Like Tree3Likes
Old 11-04-2009, 08:21 PM   #7006
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
Originally Posted by ark View Post
Will do! Im sure it'll come good. By the way, the help on this thread is awsome! Thanks so much
i know this sounds kinda obvious. but double check and make sure the t-nut is on the shorter diff half .
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 11-04-2009, 10:16 PM   #7007
Imho. I don`t know how many guys use this, but i always run in my diff before i`ll go to the track
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Old 11-04-2009, 10:59 PM   #7008
Originally Posted by TryHard View Post
Really... if you do a bit of reading on the plates (it's on the website ) it says the sheets are 7mils thick, which actually comes out at 0.18mm... so naff all affect on the ride height really
I'm not running one, but would be sorely tempted when the outdoor season rolls around again...
Regards
Ed
i will do a report and some photos whan thay arrive
got some for my TRF and my F103 15th anniversary
sidecarphil1 is offline   Reply With Quote
Old 11-05-2009, 02:22 AM   #7009
miccal's Avatar
Trader Rating: 23 (100%+)
RC Champ are saying December 10.
Originally Posted by runinonempty View Post
Any more updates on the release of the 416x?
miccal is offline   Reply With Quote
Old 11-05-2009, 06:04 AM   #7010
Hi, I bought used TRF416 roller and am now getting parts to race it in Stock-class. Our stock-class uses 17.5t brushless motors and other racers has recommended me to use overall ratio of 4 to 4.5. So Now I'm after right spur/pinion combination. I've been thinkin of gettin 70t spur and few pinions in range from 32 to 38.
Now I just need to be confirmed, can I use 70t spur in this chassis or not?
And is this right kind of spur?
http://www.finRC.com
AiR2k is offline   Reply With Quote
Old 11-05-2009, 11:01 AM   #7011
It doesn`t matter what spur you use... 68,70 or 72t if you have enough pinjons up to 35
I have VTR Tamiya with 17.5t and i use 72 spur and 32 pinjon so ratio is 4.50 then
Have fun
Old 11-08-2009, 04:24 AM   #7012
Default trf416we rear toe in problem
hi all,
just bought used trf416we, somehow rear toe in degree left & right is not the same (Left: 3.5' Right: 3')
no sign of wear off on hingpin/arm/uni shaft, everything on rear suspension firmly attached
should the left & right toe-in had different value what would be the effect on the car ? which parts to adjust to make them equal
TIA
leonardi
leonardiw is offline   Reply With Quote
Old 11-08-2009, 07:42 AM   #7013
Xanavi_R34's Avatar
Try checking the uprights.
TAMIYA TRF416
[Tamiya] [Hot Bodies]
[Futaba] [SpeedPassion] [LRP] [YeahRacing] [3Racing] [Imax]
Xanavi_R34 is offline   Reply With Quote
Old 11-08-2009, 08:49 AM   #7014
could you be more specific which uprights are you referring to?
TIA
leonardi
Old 11-08-2009, 09:03 AM   #7015
94eg!'s Avatar
Trader Rating: 17 (100%+)
Originally Posted by leonardiw View Post
hi all,
TIA
leonardi
Also be sure that the wheels your using to check toe are true. If your using your plastic wheels, they are almost never perfectly round even when new. A half a degree of warp would more than typical. I see that on my Camber gauge all the time.
If your using setup wheels to measure (machined alloy), then the next thing to check would be the uprights. That's the plastic parts that hold the wheel bearings and axles. If one get's bent, then the toe will pointing in the wrong direction...
94eg! is offline   Reply With Quote
Old 11-08-2009, 10:05 AM   #7016
AUDI 0000's Avatar
I have just aquired a trf416, It looks really nice. Iam getting it ready for racing stock class. What spares are the most used? I want to make sure Ive got enough of the parts that commonly would need replacement. Any input is appreciated. Thanks.
TAMIYA TA05v2 /// TRF416 ///
AUDI 0000 is offline   Reply With Quote
Old 11-08-2009, 12:00 PM   #7017
SammyZ's Avatar
Trader Rating: 138 (100%+)
first of all ditch those aluminum steering turnbuckles and the aluminum
ball studs in the steering rack with Titanium and steel parts. Then swap out the front CVD bones to steel 46mm and put the stock aluminum peices in
your spares box.
Now you can load up on spares, get:
46mm hinge pins
C-hubs
Arms
Steering Knuckles
Ball studs
Spool cups (if running spool)
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 11-08-2009, 09:04 PM   #7018
thx for your detail reply, i'm using titan setup tools to measure it
just check on both left & right plastic uprights, they are in good condition but the previous owner put different shim on each side
on left uprights Front 0.2+0.3, Rear 0.5 (non tamiya spacer)
on right uprights Front 0.55, Rear 0.55 (tamiya kit spacer thickness is not exactly 0.5mm as stated on the manual according to my digital caliper it's 0.55 )
will this affect rear toe in measurement ?
TIA
Leonardi
Old 11-08-2009, 11:27 PM   #7019
veecee's Avatar
Trader Rating: 34 (100%+)
There are always tolerances to consider. If you loosen the suspension blocks you can shift the blocks slightly - eg rear block to the right, front block to the left, or both - to get this corrected.
SMOKEM --- XPRESS --- HIRO SEIKO
veecee is offline   Reply With Quote
Old 11-09-2009, 12:55 AM   #7020
TRF415boy's Avatar
TIA
Leonardi
Check that your hinge pins aren't bent, and that your toe blocks are straight. That'll be for me the first things to check on a 2nd hand car. Incidentally I have just picked a 2nd hand 416 and of course, 3 out of the 4 blocks were bent. It doesn't matter since they're not the ones I am using (put the short arms directly on it and C-C, XA-E).
TRF415boy is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
