Old 10-19-2009, 03:42 PM   #6871
veecee's Avatar
Trader Rating: 34 (100%+)
TRD = Tamiya Racing Domination!!!
I've been having a few issues with my spool. First I had a tendency to rim the cups on some hits. But that's been fixed with 46mm shafts and slightly better driving. I recently started running a 6.5 instead of a 10.5. In my last rebuild, the channels on one spool cup had partially filled up with melted plastic!!! Anybody else having issues with the Tamiya spool???
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 10-19-2009, 10:00 PM   #6872
I'm running stock 416. I want to have 1 degree and 0.5 degree less on rear toe in. What suspension mount should I buy? thanks
ioxqq is offline   Reply With Quote
Old 10-19-2009, 11:18 PM   #6873
veecee's Avatar
X-D and A-E would give you 2 degrees. But if you have 44mm driveshafts there is a small chance the blade can bottom out against the diff nut with X-D. No problems if you have 42mm driveshafts.
Old 10-20-2009, 12:02 AM   #6874
Stein Tumert's Avatar
Look at TryHards website http://www.thard.co.uk/ There you can find a form with all the suspension blocks so you can see how they combine.
You can set up the same toe-in with different suspension mounts, but with varying width.
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 10-20-2009, 01:06 AM   #6875
Stilo's Avatar
Had that same problem when the outdoor season started here and I was running modified. Adding some grease to the cup seems to fix the melting problem.
Team EuroRC.com
Stilo is offline   Reply With Quote
Old 10-20-2009, 02:21 AM   #6876
veecee's Avatar
Thanks Stilo!
Old 10-20-2009, 03:19 PM   #6877
veecee's Avatar
Square has released some new black center pulleys for the TA05/v2 (same pulley as 416). There is a 20T and a massive 22T! Looks like they are available at RC Market.
Old 10-20-2009, 04:46 PM   #6878
Looks very interesting, and as the 416 belts are very short, it should not be difficult finding a longer belt to accomodate them.
I have just preordered a T3, i might have to throw some in if in stock when it arrives.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 10-20-2009, 07:20 PM   #6879
sonic31's Avatar
hello all, inspired by the recent ets i decided to try and copy the way marc rheinard had his lipo in place so i came up with this:
as you can see in the pics i used a battery bar and a bullet plug and tube but i also used a 3mm screw to secure the bullet male plug in place so it doesnt move around when i connect/diconnect the plug. hope ya'll like
Tamiya TRF416 / TRF416WE / TRF416X-picture-21.jpg   Tamiya TRF416 / TRF416WE / TRF416X-picture-22.jpg   Tamiya TRF416 / TRF416WE / TRF416X-picture-20.jpg
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 10-20-2009, 07:24 PM   #6880
SammyZ's Avatar
Trader Rating: 138 (100%+)
who was the genius that decided to put aluminum turnbuckles
in this car?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 10-20-2009, 07:30 PM   #6881
Send a message via MSN to maxrcp
Default wheel axles and diff pully
hi ALL
i have been too much problems with my 416 we wheel axles, they broken in the hole that fix with the junction with dogbone and do not find more wheel axles in stores...
there is another car or brand of those axles that fits on my 416 we??
i need to change the pulleys from diff and front pulley
there is any difference between black or withe colors?
with one is better??
i need the hardest ones not lighter
best regards
MAx
maxrcp is offline   Reply With Quote
Old 10-20-2009, 07:38 PM   #6882
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
in this car?
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 10-20-2009, 07:57 PM   #6883
syndr0me's Avatar
Trader Rating: 32 (100%+)
Pretty clever! It seems like EFRA mandating internal plugs is a bit of hassle for most folks. I know they're unruly, but I kind of like my Deans plugs a little more now.
syndr0me is offline   Reply With Quote
Old 10-20-2009, 08:20 PM   #6884
sonic31's Avatar
thanks
whats silly for me is why i didnt come up with this when i first bought the pack? instead of shaving down the humps i could have just done this mod but i had opted to position the batt out more to clear the top deck. i tell you why, cause im lazy.
Old 10-21-2009, 01:22 AM   #6885
Try these spool from Titanium Racing. Their Delrin cups are a lot stronger and more durable. Hope it helps.
http://www.titaniumracing.com/produc...456&menu_ID=25
billythekid is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
