Like Tree3Likes
Old 10-29-2009, 01:48 PM   #6946
Johnny Wishbone's Avatar
Originally Posted by sidecarphil1 View Post
i want to replace the 5mm ball joints on my TRF but i want to use either steel or Flurine coate ones , just to stop the wear
does any one have a part number for them ??
both the nut type and the screw type
For the steering on my car I replaced them with the new Xray steel ball studs they are 8mm studs and with the cups a pretty slop free and strong to boot. I think if you go back a couple of pages Syndrome posted the part numbers for the Tamiya ones.
Old 10-29-2009, 03:14 PM   #6947
veecee's Avatar
Trader Rating: 34 (100%+)
Go with the Fluorine - 53598 (stud) and 53599 (nut).
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 10-29-2009, 06:08 PM   #6948
ark
Just a question. Im after some D and E blocks for WE. Are the 3 racing sus mount blocks the same as the tamiya ines? (Im looking at RC Markets inventory)
example: 3 racing part number 3R-415-01/1D
Tamiya part number 51068 (D)
cheers
ark is offline   Reply With Quote
Old 10-29-2009, 06:16 PM   #6949
veecee's Avatar
Default Axle Length?
Sorry I've never used the 3Racing blocks but you would expect that they would have done a half decent copy job!
AXLE LENGTH
Can someone please tell me the length of the Tamiya axle? I'm after the total length of just the shaft area. Unfortunately I dremelled mine down so I don't know for sure... Thanks.
Old 10-29-2009, 07:20 PM   #6950
ark
Cool. Also another question, how do the spool outdrives hold up? Im ordering some parts soon but havent run the car yet.
cheers
Old 10-29-2009, 07:45 PM   #6951
cheers
If your running the 42mm axles they are hard on the outdrives, if you go to the 46mm axles this make them pretty bulletproof. Also remeber to grease the cup or they will melt, with the grease you have no problems, it doesn't require a lot of grease either.
From what I've seen the 3R blocks tend to have a little more material around the bushing area and this could cause clearance issues depending on where you are using them
Old 10-29-2009, 07:47 PM   #6952
ark
Sweet thanks Johnny
Old 10-29-2009, 07:49 PM   #6953
Originally Posted by veecee View Post
AXLE LENGTH
What are you looking for as far as a measurement goes? Is this the "dog bone" or the axle that you want the measurement off of?
Old 10-29-2009, 08:01 PM   #6954
syndr0me's Avatar
Trader Rating: 32 (100%+)
Anybody used the Atomic LCD's? I'm concerned they're the length of the 44's and will destroy spool cups, when we all know the 46's are where it's at.
syndr0me is offline   Reply With Quote
Old 10-29-2009, 08:04 PM   #6955
veecee's Avatar
The axle please. I can't measure mine because they were dremelled down.
Old 10-29-2009, 08:05 PM   #6956
Did you get a set yet? I'm thinking about trying them too, but have the same concerns, although 44 is better than the 42 stock unit.
Old 10-29-2009, 08:09 PM   #6957
They could be just a tick under 30mm, mine are ground as well, but I don't think a whole heck of a lot.
Old 10-29-2009, 08:39 PM   #6958
syndr0me's Avatar
Thinking about it. I didn't realize HKS Hobby is a US shop, so shipping is like $5 for us.
Old 10-29-2009, 08:54 PM   #6959
A friend was watching a guy prac with some last weekend, he said in mod they lasted 2 laps before a pin broke.
Probably the same as the Xray ones, run forever in spec but if your track has a heavy braking section in mod it will snap within laps.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 10-29-2009, 09:15 PM   #6960
I wonder if the pins are a problem, if you could replace them with piano wire replacement instead of the ground pins? I'm speculating the piano wire would be less brittle so maybe they could take the shock better. I would also do the LOSI shrick wrap deal on them to keep the pins in. JMO
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
