Old 11-17-2009, 10:19 AM   #7126
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
Originally Posted by syndr0me View Post
I'll have to give them another shot, it seems like they're so frequently out of everything I want that I stopped shopping there.
Seems that Tamiya Usa, is a rather diffacult company for shop Owners to deal with, For example We have a local Track That has been trying to get kits and parts for a few months now, and it has not been exactly Easy for them to get anything. and they are within driving distance.
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 11-17-2009, 10:45 AM   #7127
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
Originally Posted by gimpex View Post
Is this what you looking for ? 53970
http://www.rcmart.com/catalog/rc-trf...0-p-24633.html
I dont think they will work
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 11-17-2009, 11:06 AM   #7128
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by yokemad View Post
I hate using Alloy parts but I think I must use them this time ...I'm sorry to say that but Tamiya Part quality is a bit Low
Doesn't every car have its weak front end piece though? Don't most XRay guys run alloy knuckles? I think it's just a matter of finding the right combination of alloy and plastic for the front of any car. Also, if you guys aren't running a hard front bumper, that really helps. The Parma T2 bumper can be trimmed to fit quite easily.
syndr0me is offline   Reply With Quote
Old 11-17-2009, 11:54 AM   #7129
lyoha's Avatar
You are mistaken. This works very well. Not as good as in X-ray, but sufficiently ...
Originally Posted by B18C Turbo View Post
keith,
The Yeah racing C-hub is much stronger, closer anodizing match,
and very cheap (about $11).
I think you are constantly checking caster after any collision? Alloy C-hubs can bend slightly and just because it is very difficult to see.
Tamiya TRF-416WE - Speed Passion GT V2.0 - EPIC 10.5
BMI12RR - Sphere SSX - Vector X12 4.0
CRC Gen-X - Speed passion GT - Orion Vortex 5.5
Futaba T3VCS 2.4 FASST
lyoha is offline   Reply With Quote
Old 11-17-2009, 12:18 PM   #7130
Speaking of which, you guys might want to pick Syn brain on what materials he is running in his car. Currently he is the man to beat at the local track and his car looks very fast and stable.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 11-17-2009, 12:49 PM   #7131
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Speedtech is willing to work with me and send it priority mail-- so im okay there.. sort of.. I still have carbon blocks.
I dont care who makes them-- yah racing, 3 racing.. traxxas racing... HOW can i get an aluminum set of blocks here by saturday?
Worse comes to worst- and ill run the softies, i guess.. i have to make sure i still have them.. I think i threw them out?
OUT
Keith Billanti is offline   Reply With Quote
Old 11-17-2009, 12:55 PM   #7132
seaball's Avatar
Send a message via Yahoo to seaball
will we be seeing you again, this weekend, sir?
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 11-17-2009, 01:53 PM   #7133
Stein Tumert's Avatar
Rubber casters---=== junk.
Well...., Marc, Victor, Jilles runs the "junk" and not alu parts...believe they say the car works better with the plastic parts...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 11-17-2009, 02:27 PM   #7134
syndr0me's Avatar
I think maybe he means the IFS versions of those parts which are a much softer plastic.
The TRF team also runs aluminum CVD's up front, and we all know how well those work. I think a lot of that type of thing is heavily dependent on what type of barriers your track uses. I imagine dots or rolled curbs are a lot easier on parts than heavy boards. I definitely saw some of the European drivers struggling with parts breakage at IIC. We've mostly figured out ways to overcome those problems, but it rarely means running the stock pieces.
Old 11-17-2009, 03:21 PM   #7135
TryHard's Avatar
No worries man. I was really pushing the car.
Martin (Crisp) came to my track and he was feeding me ideas for setup all day and it seems i kept getting further and further away from where I needed to be.
Until this week I have broken only a couple parts. Also caster blocks, though. lol.
Had a nasty traction roll once traction came up... but before i started messing with the car it was right on pace... but after 3 rounds- the pace was like 1.5 laps faster- and my car was getting progressively worse.
I dont care who makes the aluminum-- as long as they are true.. lol.
I have to beat this traction roll. Martin says his car will roll too if he is not careful. Just seems wrong to have to adjust driving style to accommodate for a poor handling characteristic.
Think the Xray pieces will fit? Does anyone have the specs? Same pin? Height? that would be ideal. I can modify a little- i just dont want to have to drastically change things to make up for this.
ALSO--- a FYI for everyone. I picked up the LCDs that are available now from Atomic (i think it was atomic)... I got two weeks out of them before a drive pin broke. (in 13.5 rubber mind you) I dont know If replacements can be bought- i havnt looked into it. They work great- really smooth out the steering, but the pin diameter needs to be increased, and they need to be longer. I had to readjust them many times.
KB
Hey keith,
Noted with interest your talking about nasty traction roll... I was suffering the same this past weekend, running xenon28's on some duo carpet... They were just generating a silly amount of grip. Anyway, tried a whole host of things to cure it as follows;
Higher front rc (0.5mm under fron block, 1mm under rear for a bit of anti dive).
Wider car (5mm hexes)
Harder oil (up too 600wt from my usual 500... Would have tried harder, but didn't have any!!)
Droop at 7F/6R (down from 6/5, partly to take account of the bigger tyre diameter)
4.5mm on the ackerman
And one final thing that made the biggest difference, and I only ran this when I got told the car seemed to be dumping all its weight around...
Harder roll bars all round (hard front, med rear)
With the harder bars settled the car completely in roll, so much so I think its now overdamped for pitch, as I did loose some steering, and the car was a lot lazier. However it didn't traction roll once in the last final, so it was a deffinate improvement
I should also mention (and this is probably specific to the xenon wheel) that I also drilled some larger air holes into the wheel to help. The air hole as std is tiny (about 0.5mm dia), and it is pants at getting the air out. This is partly what I believed was causing the car to be nervous on those tyres, and having backed to backed std hole vs redrilled, I'm now convinced of it... Mugh smoother. Didn't halp too much with grip roll, but did improve the feel of the tyres not sure how legal it is mind... But ok for the club I was at
As for the cut top decks... I can kinda see the theory, but I'll admit I'm not overly convinced.. However still something to try, so be whipping the dremel out for the weekend
Regards
Ed
Old 11-17-2009, 04:13 PM   #7136
JimmyMac's Avatar
Plus another thing to also consider is that the pro guys tend to screw up less. Plus the competition is generally so close between them that one mistake or wreck can cost them that run. So they can afford to run the graphite chubs and aluminum cvd's etc. Us club racers need something more durable and the competition is not always that uber close. Go to a big race, run the graphite stuff. Go to a club race, run the durable stuff.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 11-17-2009, 07:20 PM   #7137
Yes- I was referring to the "rubber" casters. (plastic- not graphite)
But- Im happy to call the graphite ones junk too.
The PRO's are pro's. But im no slouch, and I rarely break anything- let alone 5 C hubs in one day
The entire time I had the JRXS-r-- from prototype to production car, I broke like 4 arms. I was about the only person who didnt think there was anything wrong with the initial batch of arms (ha)
I hate aluminum add on's. But somethings gotta give here lol.
I will say that they likely didnt break from contact with the boards! it was from the VIOLENT traction rolling. It has been named the "Billanti traction roll" at my track.
I have never had a car lift like this LOL. It is gruesome.
TryHard-- Im loving the direction your going. Im going to print that post. I always seem to have my own ideas for setup= but a lot of those thoughts, seem to be in line with what my gut says.
I like the higher front RC.. but iv never been into antidive. I did try that a few weeks back and took it out. Didnt think to just raise the whole front. Cant wait to try that.
I generally run a narrower front than rear too.. I think this makes the car a bit more reactive around entry and mid corner.. ill try it wider.
I actually as a last resort- went to a front diff- as some of the worst rolls, were on power coming out of really tight turns. The diff- well, it worked sort of-- It wasnt rolling, but now diffing horribly. And the diff was barely a diff- almost a spool, it is so tight. I think some suspension adjustment would make this go away-- but the car was a little slower.
Martin had me lightening oils and softening suspension etc. I figured, his car= he knows his stuff.. (he has been running these cars for probably about 8 years).. but i think this is a case where one's setup just doesnt work for someone else.
I have driven his car, and it is very responsive- like 10x's as responsive as mine, and many people have said my car is way too aggressive. I like my wheel sort of soft around center.
I like the car a lot. I think it is very well designed, but-= I am not overly thrilled with the parts support. I was going to get the X or SX or what ever the new car is, but to be honest- this recent stuff has soured me a little.
Keith
@Goetz.. No. not this week. Im coming. Get your crap together- get your passport!! come race with me! im sick of always coming to see you guys= with no return gesture
OH- and im running aluminum front CVDs now.. seem to hold up better than the caster blocks (ha)
OUT
Old 11-17-2009, 09:58 PM   #7138
SammyZ's Avatar
Trader Rating: 138 (100%+)
ok so i have a strange problem that I encountered today and couldn't figure it out?
The car in general is predictable and easy to drive on power
but as soon as i let off throttle the car is loose entering the
corner and then while drifting it eventually grabs traction and
the car jerks (hard to explain?) and is unpredictable & very hard
to drive.
The car didn't do this before i changed to corally springs and a brushed setup (yes i know, my tekin blew up and this is all I had)
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 11-17-2009, 10:29 PM   #7139
Keith at the Cam race I had roll issue's too.
here is my set-up from there:
Front:
1d-1d
4.5mm under front camber link
1mm spacer on the wheel hex
med sway bar
3 hole
Muchmore 600
Tamiya white spring
2.5mm of spacer behind front arm(wheelbase)
middle hole on shock tower
outmost hole on suspension arm
1.5mm of droop(uptravel)
Rear
1xa-1d
3.5mm under link at bulkhead
3mm on outmost hole on the knuckle
.5mm spacer on wheel hex
small sway bar
3 hole
Muchmore 500
Tamiya blue spring
2.5mm of spacer in front of rear arm(wheelbase)
3rd hole from top on shocl tower
outmost hole on the holes closer to the bulkhead
1mm of droop(uptravel)
5mm akerman, .5mm bumpsteer shim on the knuckle, 4 screws removed from the rear of the topdeck for chassis flex.
most of the weight added was to the middle of the car on the inside of the battery. A couple pieces were needed on the outside for balance side to side.
I was running sorex 28's then switched to 32's once grip came up and then the car was dialed, abosolutely no hint of roll and didn't lose a tenth switching to the 32's. Hope some of this helps
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 11-18-2009, 05:37 AM   #7140
@ Joe= thanks, ill take that one too. I dont think im far from yours actually- well, before Martin had be changing things.
I havnt tried 32's yet, but i think its in the future...
I am going to start fresh this weekend. I have added so much weight to the car- and its obviously not helping. SO- im taking it all out.
Complete tear down.
KB
OUT
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
