Like Tree3Likes
Old 11-20-2009, 12:39 PM   #7171
Johnny Wishbone's Avatar
Default Atomic ECS
I got my ECS's and finally installed them for some hard testing.
I took them apart and gave them a grease job (AWS) and re-assembled with blue loc-tite on the grub screws. So far the pro and cons are, they seem to be in general good quality but the grub screws are very thin walled and its very easy to round them out if your not careful. Once I had them back togeather I took it one step further and shrink wrapped the carnden unit to keep the pins in, incase the grub screws didn't hold. (This is the same as what LOSI does with their units). I greased the cushion pins and put the whole thing togeather.
When bench testing the car it seemed to have excessive drag? Back apart only to find that, (my car has been running using Xray steering hubs) the Xray hubs are just the slightest amount wider than the stock Tamiya ones and the flash of the hub was enough to catch the hexes when rotating giving it a notchey feel. So I installed the stock Tamiya pieces, which I can tell you, I have destroyed a lot of.
On track performance, although not any faster on our track, they are definately smoother, as my car had a noticable chatter in the very tight turns that was now gone. I also found that I could dial a little more total throw into the car and still have no chatter issues.
They are shorter that what I would prefer to run (46mm) as I fear for the outdrives. Since the ones I had in the car where pretty worn I opted to change them out, but I had a set from a 415 that I ordered by accident, so I figured I would try them just in case they couldn't take the shorter units. The 415 outdrives are made of white materail not black and just marginally shorter than the stock 416 units, so I had to file the outer aluminum collars down a touch for this all to work. The 415 outdrives seem to be a little beefier than the 416 and a little more pliable, as I have had no breaking issues yet, and I have challenged the boards a couple of times, that would have exploded the stock 416/42 setup.
The only thing to really watch out for on these units is the pin end that plunges the outdrive cup. As I was putting the car back togeather I had no shocks on the front and was rotating the spool and lifting the suspension arms and as I was rotating the whole assembly it would actually lock the suspension momentarily, the cause of this was the pin was just wide enough to catch the inside of the aluminum collar at extreme angles. I just filed a little off each end of the pin and checked again, now there was no more locking up.
Are they worth it? For sure they are smoother, but no noticeable time gain was found.
Old 11-20-2009, 12:41 PM   #7172
Artwork ygpm
Old 11-20-2009, 06:11 PM   #7173
artwork's Avatar
Trader Rating: 60 (100%+)
Here is the setup in case anyone wanted to see it. PM me if you have any questions.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 11-22-2009, 06:56 PM   #7174
Default ECS update
Entire day of racing and beating down walls and no pin or outdrive issues, I'm either lucky or it safe to say they are ok to use. (17.5)
Artwork, tried your setup, not the ticket for our track, thanks anyways.
Old 11-22-2009, 07:10 PM   #7175
i love mine i just put a tekin 17.5 in it and ran a race agains a buddy who has a 415 msxx MR and destroyed his! in the turns i could hold so much more speed and his car just felt lose and slugish and we had practily the exact same cars(except tune)
since im new does anyone know what parts i should keep on hand? i have a full screw set now. thanks
the 1995 McLaren F1 LM will live forever
(pardon my spelling)
Titanum28 is offline   Reply With Quote
Old 11-22-2009, 07:21 PM   #7176
artwork's Avatar
Car was really good for me today...I made two of very minor changes and the car was digging in really well on high speed sections. Sorry to hear it did not work for you...
Old 11-22-2009, 10:38 PM   #7177
miccal's Avatar
Trader Rating: 23 (100%+)
What changes?
miccal is offline   Reply With Quote
Old 11-23-2009, 03:38 AM   #7178
Stephtruc's Avatar
Hi,
witch retainer (cup ?) using with HPI gold & silver 14mm spring ?
Tamiya alu are too small and spring does not fit very well....
Thx
Stephtruc is offline   Reply With Quote
Old 11-23-2009, 04:17 AM   #7179
Stein Tumert's Avatar
Originally Posted by Stephtruc View Post
Hi,
Thx
I use the standard plastic one...has worked fine...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 11-23-2009, 06:15 AM   #7180
I had the worst weekend for the short time I have the 416WE. The first weekend the car was drivable but week after week the car became progressively worst, my rear end keep swinging out on the 180 deg corners, I tried different springs, oil's and setup and no help, it happen mostly on power exiting corners.
My setup: Front spring white/50 oil
Spool
No shims under arm pivots
4mm shims under camber links
1.5 camber
1ds block up front
Rear spring Blue/40 oil
Start with 4mm shims under camber links
2.0 camber
1e and xa rear.
I tried softer spring and oils and to no avail the car still spin out.
"Do not look at small advantages, shoot high, achieve GREATNESS and live life with CONFIDENT EXPECTANCY!!!"
Elijah is offline   Reply With Quote
Old 11-23-2009, 07:05 AM   #7181
artwork's Avatar
Originally Posted by miccal View Post
What changes?
lowered the inside camber link in the front to 3mm and moved the rear shocks in one hole. Minor changes, but seemed to help on the track.
Old 11-23-2009, 07:34 AM   #7182
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Please post your entire setup... And have you checked the car for anything broken or bent ? Hingepins etc ?
Spool
1.5 camber
1ds block up front
2.0 camber
1e and xa rear.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 11-23-2009, 08:01 AM   #7183
Gotta try anything once, could have been the ticket. Nothing really wrong with the setup, but our track is very small and tight compared to what you guys have, so I needed a more responsive setup. Your setup was easy to drive and consistant, but I couldn't drive the car as hard as what our track requires, to slow a transition in the tight corners, but I can see where this would be a nice setup for a flowing type of track. Thanks for the setup though.
Old 11-23-2009, 08:03 AM   #7184
Spool
1.5 camber
1ds block up front
2.0 camber
1e and xa rear.
I agree with Tim, please post your entire setup, on a sheet if possible and also what surface and class of motor your running.
Old 11-23-2009, 09:42 AM   #7185
kentech's Avatar
Tomorrow should be a good day
Someone please update the thread title to Tamiya TRF416 / TRF416WE / TRF416X
kentech.wordpress.com
kentech is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
