecee's Avatar
Trader Rating: 34 (100%+)
Because the 416 had long arms and WE had short arms. I run short arms with X-E at rear with 44mm, -1 deg camber and it clears. -1.5 deg is as far as I can go with this setup without binding.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 11-30-2009, 07:22 PM   #7290
Need some help. since I cannot locate some Tamiya ball cups in my area on such short notice for a race this weekend, what other brand will fit if any? Thanks.
boyntoncyclone is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
