Like Tree3Likes
Old 11-24-2009, 10:24 PM   #7216
Originally Posted by RC MARKET View Post
WoW !
but some expensive !
yeah but if we buy from you then when it comes into europe they hit us with 19% import tax , then your deals aint so cheap !!!!
bloody customs !!!!!!
i want to wait till there is a few people driving them before i commit to buying one
sidecarphil1 is offline   Reply With Quote
Old 11-24-2009, 10:46 PM   #7217
vr6cj's Avatar
Trader Rating: 124 (100%+)
That 479 euros is 717 US which would make it the most expensive touring out by about 200 us from what I've seen.
vr6cj is offline   Reply With Quote
Old 11-25-2009, 02:29 AM   #7218
kentech's Avatar
Regarding the price you over in the US can't really compare with Europe, especially with the current exchange rate. FYI most top level TC's are 400-500 EUR in Europe.
A couple of notes on the build so far:
- motor mount/centre support and right middle bulkhead are changed in a few ways and all beautifully machined with super precision
- layshaft bearings are not flanged anymore, bulks changed correspondently
- front bulks are longer as you know, holes for old bulks still on chassis plate
- battery holes moved back as on original 416
- suspension blocks are F: 1C-1C, R: 1XA-1E
You could use the new motor mount/centre mount on a WE chassis plate as the holes are the same. However, since the motor is moved in, the machined part under the motor on the chassis plate now goes further towards the centre. Thus this might interefere with your motor, unless you use something like a SP Competition 3.0. Also note the change to the way the layshaft is mounted with different bearings.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 11-25-2009, 05:25 AM   #7219
yokemad's Avatar
Thanx for the info
so if we want to change to 416X motor mount we have to buy the opposite bulkhead as we also have to use normal bearings...
and have to file the chassis 1mm towards to centre to clear under the motor
cheers
yokemad is offline   Reply With Quote
Old 11-25-2009, 10:04 AM   #7220
Hy guys!
My car has just arrived,put it togerher but i got a HUGE problem.
The motor don't fit in the motor mount.
HPI SATURN 27T, tamiya stock,fireball 15T etc.
This type of motors have bigger front bearing and they won't fit in to mount.The mounting oval hole is too small.
I didn't know that the car is only compatible with BL motors.
Davzone is offline   Reply With Quote
Old 11-25-2009, 10:31 AM   #7221
TryHard's Avatar
Originally Posted by yokemad View Post
Thanx for the info
cheers
Bear in mind you would also lose two screw positions off the top deck. They are the two screws that the trf guys have previously used when wanting a bit more flex out of the car, but don't seem to run anymore... So it would affect your car if you ran the new motor bulkheads with the old rear (especially if you run thoose screws currently!)
If you want to keep the car as stiff, you'll need the new rear bulkheads, and the X top deck too.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 11-25-2009, 10:39 AM   #7222
reenmachine's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Davzone View Post
Hy guys!
Sounds like time to bust out the Dremel.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 11-25-2009, 11:29 AM   #7223
Yes,I've already started working on it
I know this car is not for this motor but we have a fun cat. in our nationals called gentleman,and we have to go with saturn 27t.
I must have to fit the motor in.
So sad ,because the car did not run any meters yet and i have to cut the motor mount.
Old 11-25-2009, 01:21 PM   #7224
Hy guys!
Oh, I just read in the other thread that you didn't buy a 416, but rather one of the Chinese counterfeits. So, Dremel away without remorse!
Pete Waydo
Old 11-25-2009, 02:11 PM   #7225
yokemad's Avatar
@Ed
Thanx for that very valuable info...
has anyone tried to file 1mm of the current 416 motor mount?
cheers
Old 11-25-2009, 02:59 PM   #7226
I did not say anything about what car i have.
It's a car with the same design with the 416we and it never will be a tamiya, till I change all the parts for tamiya spares.
(I found alloy spares at rcmarket without package but sold with tamiya item numbers.I dont think they are all tamiya spares...Also 3racing makes alloy parts for it.Who knows that the clones's alloy doesn't came from the 3racing's factory?)
If you didn't buy a clone you can't say it's a junk.But if yout think i'm stupid just ignore me from reading my posts...
I wrote down in the clone's topic why i bought the car.
Old 11-25-2009, 04:01 PM   #7227
Don't be so defensive. I never said the car is junk or that you are stupid. I didn't make any comment at all except to imply that I wouldn't feel the same about cutting up a counterfeit car as a genuine one.
Pete Waydo
Old 11-26-2009, 01:15 AM   #7228
Xanavi_R34's Avatar
Hy guys!
It can accommodate brushed motors.
I have fitted the Tamiya Super Stock RZ Motor and had no problem with it. Fitted perfectly.
TAMIYA TRF416
[Tamiya] [Hot Bodies]
[Futaba] [SpeedPassion] [LRP] [YeahRacing] [3Racing] [Imax]
Xanavi_R34 is offline   Reply With Quote
Old 11-26-2009, 01:47 AM   #7229
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by kentech View Post
Just a couple of pics for today, I will post a bit more details someday when I have time.
These will show you the new bulks/motor mount etc.
Thanks for the pics kentech - very jealous... Your diffs are mounted high. Is this ok with the spool or is there extra clearance with the 416X?
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 11-26-2009, 02:39 AM   #7230
penmark67's Avatar
Trader Rating: 14 (100%+)
Default yeah
[QUOTE=sidecarphil1;6640893]yeah but if we buy from you then when it comes into europe they hit us with 19% import tax , then your deals aint so cheap !!!!
Yeah and were not guaranteed we will get all the order that we PAID for isnt that right MR MARKET (told you i wouldnt let it go !!!!!!!!)
See you on your next Thread MR MARKET !!!!!!!!!!
penmark67 is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
