Old 11-11-2009, 12:45 PM   #7036
JCarr's Avatar
Thanks man, think I'll order me up a set here soon.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 11-11-2009, 12:50 PM   #7037
syndr0me's Avatar
Trader Rating: 32 (100%+)
Atomic shafts are the same length as the stock 44mm CVD's. If you're the type that prefers 46's, it's something to keep in mind.
syndr0me is offline   Reply With Quote
Old 11-11-2009, 01:22 PM   #7038
JCarr's Avatar
I forgot about that, thanks. Running a spool with 44mm is ok though isn't it? I thought the problems with splitting the cups were if you were using the 42mm. I'm no pro driver by any means, so I tend to tap a board now and then.
Gorilla Size Racing
Old 11-11-2009, 01:34 PM   #7039
yokemad's Avatar
I've been using xray ecs drive shafts and they transform the car to another level I do recommend them...
I'll try them on 416 soon
yokemad is offline   Reply With Quote
Old 11-11-2009, 02:11 PM   #7040
syndr0me's Avatar
44's kill the spool inserts, and are what comes with the WE. I don't think 42's even work with the spool.
Old 11-11-2009, 02:19 PM   #7041
i think 42's will work with a really narrow front end like A A blocks
but i have never been that narrow
sidecarphil1 is offline   Reply With Quote
Old 11-11-2009, 04:44 PM   #7042
yokemad's Avatar
so which Driveshafts you guys using with spool?
46-44-42???
Old 11-11-2009, 06:02 PM   #7043
CraigM's Avatar
Trader Rating: 34 (100%+)
The 44s are the way to go... if you can keep it off the boards . The 46s can chatter and rob a little steering but they look after the cups better
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 11-11-2009, 09:45 PM   #7044
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
I'm running C C front with the 44mm shaft works fine. I dont think they make a 46mm shaft yet
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 11-11-2009, 09:50 PM   #7045
JimmyMac's Avatar
46mm shafts been out for several years. They started with the Evo IV I believe.
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
JimmyMac is offline   Reply With Quote
Old 11-11-2009, 10:13 PM   #7046
Sorry, I was talking about the atomic drive shaft they only make them in 44mm
Old 11-11-2009, 11:10 PM   #7047
suparajicon's Avatar
Does anyone knows which springs fits the Tamiya dampers? The thing is that as I running with Lipos I have no idea which oil or springs use. And I don,t that tamiya spring are made for lipos...Can anyone help?
Living in a banana republic
suparajicon is offline   Reply With Quote
Old 11-12-2009, 04:15 AM   #7048
Stein Tumert's Avatar
Well....we do run the white/blue Tamiya springs indoor and HPI springs on asphalt....with LiPo 2S...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 11-12-2009, 04:25 AM   #7049
Which HPI color do you use with 2s? I run on indoor asphalt.
Does Tamiya have only yellow,red and blue short or long? Or they have more?
Old 11-12-2009, 07:38 AM   #7050
yokemad's Avatar
hi guys
I know one piece front rear suspension block bends so easy after a crash do you guys recommend me to order split design two piece holders? if so which one should I go for 1c or 1d?
another point is servo saver I have kimbory servo saver should I go for tamiya one and alloy horn combo or not?
thanx in advance
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
