Old 12-21-2007, 12:42 AM   #691
JimmyMac's Avatar
Hmmm, buy me one and I'll let ya know how it does!
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 12-21-2007, 01:00 AM   #692
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Originally Posted by syndr0me View Post
I -love- how much room there is for electronics on this car.
That is CLEAN. A+ on the wiring. I like the little touch of a custom servo lead.
Racing4Evo is offline   Reply With Quote
Old 12-21-2007, 01:04 AM   #693
syndr0me's Avatar
Trader Rating: 32 (100%+)
Thanks! I found some servo leads with all black wires from Hitec, and just replace my plugs with those now, and cut them to length. With some pins and a crimper, it's pretty easy to make plugs however you want them. Replacing the lead in the LRP TC Spec sucked, though. I wouldn't suggest that, and kind of regret messing with it myself. I need better equipment if I'm going to solder tiny wires to a board like that.
I need to do something else with the motor wires, still. Maybe rotate the motor so the connector is toward the front of the car rather than straight up, and tuck the wires in. I've got a shorter harness coming, too. Does anybody make one shorter than 100mm though?
syndr0me is offline   Reply With Quote
Old 12-21-2007, 01:26 AM   #694
alan1467's Avatar
Speedpassion do a 90mm but that's the shortest I've seen
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 12-21-2007, 02:05 AM   #695
bigbutstupid's Avatar
so anyone has a verdict to how this little beast rules the track?
bigbutstupid is offline   Reply With Quote
Old 12-21-2007, 02:18 AM   #696
sosidge's Avatar
I have used it. When the pin is in it is very effective and solid. The downside is that the springs are weaker than, say, the Tamiya High Torque saver. So, when/if you break the pin, you end up with slightly sloppy steering.
I was probably going through the pins at the rate of about one per meeting indoors. I don't crash a huge amount but I am not perfect either.
Old 12-21-2007, 02:48 AM   #697
TryHard's Avatar
Never tried it... and TBH I always use a solid horn now. When I used a Kimborough saver, found that it rubbbed on the chassis plate (with the 415 at least). Running a solid horn removes that possibility, and takes slop out the system... I'm a good enough driver now to not hit things too
I thought I'd done my first servo last meeting (felt gritty), so I took the S9550 apart, but couldn't find the problem (all the gears are fine). Seems that the splines on the horn had stripped instead Just to be suere though, I've retired the servo to my mini...
Regards
Ed
Old 12-21-2007, 04:19 AM   #698
TRF415boy's Avatar
Who are you ? Why do you post under Ed's account ?
TRF415boy is offline   Reply With Quote
Old 12-21-2007, 05:51 AM   #699
Send a message via MSN to jontang001
Regards
Ed
Hi Ed
Have you get your 416 yet?
After I tried mine on carpet was not so good as 415...
But outdoor was very good with the original setting!!!!
So, wish we can change some information about the setting...
Thanks!!!
TAMIYA TRF416, EVO5MS, TB03 FullOP
Schumacher Mi4LP, CAT SXII, Cougar
jontang001 is offline   Reply With Quote
Old 12-21-2007, 07:06 AM   #700
Trader Rating: 45 (100%+)
Woohoo!! Just picked it up from the post office. Going to start building tonight!!
Apex is offline   Reply With Quote
Old 12-22-2007, 05:39 AM   #701
miccal's Avatar
Trader Rating: 23 (100%+)
Does anyone know of anywhere that has TRF416 parts yet, such as the C-hubs and front uprights?
miccal is offline   Reply With Quote
Old 12-22-2007, 11:22 AM   #702
Eirik's Avatar
Finally, my car is ready to Rock!
Eirik is offline   Reply With Quote
Old 12-22-2007, 01:26 PM   #703
RC MARKET's Avatar
RC MARKET is offline   Reply With Quote
Old 12-23-2007, 12:54 AM   #704
Found out something lame.
If you use the short reversible arms on the rear, the right side will have problems. The plastic dog bone protector will hit the diff nut and you can't adjust your camber to spec. You can try to use a wider suspension mount, but you will then be limited to about 1degree of rear toe in. Unless you have a 42mm dog bone (53502) it won't work
BTW, the short sus arm has no slop what so ever. The shaft sits tight into the arm. What happened to you tamiya?
redbones is offline   Reply With Quote
Old 12-23-2007, 01:14 AM   #705
Eirik's Avatar
I just used a knife to remove some material from the blades and it's fine!
Also, remember to squeese the diff spring a couple of times before you install it. This will make it shorter and make up some room for the blade.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
