Old 11-24-2009, 11:00 AM   #7201
Originally Posted by sidecarphil1 View Post
i would find out why they are leaking then !!!
mine are 2 years old and never leak a drop
but back to your setup problems
i am at the track now and when i get home later i will post my setup for you to try , the car is solid and planted through the corners
Thanks for all your input.
"Do not look at small advantages, shoot high, achieve GREATNESS and live life with CONFIDENT EXPECTANCY!!!"
Elijah is offline   Reply With Quote
Old 11-24-2009, 01:01 PM   #7202
tandman's Avatar
Send a message via Yahoo to tandman
Mighty fine looking treasure Lanzer
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist Fantom Racing
Team Sweepracing
tandman is offline   Reply With Quote
Old 11-24-2009, 01:11 PM   #7203
Trader Rating: 22 (100%+)
Originally Posted by Elijah View Post
Front: Damper Pos #3 3 Hole piston
Upper arm spacer 4mm Oil 50 ae
0 sus mount F/R Spring White
Camber 1.5 Droop 6mm under arm
Caster 4 deg
Spool
Stabilizer (M)
Wheel spacer 0
Rear: Damper Pos #4 3 Hole piston
Upper arm spacer 4mm Oil 40 ae
0 sus mount F/R Spring Blue
Camber 2.0 Droop 5mm
Stablizer (M)
Wheel spacer .5mm
Fsus mount 1d rear 1d R sus mount xa and 1e
F sus arm spacer 2mm R sus arm spacer 3mm
Why are you running no shims under the suspension mounts?
I would say the car is roll oversteering ( it rolls so much that the tires loose contact patch and grip).If you dont want to put shims under the sus mounts stand up the rear shocks 1 hole.
bjspinner is offline   Reply With Quote
Old 11-24-2009, 01:51 PM   #7204
Originally Posted by Johnny Wishbone View Post
And where might one find that pile of treasure??
Here
http://www.racingfactory.fi/products...sis-Kit-102414
We picked up our 416X today. They still had 10 of them on the shelf when we left the store.
Carbon parts prep is ongoing. The target is to take the new car to the track on Saturday. Looking forward to seeing how it performs on very high traction where the 416WE is flexing too much.
jarkko is offline   Reply With Quote
Old 11-24-2009, 02:20 PM   #7205
RC MARKET's Avatar
Originally Posted by jarkko View Post
Here
WoW !
but some expensive !
RC MARKET is offline   Reply With Quote
Old 11-24-2009, 04:15 PM   #7206
kentech's Avatar
Just a couple of pics for today, I will post a bit more details someday when I have time.
These will show you the new bulks/motor mount etc.
Tamiya TRF416 / TRF416WE / TRF416X-img_8216.jpg   Tamiya TRF416 / TRF416WE / TRF416X-img_8183.jpg   Tamiya TRF416 / TRF416WE / TRF416X-img_8203.jpg   Tamiya TRF416 / TRF416WE / TRF416X-img_8210.jpg   Tamiya TRF416 / TRF416WE / TRF416X-img_8211.jpg
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 11-24-2009, 04:23 PM   #7207
lyoha's Avatar
More detail fotos, please!
Tamiya TRF-416WE - Speed Passion GT V2.0 - EPIC 10.5
BMI12RR - Sphere SSX - Vector X12 4.0
CRC Gen-X - Speed passion GT - Orion Vortex 5.5
Futaba T3VCS 2.4 FASST
lyoha is offline   Reply With Quote
Old 11-24-2009, 04:51 PM   #7208
jca2000au's Avatar
Trader Rating: 9 (91%+)
Originally Posted by RC MARKET View Post
WoW !
How much is your price and what version are you going to stock between Japanese or overseas version?
jca2000au is offline   Reply With Quote
Old 11-24-2009, 05:44 PM   #7209
mmmm, should I upgrade?
redbones is offline   Reply With Quote
Old 11-24-2009, 05:54 PM   #7210
TryHard's Avatar
Check your hinge pins... they only need to be a little bent to really hurt the car. I'd bent one the other week, and couldn't figure it out, but on checking all the pins found a slightl (less than 1mm) bend in the pin. Switched it out, and bingo, back to normal. Do the same with all the suspension blocks (both up and down and fore and aft) as well... a slight bend can be difficult to spot, but you'll feel it on track.
HiH
Ed
Old 11-24-2009, 05:58 PM   #7211
TryHard's Avatar
nice too see the forth pic showing the "wider" front bulkheads, can easily see the rear leg is closer to the suspension block from there
Shame I'll be waiting till the outdoor season to get mine, can't justify another new car this year, only had my WE built for a few months!
Ed
Old 11-24-2009, 06:05 PM   #7212
man, the yen exchange rate is killing the price! But maybe I should get it before the dollar tanks even more.
Old 11-24-2009, 08:19 PM   #7213
yokemad's Avatar
416X looks Great
could you Please check If we can fit the new motor mount to the older chassis (416-416we)
Best regards
P.s 479 euro I must say WoW
yokemad is offline   Reply With Quote
Old 11-24-2009, 08:45 PM   #7214
Rollbar mount seems a bit higher.
Old 11-24-2009, 10:46 PM   #7215
Hebiki's Avatar
Trader Rating: 26 (100%+)
check speedtechrc.com he still has some available for preorder..with a price lower than the rest even the Japan sites.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
