Like Tree3Likes
Old 10-21-2009, 05:14 PM   #6901
chrisk's Avatar
Trader Rating: 32 (100%+)
Brad
just curious of the weight of these trays?
how do they compare to other trays like the bitty design, not sure if you have used others or anyone else that are using the demon type.
The bitty design helps with the weight
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 10-21-2009, 05:28 PM   #6902
miccal's Avatar
Trader Rating: 23 (100%+)
I currently use the offset Bitty design tray, and the new tray and brace weighs about the same.
Originally Posted by chrisk View Post
Brad
miccal is offline   Reply With Quote
Old 10-21-2009, 05:33 PM   #6903
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by artwork View Post
OK so I have a couple of questions for the Tamiya experts...
I have a 416WE running Jaco Blues on CRC carpet. Our grip is pretty high in the groove but outside the groove it is pretty loose. Since our carpet is pretty new we have not quite built up a full groove everywhere just yet. With that said I am having issues with the 416 feeling floaty on the track. Does not feel very connected and stuck like it should feel. What I am trying to figure out is what people have done to get the car to be more stuck. The car feels like it is not generating enough grip both front and rear.
Setup at a high level
416WE
spool up front
50wt up front with Whites
40wt in the rear with blues
blocks flat both front and rear
1F in the rear (1XA and 1F)
1D in the front
3mm on the inside rear link
3mm on the inside front link
links long in the rear and short in the front
Medium sway in the front and small in the rear
My first thought would be to go softer all the way around, but I am just not sure this is the correct approach. any suggestions?
I was running on a really similar surface and was using Jilles' LRP TCM setup with Jaco Blues and a Mazdaspeed 6 body and it was dialed. Jack The Gripper sauce, I let it sit in on the full rear for about 20 mins, and 7/8 of the front for about 10 mins.
Old 10-21-2009, 06:57 PM   #6904
chrisk's Avatar
Thanks Miccal
smaracing.org
Old 10-21-2009, 08:49 PM   #6905
CraigM's Avatar
Trader Rating: 34 (100%+)
you guys know the weights are coming down to 1425g next year right?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-21-2009, 09:08 PM   #6906
DaSkills's Avatar
We have already switched to the new weight limit at my track. I like it, it keeps the tire wear down. Especially running 17.5 on asphalt.
TRF416 - Tamiya 801X - Xray XII - 4PK - Fantom Racing - Reedy - SMC - Jaco -LRP - Sorex -Tekin -Orion - Thunder Power
AKA: "No Limitz"
DaSkills is offline   Reply With Quote
Old 10-21-2009, 10:35 PM   #6907
Originally Posted by Johnny Wishbone View Post
Yes, 1mm spacers under the blocks but keep the .5mm antidive in the front.
Yes 1.5mm camber from 2mm.
Try the suspension mount spacers with the same droop as you have now, you'll have to reset them with that change anyways, and then fine tune from there with the droop.
Does the car flip on the turn in of highspeed corner, like a snap roll? Is your steering cranked when it happens? Just trying to get a visual of what its doing.
i will try it
the car flips mid corner on the apex , it is catchable if i am quick enough and feel it happening normally i do but then it sends me wide , and i need to hold me line due to the corner decreasing to a hairpin , my steering is about half way when i flip
sidecarphil1 is offline   Reply With Quote
Old 10-22-2009, 02:18 AM   #6908
Send a message via MSN to Bigger Brother
Europe is coming down to (most likely) 1350g, perhaps 1425..... IFMAR 2010 rules say 1350g
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 10-22-2009, 06:56 AM   #6909
syndr0me's Avatar
I was skeptical about 1420g at IIC, but it ended up working out pretty well. It seems like we're being hasty with lowering the weights, though. Isn't there a better way we could have used it, like with tougher cars?
syndr0me is offline   Reply With Quote
Old 10-22-2009, 11:10 AM   #6910
SammyZ's Avatar
Trader Rating: 138 (100%+)
i race at 1290g because rules are for suckers.
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 10-22-2009, 11:44 AM   #6911
Trader Rating: 45 (100%+)
Is there a firm date in December when the 416X will be released?
Apex is offline   Reply With Quote
Old 10-22-2009, 02:05 PM   #6912
TryHard's Avatar
1425... pah... I'm hoping it's 1350 over here in the uk
| THard.co.uk | Xray | MuchMore |
Old 10-23-2009, 01:45 AM   #6913
Toh WL's Avatar
My local agent says the 416X will arrive late November. But that will depend on HQ how soon they will sent them out.
Toh WL is offline   Reply With Quote
Old 10-23-2009, 06:26 AM   #6914
Any idea on street pricing?
Old 10-24-2009, 02:13 AM   #6915
miccal's Avatar
Originally Posted by Besercoe View Post
I recently found perhaps the best lipo tray ever made. Just arived today.
Demon products out of Taiwan, but its been difficult getting hold of them.
Mounts to the centreline of the chassis, with the tray sitting up off the lower deck to prevent tweak or change in chassis stiffness.
Mounted up the little fella last night, it took a little bit of trimming as the mounts were close to the belt, and a liberal use of shims.
You can see the tray mounts to the centreline, and does not touch the chassis at all. Brace holds pack in, but is not pressing on the battery, car can flex without binding on the tray or the battery.
Originally Posted by miccal View Post
Thanks to Bradd I received one of these Demon lipo trays. I actually have the original TRF416, but it still fits, the only thing you do different is screw the lipo tray into the center post for the motor mount from the top, so that there are two screws - one from the bottom through the chassis and one from the top through the lipo tray. I will post a picture this weekend.
So here are some pictures of the Demon lipo tray in my original TRF416. The tray mount that connects to the center post of the motor mount is on backwards and screws in from the top with a 2 mm shim. I had to remove some material from the tray mount under the aerial post to clear the belt. The tray holds my SMC lipo perfectly, and is perfectly balanced with no added weight.
So although the Demon lipo tray says it is for the TRF416WE only, it fits just fine in the original 416 with no serious modification.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
